Home » Eclipse Projects » OSEE » ANSWERED - Moving to a new version - can you mix OSEE client/server versions?(Yes - use different ports)
ANSWERED - Moving to a new version - can you mix OSEE client/server versions? [message #486198] Wed, 16 September 2009 13:16 Go to next message
Mark D-B is currently offline Mark D-B
I haven't got as far as having a running 0.8.1 yet, but ....
When moving forward an OSEE version (e.g. 0.7.0 to 0.8.1) and where there
are multiple users, is it required that the system be taken down and all
users moved to the new client or, if not, which of the following options
is preferred:
a) Update the OSEE application server to the new version and gradually
update the clients
b) Gradually update the clients and finally update the OSEE application
server when all clients have been updated
[Updated on: Tue, 21 September 2010 13:18]
Report message to a moderator
Re: Moving to a new version - can you mix OSEE client/server versions? [message #486916 is a reply to message #486198] Sun, 20 September 2009 19:57 Go to previous messageGo to next message
Ray Joseph is currently offline Ray Joseph
Member
I could sure use some help. I would like to use the newest builds and instructions.
When I go to the download page, I only see the old version .7, similar with the documentation wiki.
Where can I get the new build and instructions?
Re: Moving to a new version - can you mix OSEE client/server versions? [message #493503 is a reply to message #486198] Mon, 26 October 2009 10:49 Go to previous messageGo to next message
bump
Re: Moving to a new version - can you mix OSEE client/server versions? [message #575602 is a reply to message #486198] Sun, 20 September 2009 19:57 Go to previous messageGo to next message
Member
Re: Moving to a new version - can you mix OSEE client/server versions? [message #575941 is a reply to message #486198] Mon, 26 October 2009 10:49 Go to previous messageGo to next message
bump
Re: ANSWERED - Moving to a new version - can you mix OSEE client/server versions? [message #577872 is a reply to message #486198] Tue, 21 September 2010 13:23 Go to previous message
Two or more versions of OSEE (e.g. which have incompatible database implementations such as is usually indicated by a version number difference, e.g. 0.7.x, 0.8.x, 0.9.x) may be run in parallel. Simply use a different port number for the OSEE application server in both the server and client configuration, and point the application server at a different database using its connection.xml.
One can be used "read-only" while users are migrating. When all users have migrated, the old version may then be taken off-line.
Previous Topic:Chat feature
Next Topic:Problem with document import
Current Time: Thu May 23 18:29:43 EDT 2013
Powered by FUDForum. Page generated in 0.03737 seconds
