Home » Eclipse Projects » Eclipse 4 » When are my (injected) POJO methods called?
When are my (injected) POJO methods called? [message #577774] Wed, 16 June 2010 07:50
No real name is currently offline No real name
Hello Everyone,
I am trying to write an RCP where I need to get the shell of the main application window AFTER it has been created. In 3.x I would override the WorkbenchWindowAdvisor .postWindowCreate() method, but as far as I could tell this is not used in e4.
I tried to write a class (which is not a part, since all parts already have been created and should be children of the shell I get from shellProvider....) like this:
public class MyClass {
@Inject
private IShellProvider shellProvider;
@PostConstruct
private Object myMethod() {
System.out.println("Do something using the shell! ");
return shellProvider.getShell();
but myMethod() does not get called. I also tried to use @Execute and @CanExecute but they don“t help. (Is there a good page that explains exactly what these annotations do, btw?)
Do I need to register MyClass through en extension point? Which one, and with what attributes?
I am using e4 M6.
Karin
Previous Topic:PartServiceImpl - rootContainer update currently broken?
Next Topic:Readiness of replacing a RCP app with e4
Current Time: Thu May 23 09:10:24 EDT 2013
Powered by FUDForum. Page generated in 0.01662 seconds
