Home » Modeling » TMF (Xtext) » Error generating UI [ropject from TMF grammar
Error generating UI [ropject from TMF grammar [message #57766] Mon, 13 July 2009 14:37 Go to next message
Jos Warmer is currently offline Jos Warmer
Member
I try to run the mwe workflow to generate the TMF parser and TMF UI project.
In my first tryouts this worked well, but I am now in a situation where I get an error message like:
<< ... running ..>>
7344 [main] ERROR g.eclipse.xtext.generator.Generator - java.io.FileNotFoundException: ..\org.mod4j.dsl.businessdomain.xtext.ui\META-INF\MANIFEST.M F (Het systeem kan het opgegeven pad niet vinden)
org.eclipse.emf.common.util.WrappedException: java.io.FileNotFoundException: ..\org.mod4j.dsl.businessdomain.xtext.ui\META-INF\MANIFEST.M F (Het systeem kan het opgegeven pad niet vinden)
at org.eclipse.xtext.generator.Generator.mergeManifest(Generato r.java:317)
at org.eclipse.xtext.generator.Generator.generateManifestUi(Gen erator.java:352)
at org.eclipse.xtext.generator.Generator.invokeInternal(Generat or.java:92)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invok e(AbstractWorkflowComponent.java:118)
at org.eclipse.emf.mwe.core.container.CompositeComponent.intern alInvoke(CompositeComponent.java:101)
at org.eclipse.emf.mwe.core.container.CompositeComponent.invoke (CompositeComponent.java:86)
at org.eclipse.emf.mwe.core.WorkflowRunner.executeWorkflow(Work flowRunner.java:412)
at org.eclipse.emf.mwe.core.WorkflowRunner.run(WorkflowRunner.j ava:292)
at org.eclipse.emf.mwe.core.WorkflowRunner.main(WorkflowRunner. java:239)
Caused by: java.io.FileNotFoundException: ..\org.mod4j.dsl.businessdomain.xtext.ui\META-INF\MANIFEST.M F (Het systeem kan het opgegeven pad niet vinden)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
at org.eclipse.xtext.generator.Generator.mergeManifest(Generato r.java:304)
... 8 more
7344 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - workflow completed in 5391ms!
The generator uses a pathname with .. prefixing the current project directory to find the UI project.
This works fine whenever the xtext and the xtext.ui projects are in the same workspace.
In our situation the xtext project is outside the workspace, which seems to be the only difference with the previous projects where it did work.
I cannot see where the ../org.mod4j.... is really looking (its a relative opath :-( ),
buyt my guess is that this path is wrong becasue the xtext project is outside the workspace directoty.
Has anyobe seen this before, or can anyone either confirm or reject my guess?
Jos Warmer
Re: Error generating UI [ropject from TMF grammar [message #57790 is a reply to message #57766] Mon, 13 July 2009 14:44 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven Efftinge
Hi Jos,
if not otherwise specified, it is assumed that the ui project is in the
same directory as the runtime project and has a suffix '.ui'.
However, that is just the default, you can specify the path to the ui
project using the 'pathUiProject' property:
<component class="org.eclipse.xtext.generator.Generator"
pathUiProject value="/my/path/to.ui" >
See the setters in org.eclipse.xtext.generator.Generator to find out
what can be configured.
Sven
> << ... running ..>>
> ... 8 more
> Jos Warmer
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: Error generating UI [ropject from TMF grammar [message #57864 is a reply to message #57790] Mon, 13 July 2009 14:56 Go to previous messageGo to next message
Member
Sven,
The projects are both in the same directory, but this dierectory is
outaside the workspace. That seems to be the only difference I have
with other projects.
The first time I ran the workflow the .ui project did not exist
(anywhere) and I got this message. Strange ebough, because it should
create the project we=henever this doesn't exist (isn't it?). Next
time I created the xtext.ui project, but got the same message.
Is there a way to get the absolute name of the file it tries to find?
That might help.
Regards, Jos
Sven Efftinge heeft ons zojuist aangekondigd :
> Hi Jos,
> if not otherwise specified, it is assumed that the ui project is in the same
> However, that is just the default, you can specify the path to the ui project
> See the setters in org.eclipse.xtext.generator.Generator to find out what can
> be configured.
> Cheers,
> Sven
>> project.
>> << ... running ..>>
>> at
>> at
>> at
>> at
>> at
>> ... 8 more
>> in 5391ms!
>> same workspace.
>> opath :-( ),
>> guess?
>> Jos Warmer
Re: Error generating UI [ropject from TMF grammar [message #57887 is a reply to message #57864] Mon, 13 July 2009 15:14 Go to previous messageGo to next message
Jos Warmer schrieb:
> Sven,
> outaside the workspace. That seems to be the only difference I have with
> other projects.
Yes, this is worth a bugzilla, I guess.
> Next time
> That might help.
No, at least not by configuration.
You could run the workflow with Java Debug enabled (see the runtime
configuration for MWE Workflow) and have a breakpoint in
org.eclipse.xtext.generator.Generator.generateManifestUi(Lis t <LanguageConfig>,
XpandExecutionContext) on line 352
it's """ mergeManifest(getProjectNameUi(), path, exported,
requiredBundles, getActivator()); """
there the 'path' variable denotes the path of the Manifest.MF.
It's a string composed of pathUiProject+"META-INF/MANIFEST.MF"
Sven
Re: Error generating UI [ropject from TMF grammar [message #57960 is a reply to message #57887] Mon, 13 July 2009 15:49 Go to previous messageGo to next message
Member
Sven,
I did get it working using an absolute pathname for the pathUIproject
variable. After that it seems to work with the relative path as well.
After digging somewhat deeper, I think the problem is based in the fact
that the eclipse project name and the directory name in which the
project resides are not the same. This confuses the TMF generator and
causes it to look at the wrong place for the MANIFEST.MF file.
I'll try to get a small example showing the error and add it bugzilla.
Regards, Jos
Sven Efftinge stelde dit idée voor :
> Jos Warmer schrieb:
>> Sven,
>> other projects.
>> The first time I ran the workflow the .ui project did not exist (anywhere)
>> and I got this message. Strange ebough, because it should create the
>> Next time I created the xtext.ui project, but got the same message.
>> Is there a way to get the absolute name of the file it tries to find? That
>> might help.
> it's """ mergeManifest(getProjectNameUi(), path, exported, requiredBundles,
> Sven
Re: Error generating UI [ropject from TMF grammar [message #58008 is a reply to message #57960] Mon, 13 July 2009 16:05 Go to previous message
Jos Warmer schrieb:
> Sven,
Thank you!
Sven
Previous Topic:[Xtext] ZUnassigned Rule Call not Allowed
Next Topic:Modeling predefined and custom commands with same prefix
Current Time: Sat May 18 09:27:35 EDT 2013
Powered by FUDForum. Page generated in 0.10551 seconds
