| Build custom package [message #577399] |
Sun, 22 June 2008 04:58 |
Marco Maccaferri Messages: 125 Registered: July 2009 |
I'm playing with EPP these days to build a custom package. It generally
works, however I can't get the update manager to work. From Help ->
Software Updates I get the following message:
Cannot launch the update UI. The installation has not been configured
property for software updates.
This seems true since the built package doesn't contains the p2 and
dropins folders, nor it contains the p2-related folders under the
configuration folder.
My guess is that I'm not using the correct root files, but since the
configuration files points to a local folder, I don't know how to get
the correct files. Also I think that there are some files that needs to
be generated rather than copied, but doesn't seems that there is a way
to generate these files.
What am I missing ?
Marco.
FUDForum. Page generated in 0.05461 seconds
