Home » Eclipse Projects » Voicetools » CVS Repository checkout error
CVS Repository checkout error [message #575277] Wed, 23 August 2006 19:47
Stan Rivera is currently offline Stan Rivera
Member
Brent,
This happened before your comments about my using the DTD for custom
objects in the VTP instead of modifying the XML editor, but I thought I'd
mentioned what happened anyway, just for future reference.
I was trying to check out the VTP plugins via the CVS repository and as it
was rebuilding the workspace, I got a dialog that was titled, "Building
workspace" with error, "Errors during build". In the "Details" section, I
see the following two times:
Errors running builder "Integrated External Tool Builder" on project
org.eclipse.vtp.source. The builder launch configuration could not be
found.
What does this mean. I tried the checkout again, this time I didn't see
this error. Does this mean the checkout was successful afterall?
I see a bunch of error in the plugin error log, things like:
!ENTRY org.eclipse.ui 4 4 2006-04-25 12:33:27.907
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-04-25 12:33:27.927
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.wst.xml.core.internal.provisional.format.TextNod eFormatter.formatNode(TextNodeFormatter.java:60)
!ENTRY org.eclipse.wst.xml.core 4 4 2006-04-25 16:12:16.14
!MESSAGE Access is denied
!STACK 0
java.io.IOException: Access is denied
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(Unknown Source)
If I decide not to make any changes, how do I "uncheckout" and remove the
projects from my Plug-in Development Package Explorer?
Sorry so wordy, thanks.
Stan
Previous Topic:Call to deployed openVXML app failing
Next Topic:CVS Repository checkout error
Current Time: Wed May 22 00:07:32 EDT 2013
Powered by FUDForum. Page generated in 0.04229 seconds
