| Re: Import UML model [message #575135 is a reply to message #530892] |
Wed, 26 May 2010 11:50  |
Zoltan Ujhelyi Messages: 98 Registered: July 2009 |
Member |
Sorry for the slow answer.
My first tip would be that the UML metamodel is not available. Did you try installing VIATRA2 to Rational Software Architect, or did you use a clean Eclipse with VIATRA? If its the latter case, then please verify, that the EMF representation of UML is also installed (that should contain the required metamodel).
FUDForum. Page generated in 0.01491 seconds
