| Size-Calculation of Embedded Swing Controls in Dialogs [message #574909] |
Mon, 06 April 2009 07:29 |
Dominik Kaspar Messages: 12 Registered: July 2009 |
Junior Member |
If I'm using a JFace dialog like the TitleAreaDialog and having a
SwingControl inside the dialog, the size of the main panel is not
correctly calculated after the shell of the dialog is created.
I tried all available Composites for the layoutDeferredAncestor, but no
one was working correctly. My workaround was to call pack() on the shell
in the afterComponentCreatedSWTThread() method but this works only
randomly.
Any ideas to solve this problem?
Dominik
TitleAreaDialog d = new TitleAreaDialog(topLevelShell) {
protected Control createDialogArea(Composite parent) {
final Composite comp = (Composite) super.createDialogArea(parent);
SwingControl control = new SwingControl(comp, SWT.NONE) {
protected JComponent createSwingComponent() {
JPanel p = new JPanel();
p.setLayout(new java.awt.GridLayout(10, 1));
for (int i = 0; i < 10; i++) {
p.add(new JTextField(String.valueOf(i)));
JScrollPane scroll = new JScrollPane(p);
scroll.setBorder(new EmptyBorder(0, 0, 0, 0));
return scroll;
public Composite getLayoutAncestor() {
return getShell();
control.setLayoutData(new GridData(GridData.FILL_BOTH));
return parent;
d.open();
FUDForum. Page generated in 0.01530 seconds
