Home » Eclipse Projects » Service Component Architecture (SCA) Tools » ecore model instance
ecore model instance [message #574760] Mon, 02 March 2009 10:22
Mischa is currently offline Mischa
Hi all,
is it possible to access a SCA model instance in a "Ecore like" way (SCA
meta model is already defined using EMF)? Currently I have a "xyz.composite"
xml file conforming to the http://www.osoa.org/xmlns/sca/1.0 namespace.
A xyz.ecore / xyz.xmi would be great, in particular to apply the oAW
generator framework.
Thanks in advance,
Mischa
Previous Topic:Using the SCA Designer as an abstract modeling tool
Next Topic:SCA Meta-model & Designer extensibility
Current Time: Sun May 19 02:58:01 EDT 2013
Powered by FUDForum. Page generated in 0.01473 seconds
