| Re: rse; dstore connector service; using port 0 error [message #574279] |
Wed, 23 April 2008 05:11 |
Martin Oberhuber Messages: 967 Registered: July 2009 |
Please still read those bugs, they contain interesting information how
to debug your issue (editing daemon.pl script and adding some echo
commands to trace into a file).
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Sander wrote:
> Martin Oberhuber wrote:
>> Hi Sander,
>> please ask such questions on the eclipse.dsdp.tm newsgroup which
>> is specific for TM and RSE.
>> Your problem sounds like the wrong JVM is selected by the dstore
>> daemon; it supports the Sun JVM only, but not the gcj JVM. Please try
>> explicitly setting a PATH on the server that points to a Sun, IBM or
>> BEA JVM before you launch the Daemon. See also
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=198093
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=153246
>> Cheers,
> Thanks for your reply, I'll ask there
> Btw. using Sun's Java
FUDForum. Page generated in 0.01463 seconds
