Home » Eclipse Projects » OSEE » Demodata Initialization Problem Must be one current state. Found 0 for DBJ3X
Demodata Initialization Problem Must be one current state. Found 0 for DBJ3X [message #574168] Mon, 29 June 2009 04:46
Andreas Graf is currently offline Andreas Graf
Hi group,
when running the Demo Data Action from the John Hopkins example I get the
attached error. My system is still populated at least with some
requirements. Does anybody have an idea about what's wrong?
Thx,
Andreas
org.eclipse.osee.ats.util.widgets.XCurrentStateDam.getState( XCurrentStateDam.java:37)
org.eclipse.osee.ats.util.StateManager.getCurrentStateName(S tateManager.java:116)
org.eclipse.osee.ats.editor.SMAManager.isCompleted(SMAManage r.java:703)
org.eclipse.osee.ats.editor.SMAManager.isCancelledOrComplete d(SMAManager.java:711)
org.eclipse.osee.ats.artifact.StateMachineArtifact.getPercen tCompleteSMATotal(StateMachineArtifact.java:1168)
org.eclipse.osee.ats.util.widgets.XCurrentStateDam.logMetric s(XCurrentStateDam.java:63)
org.eclipse.osee.ats.util.widgets.XCurrentStateDam.updateMet rics(XCurrentStateDam.java:51)
org.eclipse.osee.ats.util.StateManager.updateMetrics(StateMa nager.java:137)
org.eclipse.osee.ats.util.StateManager.updateMetrics(StateMa nager.java:132)
org.eclipse.osee.ats.artifact.TeamWorkflowManager.setEndorse Data(TeamWorkflowManager.java:110)
org.eclipse.osee.ats.artifact.TeamWorkflowManager.transition To(TeamWorkflowManager.java:49)
org.eclipse.osee.ats.config.demo.config.PopulateDemoActions. createActions(PopulateDemoActions.java:406)
org.eclipse.osee.ats.config.demo.config.PopulateDemoActions. run(PopulateDemoActions.java:123)
org.eclipse.osee.ats.config.demo.config.PopulateDemoActions. run(PopulateDemoActions.java:92)
org.eclipse.osee.framework.ui.skynet.widgets.xnavigate.XNavi gateComposite.handleDoubleClick(XNavigateComposite.java:214)
org.eclipse.osee.ats.navigate.AtsNavigateComposite.handleDou bleClick(AtsNavigateComposite.java:92)
org.eclipse.osee.ats.navigate.AtsNavigateComposite.handleDou bleClick(AtsNavigateComposite.java:60)
org.eclipse.osee.framework.ui.skynet.widgets.xnavigate.XNavi gateComposite$3.handleEvent(XNavigateComposite.java:100)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
java.lang.reflect.Method.invoke(Method.java:597)
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Previous Topic:Native Editor generates an exception
Next Topic:Artifact import wizard - Add to Selected Artifact greyed out
Current Time: Tue Jun 18 01:46:28 EDT 2013
Powered by FUDForum. Page generated in 0.01495 seconds
