Home » Eclipse Projects » OSEE » Native Editor generates an exception
Native Editor generates an exception [message #574154] Tue, 23 June 2009 12:52
Mark D-B is currently offline Mark D-B
I have created an artifact of "General Document" type. When I change the
Extension attribute, the icon for the artifact changes to the appropriate
one (e.g. Acrobat for pdf, bitmap for bmp, model for mdl).
This would imply to me that OSEE should know which renderer to use.
However, when I right-click->Native Editor, I get:
Tue Jun 23 14:41:15 BST 2009
org.eclipse.osee.framework.ui.skynet.SkynetGui
Plugin
SEVERE org.eclipse.osee.framework.ui.skynet.OpenWithSelectionListen er
widget
Selected (40)
null
org.eclipse.osee.framework.jdk.core.util.Lib$1.read(Lib.java :412)
at java.io.InputStream.read(InputStream.java:85)
org.eclipse.core.internal.utils.FileUtil.transferStreams(Fil eUtil.jav
a:230)
org.eclipse.core.internal.localstore.FileSystemResourceManag er.write(
FileSystemResourceManager.java:932)
org.eclipse.core.internal.resources.File.internalSetContents (File.jav
a:330)
at org.eclipse.core.internal.resources.File.create(File.java:15 8)
at org.eclipse.core.internal.resources.File.create(File.java:18 6)
org.eclipse.osee.framework.ui.plugin.util.AIFile.writeToFile (AIFile.j
ava:36)
org.eclipse.osee.framework.ui.skynet.render.FileRenderer.ren derToFile
(FileRenderer.java:87)
System(FileRenderer.java:76)
org.eclipse.osee.framework.ui.skynet.render.FileSystemRender er.intern
alOpen(FileSystemRenderer.java:73)
org.eclipse.osee.framework.ui.skynet.render.FileSystemRender er.open(F
ileSystemRenderer.java:45)
org.eclipse.osee.framework.ui.skynet.commandHandlers.rendere r.handler
s.NativeEditorHandler.execute(NativeEditorHandler.java:33)
org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.ja
va:281)
org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(Handle
rService.java:178)
org.eclipse.osee.framework.ui.skynet.OpenWithSelectionListen er.widget
Selected(OpenWithSelectionListener.java:38)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:
228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.ja
va:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.jav
a:488)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEAppli
cation.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandl
e.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runAppli
cation(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Ec
lipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.ja
va:386)
va:179)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.
java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAcces
sorImpl.java:25)
What's wrong please?
Previous Topic:What determines the order of attributes in artifact editor?
Next Topic:Demodata Initialization Problem Must be one current state. Found 0 for DBJ3X
Current Time: Fri May 24 03:07:23 EDT 2013
Powered by FUDForum. Page generated in 0.01797 seconds
