Home » Eclipse Projects » DSDP - Mobile Tools for Java (MTJ) » [MTJ RC4] when edit code ,eclipse crashed.
| [MTJ RC4] when edit code ,eclipse crashed. [message #574140] |
Tue, 16 June 2009 21:41 |
ryan_hust Messages: 6 Registered: July 2009 |
Junior Member |
Using ecipse 3.5 RC4 + MTJ RC4, everytime ,when i'm editing the code:
Display.
there will show a dialog to select the method. when i input the 'g'
letter, then the eclipse crashed. this is the crash log.
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x73fb3a23, pid=3356,
tid=3496
# Java VM: Java HotSpot(TM) Client VM (11.0-b16 mixed mode windows-x86)
# Problematic frame:
# C
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x00b56c00): JavaThread "main"
siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
Registers:
EAX=0x00000000, EBX=0x00000001, ECX=0x0013f6b8, EDX=0x00000001
ESP=0x0013ed90, EBP=0x0013eda4, ESI=0x00b56d14, EDI=0x00000000
EIP=0x73fb3a23, EFLAGS=0x00010297
Top of Stack: (sp=0x0013ed90)
0x0013ed90: 00b56d14 0013ede0 46117c28 00000001
0x0013eda0: 0013f6b8 0013edd8 4649d452 0013ede0
0x0013edb0: 00000002 00000000 00000000 00000000
0x0013edc0: 00000000 46117c28 00b56c00 234da6f8
0x0013edd0: 234da6f8 00000000 0013ee24 00b99d11
0x0013ede0: 00000017 0013ee2c 0013ee4c 00000002
0x0013edf0: 00000000 00000000 00000000 00000000
0x0013ee00: 0013ee34 0013ee04 00000000 0013ee4c
Instructions: (pc=0x73fb3a23)
0x73fb3a13: 57 01 3b 55 0c 89 5d f8 7d 1d 8b 45 18 8d 04 78
0x73fb3a23: 66 8b 08 83 c0 02 66 39 08 75 0c 43 42 40 40 3b
Stack: , sp=0x0013ed90, free space=1019k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native
code)
C
C
j
org.eclipse.swt.internal.win32.OS.ScriptGetLogicalWidths(Lor g/eclipse/swt/internal/win32/SCRIPT_ANALYSIS;IIIII
0x47dea400 JavaThread "org.eclipse.jdt.internal.ui.text.JavaReconciler"
daemon
0x47f90c00 JavaThread "org.eclipse.jdt.internal.ui.text.JavaReconciler"
daemon
0x47a36c00 JavaThread " - Idle Thread" daemon
0x47af0800 JavaThread "Bundle File Closer" daemon
0x46400400 JavaThread "Worker-5"
0x47b40c00 JavaThread "Worker-4"
0x4636c800 JavaThread "Worker-3"
0x462bb800 JavaThread "Worker-2"
0x47c82800 JavaThread "Worker-1"
0x4636f800 JavaThread "Java indexing" daemon
0x4612e800 JavaThread "Worker-0"
0x455ea800 JavaThread " - Main Queue Handler" daemon
0x455db800 JavaThread "Framework Event Dispatcher" daemon
0x455eb400 JavaThread "Start Level Event Dispatcher" daemon
0x455c9800 JavaThread "State Data Manager" daemon
0x44cbac00 JavaThread "Low Memory Detector" daemon
0x44cb8000 JavaThread "CompilerThread0" daemon
0x44cb3400 JavaThread "Attach Listener" daemon
0x44cae000 JavaThread "Signal Dispatcher" daemon
0x44c9c400 JavaThread "Finalizer" daemon
0x44c97800 JavaThread "Reference Handler" daemon
=>0x00b56c00 JavaThread "main"
Other Threads:
0x44c92c00 VMThread
0x44cbcc00 WatcherThread [id=3828]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 18240K, used 14347K [0x02c10000, 0x03fd0000,
0x05370000)
eden space 16256K, 76% used [0x02c10000, 0x0382bc00, 0x03bf0000)
from space 1984K, 98% used [0x03de0000, 0x03fc7240, 0x03fd0000)
to space 1984K, 0% used [0x03bf0000, 0x03bf0000, 0x03de0000)
tenured generation total 241984K, used 30553K [0x05370000, 0x13fc0000,
0x22c10000)
the space 241984K, 12% used [0x05370000, 0x07146528, 0x07146600,
0x13fc0000)
compacting perm gen total 44800K, used 44558K [0x22c10000, 0x257d0000,
0x42c10000)
the space 44800K, 99% used [0x22c10000, 0x25793b50, 0x25793c00,
0x257d0000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x0040e000 E:\eclipse\galileo\eclipse\eclipse.exe
0x7c920000 - 0x7c9b6000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c91d000 C:\WINDOWS\system32\kernel32.dll
0x77d10000 - 0x77da0000 C:\WINDOWS\system32\USER32.dll
0x77ef0000 - 0x77f38000 C:\WINDOWS\system32\GDI32.dll
0x5d170000 - 0x5d20a000 C:\WINDOWS\system32\COMCTL32.dll
0x77da0000 - 0x77e49000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e50000 - 0x77ee1000 C:\WINDOWS\system32\RPCRT4.dll
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\MSVCRT.dll
0x76300000 - 0x7631d000 C:\WINDOWS\system32\IMM32.DLL
0x62c20000 - 0x62c29000 C:\WINDOWS\system32\LPK.DLL
0x73fa0000 - 0x7400b000 C:\WINDOWS\system32\USP10.dll
0x72000000 - 0x72014000
E:\eclipse\galileo\eclipse\plugins\org.eclipse.equinox.launc her.win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x5adc0000 - 0x5adf7000 C:\WINDOWS\system32\uxtheme.dll
0x74680000 - 0x746cb000 C:\WINDOWS\system32\MSCTF.dll
0x76d70000 - 0x76d92000 C:\WINDOWS\system32\apphelp.dll
0x73640000 - 0x7366e000 C:\WINDOWS\system32\msctfime.ime
0x76990000 - 0x76acd000 C:\WINDOWS\system32\ole32.dll
0x60800000 - 0x60809000 C:\WINDOWS\system32\mslbui.dll
0x6d800000 - 0x6da56000 D:\Program Files\Java\jre6\bin\client\jvm.dll
0x76b10000 - 0x76b3a000 C:\WINDOWS\system32\WINMM.dll
0x7c340000 - 0x7c396000 C:\WINDOWS\system32\MSVCR71.dll
0x6d280000 - 0x6d288000 D:\Program Files\Java\jre6\bin\hpi.dll
0x76bc0000 - 0x76bcb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d7b0000 - 0x6d7bc000 D:\Program Files\Java\jre6\bin\verify.dll
0x6d320000 - 0x6d33f000 D:\Program Files\Java\jre6\bin\java.dll
0x6d7f0000 - 0x6d7ff000 D:\Program Files\Java\jre6\bin\zip.dll
0x45730000 - 0x45758000 C:\WINDOWS\system32\rsaenh.dll
0x759d0000 - 0x75a7e000 C:\WINDOWS\system32\USERENV.dll
0x5fdd0000 - 0x5fe26000 C:\WINDOWS\system32\netapi32.dll
0x6d610000 - 0x6d623000 D:\Program Files\Java\jre6\bin\net.dll
0x71a20000 - 0x71a37000 C:\WINDOWS\system32\WS2_32.dll
0x71a10000 - 0x71a18000 C:\WINDOWS\system32\WS2HELP.dll
0x55600000 - 0x55631000 C:\Program Files\Microsoft Firewall Client
2004\FwcWsp.dll
0x770f0000 - 0x7717b000 C:\WINDOWS\system32\OLEAUT32.dll
0x719c0000 - 0x719fe000 C:\WINDOWS\System32\mswsock.dll
0x76ef0000 - 0x76f17000 C:\WINDOWS\system32\DNSAPI.dll
0x76f80000 - 0x76f88000 C:\WINDOWS\System32\winrnr.dll
0x76f30000 - 0x76f5c000 C:\WINDOWS\system32\WLDAP32.dll
0x45930000 - 0x45955000 C:\Program Files\Bonjour\mdnsNSP.dll
0x76d30000 - 0x76d48000 C:\WINDOWS\system32\Iphlpapi.dll
0x60fd0000 - 0x61025000 C:\WINDOWS\system32\hnetcfg.dll
0x71a00000 - 0x71a08000 C:\WINDOWS\System32\wshtcpip.dll
0x77f40000 - 0x77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
0x77180000 - 0x77283000
C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595 b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl32.dll
0x76f90000 - 0x76f96000 C:\WINDOWS\system32\rasadhlp.dll
0x6d630000 - 0x6d639000 D:\Program Files\Java\jre6\bin\nio.dll
0x46490000 - 0x464e9000
E:\eclipse\galileo\eclipse\configuration\org.eclipse.osgi\bu ndles\149\1\.cp\swt-win32-3550.dll
0x76320000 - 0x76367000 C:\WINDOWS\system32\comdlg32.dll
0x7d590000 - 0x7dd84000 C:\WINDOWS\system32\SHELL32.dll
0x76680000 - 0x76726000 C:\WINDOWS\system32\WININET.dll
0x765e0000 - 0x76672000 C:\WINDOWS\system32\CRYPT32.dll
0x76db0000 - 0x76dc2000 C:\WINDOWS\system32\MSASN1.dll
0x46500000 - 0x46514000
E:\eclipse\galileo\eclipse\configuration\org.eclipse.osgi\bu ndles\149\1\.cp\swt-gdip-win32-3550.dll
0x4ae90000 - 0x4b036000
C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144cc f1df_1.0.2600.3352_x-ww_81af8e88\gdiplus.dll
0x46560000 - 0x46568000
E:\eclipse\galileo\eclipse\configuration\org.eclipse.osgi\bu ndles\29\1\.cp\os\win32\x86\localfile_1_0_0.dll
0x74be0000 - 0x74c0c000 C:\WINDOWS\system32\oleacc.dll
0x75ff0000 - 0x76055000 C:\WINDOWS\system32\MSVCP60.dll
0x47150000 - 0x47699000 C:\WINDOWS\system32\xpsp2res.dll
0x76fa0000 - 0x7701f000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77020000 - 0x770ba000 C:\WINDOWS\system32\COMRes.dll
0x74cf0000 - 0x74d81000 C:\WINDOWS\system32\mlang.dll
0x46ce0000 - 0x46cef000
E:\eclipse\galileo\eclipse\configuration\org.eclipse.osgi\bu ndles\32\1\.cp\jWinHttp-1.0.0.dll
0x4a410000 - 0x4a468000 C:\WINDOWS\system32\WINHTTP.dll
0x76eb0000 - 0x76eec000 C:\WINDOWS\system32\RASAPI32.DLL
0x76e60000 - 0x76e72000 C:\WINDOWS\system32\rasman.dll
0x76e80000 - 0x76eaf000 C:\WINDOWS\system32\TAPI32.dll
0x76e50000 - 0x76e5e000 C:\WINDOWS\system32\rtutils.dll
0x762f0000 - 0x762f5000 C:\WINDOWS\system32\msimg32.dll
0x48f00000 - 0x48f07000 D:\Program Files\Internet Download
Manager\idmmkb.dll
0x48ec0000 - 0x48ecc000 D:\Program Files\Kingsoft\Powerword
2007\Grabgdip.dll
0x7e550000 - 0x7e6c1000 C:\WINDOWS\system32\shdocvw.dll
0x75430000 - 0x754a1000 C:\WINDOWS\system32\CRYPTUI.dll
0x76c00000 - 0x76c2e000 C:\WINDOWS\system32\WINTRUST.dll
0x76c60000 - 0x76c88000 C:\WINDOWS\system32\IMAGEHLP.dll
0x77fc0000 - 0x77fd1000 C:\WINDOWS\system32\Secur32.dll
0x75e00000 - 0x75eae000 C:\WINDOWS\system32\SXS.DLL
0x7c9c0000 - 0x7cc7e000 C:\WINDOWS\system32\msi.dll
0x75c60000 - 0x75d00000 C:\WINDOWS\system32\urlmon.dll
0x498e0000 - 0x4995c000 C:\WINDOWS\system32\shdoclc.dll
0x74650000 - 0x7467a000 C:\WINDOWS\system32\msimtf.dll
0x492b0000 - 0x492b2000 C:\Program Files\Common Files\Microsoft
Shared\INK\PENCHS.DLL
0x76060000 - 0x761b6000 C:\WINDOWS\system32\SETUPAPI.dll
0x72c90000 - 0x72c99000 C:\WINDOWS\system32\wdmaud.drv
0x72c80000 - 0x72c88000 C:\WINDOWS\system32\msacm32.drv
0x77bb0000 - 0x77bc5000 C:\WINDOWS\system32\MSACM32.dll
0x77ba0000 - 0x77ba7000 C:\WINDOWS\system32\midimap.dll
0x71a40000 - 0x71a4b000 C:\WINDOWS\system32\wsock32.dll
0x6c140000 - 0x6c176000 C:\WINDOWS\system32\dxtrans.dll
0x76af0000 - 0x76b01000 C:\WINDOWS\system32\ATL.DLL
0x6d7c0000 - 0x6d7ca000 C:\WINDOWS\system32\ddrawex.dll
0x736d0000 - 0x73719000 C:\WINDOWS\system32\DDRAW.dll
0x73b30000 - 0x73b36000 C:\WINDOWS\system32\DCIMAN32.dll
0x6c180000 - 0x6c1da000 C:\WINDOWS\system32\dxtmsft.dll
0x66b50000 - 0x66b5c000 C:\WINDOWS\system32\IMGUTIL.DLL
0x5e400000 - 0x5e40c000 C:\WINDOWS\system32\pngfilt.dll
0x7e210000 - 0x7e508000 C:\WINDOWS\system32\mshtml.dll
0x74620000 - 0x74647000 C:\WINDOWS\system32\msls31.dll
VM Arguments:
jvm_args: -Xms256m -Xmx512m -XX:MaxPermSize=512m
java_command: <unknown>
Launcher Type: generic
Environment Variables:
JAVA_HOME=D:\Program Files\Java\jdk1.6.0_11
PATH=D:/Program Files/Java/jre6/bin/client;D:/Program
Files/Java/jre6/bin;D:\JavaFX\javafx-sdk1.1\bin;D:\JavaFX\ja vafx-sdk1.1\emulator\bin;C:\Program
Files\PC Connectivity
Solution\;D:\php-5.2.4-Win32\;C:\WINDOWS\system32;C:\WINDOWS ;C:\WINDOWS\System32\Wbem;JRUBY_HOME\bin;E:\apache-ant-1.7.0 \bin;E:\java\grails-1.0.4\bin;D:\Program
Files\Subversion\bin;D:\Program Files\Java\jdk1.6.0_11\bin;C:\Program
Files\Common Files\Symbian\tools;i:\Program Files\CSL Arm
Toolchain\bin;E:\java\play-1.0-stable4;C:\Program Files\Common Files\Roxio
Shared\DLLShared\;C:\Program Files\Common Files\Roxio
Shared\9.0\DLLShared\;D:\Program Files\Mercurial;C:\Program Files\Common
Files\Thunder Network\KanKan\Codecs;D:\Program Files\Apache Software
Foundation\Apache2.2\htdocs\cakephp\cake\console;C:\Program
Files\StormII\Codec;C:\Program
Files\StormII;E:\java\android-sdk-windows-1.0_r2\tools;D:\Py thon25;D:\Google\google_appengine\
USERNAME=chengyf
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 6 Stepping 5, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 2
CPU:total 2 (2 cores per cpu, 1 threads per core) family 15 model 6
stepping 5, cmov, cx8, fxsr, mmx, sse, sse2, sse3
Memory: 4k page, physical 2097151k(2097151k free), swap 4194303k(4011420k
free)
vm_info: Java HotSpot(TM) Client VM (11.0-b16) for windows-x86 JRE
(1.6.0_11-b03), built on Nov 10 2008 02:15:12 by "java_re" with MS VC++ 7.1
time: Wed Jun 17 09:32:24 2009
elapsed time: 108 seconds
Current Time: Sat May 18 01:29:46 EDT 2013
Powered by FUDForum. Page generated in 0.01770 seconds
