Home » Eclipse Projects » IMP » incremental builder wizard failed
incremental builder wizard failed [message #573530] Thu, 16 October 2008 10:25
Defert Philippe is currently offline Defert Philippe
Member
I use eclipse 3.4.1 and IMP meta-tooling 0.1.80
eclipse.buildId=M20080911-1700
java.version=1.6.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86
When i try to use incremental builder wizard , nothing done in wizard dialog
i have this error in log:
java.lang.Exception: Cannot find schema source for schema/builders.exsd
org.eclipse.imp.wizards.ExtensionPointWizardPage.<init>(ExtensionPointWizardPage.java:110)
org.eclipse.imp.wizards.ExtensionPointWizardPage.<init>(ExtensionPointWizardPage.java:65)
org.eclipse.imp.wizards.NewBuilderWizardPage.<init>(NewBuilderWizardPage.java:31)
at org.eclipse.imp.wizards.NewBuilder.addPages(NewBuilder.java: 42)
org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(Wiz ardSelectionPage.java:113)
org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage .getNextPage(WorkbenchWizardSelectionPage.java:100)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:813)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
org.eclipse.ui.internal.handlers.WizardHandler$New.executeHa ndler(WizardHandler.java:253)
org.eclipse.ui.internal.handlers.WizardHandler.execute(Wizar dHandler.java:273)
org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:281)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:247)
org.eclipse.ui.internal.actions.CommandAction.runWithEvent(C ommandAction.java:157)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
Philippe
Previous Topic:New release available on update site on SourceForge
Next Topic:LPG editor failed after last update
Current Time: Wed May 22 04:47:00 EDT 2013
Powered by FUDForum. Page generated in 0.07520 seconds
