Home » Eclipse Projects » Dali » Persistence perspective
| Persistence perspective [message #573373] |
Wed, 22 February 2006 11:52 |
Originally posted by: jakieskonto1.wp.pl
I use Eclipse SDK 3.1.1 and java.version=1.5.0_06 under Win XP. I have
been trying to use EJB 3.0 Persistence. I did everything exacly with this
jsr220_tutorial.ZIP tutorial instrictions
I downloaded all necessary plug-ins:
* GEF-SDK-3.1.zip (Graphical Editor Framework)
* emf-sdo-xsd-SDK-2.1.0.zip (Eclipse Modeling Framework)
* wtp-wst-sdk-I20050809.zip (Eclipse Web Tools)
* JEM-SDK-1.1.zip (Java EMF Model Runtime)
but i still cann't get a Persistence perspective.
Configuration details:
*** Date: Wed Feb 22 17:44:34 CET 2006
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20050929-0840
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
D:\Programy\Java\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
b38_60
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1140624332375
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
D:\Programy\Java\eclipse\startup.jar
eof=eof
file.encoding=Cp1250
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=D:\Programy\Java\eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_06\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.5.0_06\lib\ext
java.home=C:\Program Files\Java\jre1.5.0_06
java.io.tmpdir=C:\WINDOWS\TEMP\
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32; C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System3 2\Wbem;C:\Program
Files\Intel\Wireless\Bin\;C:\Sun\AppServer\jdk\bin;D:\Progra my\JBoss\jboss-4.0.2;C:\Program
Files\Microsoft SQL Server\80\Tools\BINN;C:\Program Files\MySQL\MySQL
Server 5.0\bin;C:\Program
Files\QuickTime\QTSystem\;C:\Sun\AppServer\jdk\bin
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=J2SE-1.5
org.osgi.framework.language=pl
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=d:\Programy\Java\eclipse\configuration\org. eclipse.osgi\bundles
osgi.configuration.area=file:/d:/Programy/Java/eclipse/confi guration/
osgi.framework=file:/d:/Programy/Java/eclipse/plugins/org.ec lipse.osgi_3.1.1.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.1.1
osgi.install.area=file:/d:/Programy/Java/eclipse/
osgi.instance.area=file:/C:/Documents and Settings/Karol/workspace/
osgi.instance.area.default=file:/C:/Documents and Settings/Karol/workspace/
osgi.logfile=C:\Documents and Settings\Karol\workspace\.metadata\.log
osgi.manifest.cache=d:\Programy\Java\eclipse\configuration\o rg.eclipse.osgi\manifests
osgi.nl=pl_PL
osgi.os=win32
osgi.splashLocation=d:\Programy\Java\eclipse\plugins\org.ecl ipse.platform_3.1.1\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=d:\Programy\Java\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.5.0_06\lib\rt.jar;C:\Program
Files\Java\jre1.5.0_06\lib\i18n.jar;C:\Program
Files\Java\jre1.5.0_06\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jsse.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jce.jar;C:\Program
Files\Java\jre1.5.0_06\lib\charsets.jar;C:\Program
Files\Java\jre1.5.0_06\classes
sun.boot.library.path=C:\Program Files\Java\jre1.5.0_06\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386
i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1250
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=PL
user.dir=D:\Programy\Java\eclipse
user.home=C:\Documents and Settings\Karol
user.language=pl
user.name=Karol
user.timezone=Europe/Belgrade
user.variant=
*** Features:
org.eclipse.emf (2.1.1) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.1.1) "Eclipse Modeling Framework (EMF) Programmers
Guide"
org.eclipse.emf.ecore.sdo (2.1.1) "EMF Service Data Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.1.1) "EMF Service Data Objects (SDO)
Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.1.1) "EMF Service Data Objects (SDO)
Source"
org.eclipse.emf.examples (2.1.0) "Eclipse Modeling Framework (EMF)
Examples"
org.eclipse.emf.source (2.1.1) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.gef (3.1.1) "Graphical Editing Framework"
org.eclipse.gef.examples (3.1.1) "GEF Examples"
org.eclipse.gef.sdk (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.1.1) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.1) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0.1) "Java EMF Model"
org.eclipse.jem.sdk (1.1.0.1) "Java EMF Model SDK"
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source"
org.eclipse.pde (3.1.1) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.1) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.1) "Eclipse Platform"
org.eclipse.platform.source (3.1.1) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.rcp (3.1.1) "Eclipse RCP"
org.eclipse.rcp.source (3.1.1) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.1) "Eclipse Project SDK"
org.eclipse.sdk.examples (3.0.1) "Eclipse SDK Examples"
org.eclipse.ve (1.1.0.1) "Visual Editor"
org.eclipse.ve.sdk (1.1.0.1) "Visual Editor SDK"
org.eclipse.ve.source (1.1.0.1) "Visual Editor Source"
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.1.1) "XML Schema Infoset Model (XSD) Programmers
Guide"
org.eclipse.xsd.source (2.1.1) "XML Schema Infoset Model (XSD) Source"
org.springframework (1.0.2) "Spring Framework"
org.springframework.ide.eclipse (1.2.3) "Spring IDE"
org.springframework.ide.eclipse.beans (1.0.3) "Spring IDE - Beans
Configuration Support"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
de.byteaction.velocity.ui (2.0.2) "Veloeclipse" [Resolved]
net.sourceforge.hiberclipse (2.0.1) "HiberClipse" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.apache.xalan (2.6.0) "Apache Xalan Plug-in" [Resolved]
org.apache.xalan (1.5.0.M2) "Apache Xalan Plug-in" [Resolved]
org.apache.xerces (2.6.2) "pluginName" [Resolved]
org.eclipse.ant.core (3.1.1) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.1) "Ant UI" [Resolved]
org.eclipse.compare (3.1.1) "Compare Support" [Resolved]
org.eclipse.compare.examples (3.0.0) "Compare Example" [Resolved]
org.eclipse.compare.examples.xml (3.0.0) "XML Compare Support" [Resolved]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Management
Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32
org.eclipse.core.runtime (3.1.1) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.1) "Debug UI" [Active]
org.eclipse.draw2d (3.1.1) "Draw2d" [Resolved]
org.eclipse.draw2d (3.1.0) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.1.1) "Draw2D Documentation" [Resolved]
org.eclipse.emf (2.1.1) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.activities (2.1.0) "EMF Activities" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation"
[Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Resolved]
org.eclipse.emf.common (2.0.1) "EMF Common" [Resolved]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
Guide" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Resolved]
org.eclipse.emf.ecore (2.0.1) "EMF Ecore" [Installed]
org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"
[Resolved]
org.eclipse.emf.ecore.edit (2.1.1) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
[Resolved]
Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO)
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Resolved]
org.eclipse.emf.edit (2.1.1) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Resolved]
Examples" [Resolved]
org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.0) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.1) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.1.1) "EMF Rose Importer" [Resolved]
org.eclipse.emf.java (2.1.0) "EMF Java" [Resolved]
org.eclipse.emf.java.edit (2.1.0) "EMF Java Edit" [Resolved]
org.eclipse.emf.java.editor (2.1.0) "EMF Java Editor" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.1) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping
Editor" [Resolved]
[Resolved]
org.eclipse.gef (3.1.1) "Graphical Editing Framework" [Resolved]
org.eclipse.gef (3.1.0) "Graphical Editing Framework" [Installed]
org.eclipse.gef.doc.isv (3.1.1) "Graphical Editing Framework
org.eclipse.gef.examples.flow (3.1.1) "GEF Flow Editor Example" [Resolved]
org.eclipse.gef.examples.logic (3.1.1) "GEF Logic Editor Example"
[Resolved]
org.eclipse.gef.examples.shapes (3.1.1) "GEF Shape Editor Example"
[Resolved]
org.eclipse.gef.examples.source (3.1.1) "GEF Examples" [Resolved]
org.eclipse.gef.examples.text (3.1.1) "GEF Text Editor Example" [Resolved]
Resources" [Resolved]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
org.eclipse.help.examples.ex1 (3.0.0) "Online Help Sample" [Resolved]
org.eclipse.help.ui (3.1.1) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.1) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.1) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.1.1) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.1.1) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.1) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.1) "Java Development Tools JUnit support"
[Resolved]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit
runtime support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching
Support" [Active]
[Resolved]
org.eclipse.jdt.ui (3.1.1) "Java Development Tools UI" [Active]
org.eclipse.jdt.ui.examples.projects (3.0.1) "Java Development Tools
Example Projects" [Resolved]
org.eclipse.jem (1.1.0.1) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.1.0.1) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.1.0.1) "Java EMF Model Proxy Support" [Resolved]
org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK" [Resolved]
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source" [Resolved]
org.eclipse.jem.ui (1.1.0.1) "Java EMF Model UI" [Active]
org.eclipse.jem.util (1.1.0.1) "Java EMF Model Utilities" [Resolved]
org.eclipse.jem.workbench (1.1.0.1) "Java EMF Model Workbench Support"
[Resolved]
org.eclipse.jface (3.1.1) "JFace" [Active]
org.eclipse.jface.text (3.1.1) "JFace Text" [Active]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.1.1) "Refactoring UI" [Resolved]
org.eclipse.osgi.services (3.1.1) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.1) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
[Resolved]
org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.1) "Plug-in Development Core" [Resolved]
org.eclipse.pde.doc.user (3.1.1) "Eclipse Plug-in Development User Guide"
[Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.1) "Plug-in Development Environment Runtime"
[Resolved]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.1) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.1.1) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.1) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.1) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.win32.win32.x86 (3.1.1) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
[Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.1.1) "Eclipse RCP Plug-in
org.eclipse.sdk (3.1.1) "Eclipse Project SDK" [Resolved]
org.eclipse.sdk.examples (3.0.1) "Eclipse SDK Examples" [Resolved]
org.eclipse.sdk.examples.source (3.0.1) "Eclipse Platform Plug-in
org.eclipse.sdk.examples.source.win32.win32.x86 (3.0.1) "Eclipse Platform
org.eclipse.search (3.1.1) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.examples (3.0.0) "SWT Standalone Examples Plugin"
[Resolved]
org.eclipse.swt.examples.browser (3.0.0) "SWT Browser Example Plugin"
[Resolved]
org.eclipse.swt.examples.controls (3.0.0) "SWT Controls Example Plugin"
[Resolved]
org.eclipse.swt.examples.launcher (3.0.0) "SWT Launcher Example Plugin"
[Resolved]
org.eclipse.swt.examples.layouts (3.0.0) "SWT Layout Example Plugin"
[Resolved]
org.eclipse.swt.examples.ole.win32 (3.0.0) "SWT OLE Example Plugin
(Win32)" [Resolved]
org.eclipse.swt.examples.paint (3.0.0) "SWT Paint Example Plugin"
[Resolved]
org.eclipse.swt.win32.win32.x86 (3.1.1) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.1.1) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.1) "CVS Team Provider Core" [Active]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.1.1) "CVS Team Provider UI" [Active]
org.eclipse.team.examples.filesystem (3.0.0) "Eclipse Team File System
Example" [Active]
org.eclipse.team.ui (3.1.1) "Team Support UI" [Active]
org.eclipse.text (3.1.1) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.1.1) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.1) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.1.1) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.0) "Console" [Active]
org.eclipse.ui.editors (3.1.1) "Default Text Editor" [Active]
org.eclipse.ui.examples.javaeditor (3.0.0) "JFace Text Example" [Resolved]
org.eclipse.ui.examples.multipageeditor (2.1.0) "Multi-Page Editor
Example" [Resolved]
org.eclipse.ui.examples.propertysheet (2.1.0) "User File Editor" [Resolved]
org.eclipse.ui.examples.readmetool (2.1.0) "Readme File Editing Tool"
[Resolved]
org.eclipse.ui.externaltools (3.1.1) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.1.1) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.1) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.1) "Views" [Active]
org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.1.1) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.1) "Text Editor Framework"
[Active]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.1) "Install/Update Core" [Resolved]
org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.1) "Install/Update UI" [Resolved]
org.eclipse.ve (1.1.0) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.1.0.1) "Visual Editor Common Data Editor" [Resolved]
org.eclipse.ve.doc (1.1.0) "Visual Editor for Java User Guide" [Resolved]
org.eclipse.ve.java.core (1.1.0.1) "Visual Editor Java Core" [Resolved]
org.eclipse.ve.jfc (1.1.0.1) "Visual Editor for Java Foundation Classes"
[Resolved]
org.eclipse.ve.propertysheet (1.1.0.1) "Visual Editor PropertySheet"
[Resolved]
org.eclipse.ve.sdk (1.1.0) "Visual Editor SDK" [Resolved]
org.eclipse.ve.source (1.1.0.1) "Visual Editor Source" [Resolved]
org.eclipse.ve.swt (1.1.0.1) "Visual Editor for Standard Widget Toolkit"
[Resolved]
org.eclipse.wst.common.frameworks (1.0.0)
"org.eclipse.wst.common.frameworks" [Resolved]
org.eclipse.wst.common.frameworks.ui (1.0.0) "WTP UI Plug-in" [Resolved]
org.eclipse.wst.common.ui (1.0.0) "Eclipse Base UI extensions" [Resolved]
org.eclipse.wst.common.uriresolver (1.0.0)
"org.eclipse.wst.common.uriresolver" [Resolved]
org.eclipse.wst.dtd.core (1.0.0) "Structured Source DTD Core" [Resolved]
org.eclipse.wst.sse.core (1.0.0) "Structured Text Model" [Resolved]
org.eclipse.wst.sse.ui (1.0.0) "Structured Source Editor" [Resolved]
org.eclipse.wst.validation (1.0.0) "Validation Framework" [Resolved]
org.eclipse.wst.xml.core (1.0.0) "Structured Source XML Model" [Resolved]
org.eclipse.wst.xml.ui (1.0.0) "SSE XML Source Editor" [Resolved]
org.eclipse.wst.xml.uriresolver (1.0.0) "pluginName" [Resolved]
org.eclipse.wst.xml.uriresolver.ui (1.0.0) "XML Catalog UI" [Resolved]
org.eclipse.xsd (2.0.1) "XML Schema Infoset Model (XSD)" [Installed]
org.eclipse.xsd (2.1.0) "XML Schema Infoset Model (XSD)" [Installed]
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)" [Resolved]
Guide" [Resolved]
org.eclipse.xsd.ecore.importer (2.1.0) "XML Schema Importer for EMF"
[Resolved]
org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
org.eclipse.xsd.editor (2.1.0) "XML Schema Editor" [Resolved]
org.eclipse.xsd.example (2.1.0) "XML Schema Infoset Model Example"
[Resolved]
[Resolved]
org.hibernate.eclipse (3.0.0.alpha4) "Hibernate Core Plugin" [Resolved]
org.hibernate.eclipse.console (3.0.0.alpha4) "Hibernate Console" [Resolved]
org.hibernate.eclipse.help (3.0.0.alpha4) "Hibernate Help" [Resolved]
org.hibernate.eclipse.mapper (3.0.0.alpha4) "Mapper Plug-in" [Resolved]
org.jboss.ide.eclipse.core (1.4.1.e31-jre15) "JBoss Core Plug-in"
[Resolved]
org.jboss.ide.eclipse.core (1.5.0.M2) "JBoss Core Plug-in" [Active]
org.jboss.ide.eclipse.deployer.core (1.4.1.e31-jre15) "JBoss Deployer Core
Plug-in" [Resolved]
org.jboss.ide.eclipse.deployer.core (1.5.0.M2) "JBoss Deployer Core
Plug-in" [Active]
org.jboss.ide.eclipse.deployer.ui (1.4.1.e31-jre15) "JBoss Deployer UI
Plug-in" [Installed]
org.jboss.ide.eclipse.deployer.ui (1.5.0.M2) "JBoss Deployer UI Plug-in"
[Active]
org.jboss.ide.eclipse.jdt.aop.core (1.0.1) "JBoss AOP Core Plug-in"
[Installed]
org.jboss.ide.eclipse.jdt.aop.core (1.1.0.beta3) "JBoss AOP Core Plug-in"
[Resolved]
org.jboss.ide.eclipse.jdt.aop.ui (1.0.1) "JBoss AOP UI Plug-in" [Installed]
org.jboss.ide.eclipse.jdt.aop.ui (1.1.0.beta3) "JBoss AOP UI Plug-in"
[Resolved]
org.jboss.ide.eclipse.jdt.core (1.4.1.e31-jre15) "JBoss Development Core
Plug-in" [Resolved]
org.jboss.ide.eclipse.jdt.core (1.5.0.M2) "JBoss Development Core Plug-in"
[Active]
org.jboss.ide.eclipse.jdt.j2ee.core (1.4.1.e31-jre15) "JBoss Development
J2EE Core Plug-in" [Installed]
org.jboss.ide.eclipse.jdt.j2ee.core (1.5.0.M2) "JBoss Development J2EE
org.jboss.ide.eclipse.jdt.j2ee.jsp.core (1.4.1.e31-jre15) "JBoss
Development J2EE JSP Core Plug-in" [Installed]
org.jboss.ide.eclipse.jdt.j2ee.jsp.core (1.5.0.M2) "JBoss Development J2EE
JSP Core Plug-in" [Active]
org.jboss.ide.eclipse.jdt.j2ee.jsp.ui (1.4.1.e31-jre15) "JBoss Development
J2EE JSP UI Plug-in" [Installed]
org.jboss.ide.eclipse.jdt.j2ee.jsp.ui (1.5.0.M2) "JBoss Development J2EE
JSP UI Plug-in" [Active]
org.jboss.ide.eclipse.jdt.j2ee.ui (1.4.1.e31-jre15) "JBoss Development
J2EE UI Plug-in" [Installed]
org.jboss.ide.eclipse.jdt.j2ee.ui (1.5.0.M2) "JBoss Development J2EE UI
Plug-in" [Resolved]
org.jboss.ide.eclipse.jdt.j2ee.xml.core (1.4.1.e31-jre15) "JBoss
Development J2EE XML Core Plug-in" [Resolved]
org.jboss.ide.eclipse.jdt.j2ee.xml.core (1.5.0.M2) "JBoss Development J2EE
org.jboss.ide.eclipse.jdt.j2ee.xml.ui (1.4.1.e31-jre15) "JBoss Development
J2EE XML UI Plug-in" [Installed]
org.jboss.ide.eclipse.jdt.j2ee.xml.ui (1.5.0.M2) "JBoss Development J2EE
XML UI Plug-in" [Resolved]
org.jboss.ide.eclipse.jdt.test.core (1.4.1.e31-jre15) "JBoss Development
Test Core Plug-in" [Installed]
org.jboss.ide.eclipse.jdt.test.core (1.5.0.M2) "JBoss Development Test
org.jboss.ide.eclipse.jdt.test.ui (1.4.1.e31-jre15) "JBoss Development
Test UI Plug-in" [Installed]
org.jboss.ide.eclipse.jdt.test.ui (1.5.0.M2) "JBoss Development Test UI
Plug-in" [Resolved]
org.jboss.ide.eclipse.jdt.ui (1.4.1.e31-jre15) "JBoss Development UI
org.jboss.ide.eclipse.jdt.ui (1.5.0.M2) "JBoss Development UI Plug-in"
[Resolved]
org.jboss.ide.eclipse.jdt.ws.core (1.4.1.e31-jre15) "JBoss Development Web
Services Core Plug-in" [Installed]
org.jboss.ide.eclipse.jdt.ws.core (1.5.0.M2) "JBoss Development Web
Services Core Plug-in" [Active]
org.jboss.ide.eclipse.jdt.ws.ui (1.4.1.e31-jre15) "JBoss Development Web
Services UI Plug-in" [Installed]
org.jboss.ide.eclipse.jdt.ws.ui (1.5.0.M2) "JBoss Development Web Services
org.jboss.ide.eclipse.jdt.xml.core (1.4.1.e31-jre15) "JBoss Development
XML Core Plug-in" [Installed]
org.jboss.ide.eclipse.jdt.xml.core (1.5.0.M2) "JBoss Development XML Core
Plug-in" [Resolved]
org.jboss.ide.eclipse.jdt.xml.ui (1.4.1.e31-jre15) "JBoss Development XML
org.jboss.ide.eclipse.jdt.xml.ui (1.5.0.M2) "JBoss Development XML UI
Plug-in" [Resolved]
org.jboss.ide.eclipse.launcher.core (1.4.1.e31-jre15) "JBoss Launcher Core
org.jboss.ide.eclipse.launcher.core (1.5.0.M2) "JBoss Launcher Core
Plug-in" [Resolved]
org.jboss.ide.eclipse.launcher.ui (1.4.1.e31-jre15) "JBoss Launcher UI
org.jboss.ide.eclipse.launcher.ui (1.5.0.M2) "JBoss Launcher UI Plug-in"
[Resolved]
org.jboss.ide.eclipse.packaging.core (1.4.1.e31-jre15) "JBoss Packaging
org.jboss.ide.eclipse.packaging.core (1.5.0.M2) "JBoss Packaging Core
Plug-in" [Resolved]
org.jboss.ide.eclipse.packaging.ui (1.4.1.e31-jre15) "JBoss Packaging UI
org.jboss.ide.eclipse.packaging.ui (1.5.0.M2) "JBoss Packaging UI Plug-in"
[Resolved]
org.jboss.ide.eclipse.ui (1.4.1.e31-jre15) "JBoss UI Plug-in" [Installed]
org.jboss.ide.eclipse.ui (1.5.0.M2) "JBoss UI Plug-in" [Active]
org.jboss.ide.eclipse.xdoclet.assist (1.4.1.e31-jre15) "XDoclet Assist
org.jboss.ide.eclipse.xdoclet.assist (1.5.0.M2) "XDoclet Assist Plug-in"
[Resolved]
org.jboss.ide.eclipse.xdoclet.core (1.4.1.e31-jre15) "XDoclet Core
org.jboss.ide.eclipse.xdoclet.core (1.5.0.M2) "XDoclet Core Plug-in"
[Resolved]
org.jboss.ide.eclipse.xdoclet.run (1.4.1.e31-jre15) "XDoclet Runner
org.jboss.ide.eclipse.xdoclet.run (1.5.0.M2) "XDoclet Runner Plug-in"
[Active]
org.jboss.ide.eclipse.xdoclet.ui (1.4.1.e31-jre15) "XDoclet UI Plug-in"
[Resolved]
org.jboss.ide.eclipse.xdoclet.ui (1.5.0.M2) "XDoclet UI Plug-in" [Resolved]
org.jbpm.core (3.0.0) "JBoss jBPM Core" [Resolved]
org.jbpm.db (3.0.0) "Db Plug-in" [Resolved]
org.jbpm.help (3.0.0) "jBPM Help Plug-in" [Resolved]
org.jbpm.ui (3.0.0) "JBoss jBPM Designer Plug-in" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.springframework (1.0.2) "Spring Framework" [Resolved]
org.springframework.core (1.0.2) "Spring Framework Core" [Resolved]
org.springframework.doc.reference (1.0.2) "Spring Framework Reference
org.springframework.ide.eclipse (1.2.3) "Spring IDE" [Resolved]
Configuration Support" [Resolved]
org.springframework.ide.eclipse.beans.core (1.0.2) "Spring IDE - Beans
Configuration Support Core" [Installed]
org.springframework.ide.eclipse.beans.core (1.2.3) "Spring IDE Beans Core"
[Active]
org.springframework.ide.eclipse.beans.ui (1.0.3) "Spring IDE - Beans
Configuration Support UI" [Installed]
org.springframework.ide.eclipse.beans.ui (1.2.3) "Spring IDE Beans UI"
[Active]
org.springframework.ide.eclipse.beans.ui.doc (1.0.0) "Spring IDE - Beans
Configuration Support Documentation" [Installed]
org.springframework.ide.eclipse.beans.ui.doc (1.2.1) "Spring IDE Beans
org.springframework.ide.eclipse.beans.ui.editor (0.7.0) "Spring IDE Beans
Config Editor" [Resolved]
org.springframework.ide.eclipse.beans.ui.graph (1.0.0) "Spring IDE - Beans
Configuration Support Graph" [Installed]
org.springframework.ide.eclipse.beans.ui.graph (1.2.1) "Spring IDE Beans
Graph" [Resolved]
org.springframework.ide.eclipse.core (1.2.3) "Spring IDE Core" [Active]
org.springframework.ide.eclipse.core.doc (1.2.3) "Spring Framework
Reference Documentation" [Resolved]
org.springframework.ide.eclipse.ui (1.2.2) "Spring IDE UI" [Active]
system.bundle (3.1.1) "OSGi System Bundle" [Active]
*** User Preferences:
#Wed Feb 22 17:44:35 CET 2006
@org.eclipse.debug.ui=3.1.1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<templates/>
@org.eclipse.ui.ide=3.1.1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.packages.lin ktoeditor=true
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="0" javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api/"
name\="jdk"
path\="C\:\\Sun\\AppServer\\jdk"/>\r\n</vmType>\r\n</vmSettings >\r\n
@org.eclipse.pde.core=3.1.1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
/instance/org.eclipse.team.cvs.core/repositories/%pserver%wirp17@cvs.wirp.pl%2401%cvsroot/location=\:pserver\:wirp17@cvs.wirp.pl\:2401/cvsroot
/instance/org.eclipse.pde.runtime/activate=true
@org.eclipse.ui.browser=3.1.1
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
/instance/org.eclipse.team.core/file_types=oom\n2\nlck\n2\ns cript\n2\nxdoclet\n2\nrar\n2\noob\n2\npdm\n2\npdb\n2\npackag ing\n2\nspringBeans\n2\n
@org.eclipse.jdt.ui=3.1.1
/instance/org.eclipse.ui.examples.javaeditor/org.eclipse.ui. examples.templateeditor.customtemplates= <?xml
version\="1.0" encoding\="UTF-8"?><templates/>
/instance/org.eclipse.core.resources/version=1
@org.eclipse.core.resources=3.1.0
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.help.ui/browser.y=2
/instance/org.eclipse.help.ui/browser.x=44
/instance/org.eclipse.help.ui/browser.maximized=true
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.pde.core/platform_path=d\:\\Programy\\ Java\\eclipse
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
@org.eclipse.team.cvs.ui=3.1.1
/instance/org.eclipse.ant.ui/useAnnotationsPrefPage=true
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.ui.workbench=3.1.1
@org.eclipse.team.core=3.1.1
/instance/org.eclipse.ui.workbench/org.eclipse.jdt.ui.editor s.textfont=1|Courier
New|11|1|WINDOWS|1|-15|0|0|0|700|0|0|0|-18|3|2|1|49|Courier New;
file_export_version=3.0
@org.eclipse.jdt.launching=3.1.0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
@org.eclipse.pde.runtime=3.1.1
/instance/org.eclipse.help.ui/browser.h=768
/instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
@org.eclipse.wst.sse.ui=1.0.0
/instance/org.eclipse.ui.ide/platformState=357
/instance/org.eclipse.jdt.ui/Refactoring.savealleditors=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
/instance/org.eclipse.ui.browser/internalWebBrowserHistory=C \:\\Documents
and
Settings\\Karol\\workspace\\XMLExamples\\readme.html|*|file\ :/C\:/Documents
and Settings/Karol/workspace/XMLExamples/readme.html|*|
/instance/org.eclipse.ui.workbench/ColorsAndFontsPreferenceP age.selectedElement=Forg.eclipse.jdt.ui.PropertiesFileEditor .textfont
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant_sec_id=1133213042750
@org.eclipse.ui.editors=3.1.1
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Doc uments and
/instance/org.eclipse.pde.runtime/orderType=2
/instance/org.eclipse.team.cvs.ui/pref_first_startup=false
/instance/org.eclipse.ui.ide/quickStart=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=d\:/Programy/Java/eclipse/plugins/org.j unit_3.8.1
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAU NCH_PERSPECTIVES= <?xml
version\="1.0"
encoding\="UTF-8"?>\r\n<launchPerspectives>\r\n<launchPerspective
configurationType\=" org.jboss.ide.eclipse.launcher.configuration.jboss.JBoss40xL aunchConfigurationDelegate "
mode\="debug"
perspective\="perspective_none"/>\r\n</launchPerspectives >\r\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_LIB=C\:/Sun/AppServer/jdk/jre/lib/rt.jar
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=8
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.team.pessimistic.ui.decorator\:true,org.eclipse.jdt.ui .override.decorator\:true,org.eclipse.pde.ui.binaryProjectDe corator\:false,org.eclipse.team.cvs.ui.decorator\:true,org.e clipse.ui.LinkedResourceDecorator\:true,org.jboss.ide.eclips e.deployer.ui.decorators.DeployedDecorator\:true,org.jboss.i de.eclipse.jdt.j2ee.jsp.ui.decorators.JSPNatureDecorator\:tr ue,org.springframework.ide.eclipse.beans.ui.beansLabelDecora tor\:true,
@org.eclipse.jdt.core=3.1.1
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.ui.workbench/org.eclipse.jdt.ui.Proper tiesFileEditor.textfont=1|Courier
@org.eclipse.search=3.1.1
/instance/org.eclipse.ant.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.ui.workbench/ColorsAndFontsPreferenceP age.expandedCategories=Torg.eclipse.jdt.ui.presentation
/instance/org.eclipse.pde.runtime/orderValue=-1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRCROOT=
/instance/org.eclipse.ui.ide/tipsAndTricks=true
@org.eclipse.jdt.debug.ui=3.1.1
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<web-browsers
current\="0">\r\n<system/>\r\n<external location\="C\:\\Program
Files\\Mozilla Firefox\\firefox.exe" name\="Firefox"/>\r\n<external
location\="C\:\\Program Files\\Internet Explorer\\iexplore.exe"
name\="Internet Explorer"/>\r\n</web-browsers>
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/instance/org.eclipse.pde.runtime/column4=150
/instance/org.eclipse.pde.runtime/column3=229
@org.eclipse.team.ui=3.1.1
/instance/org.eclipse.pde.runtime/column2=810
/instance/org.eclipse.search/org.eclipse.search.defaultPersp ective=org.eclipse.search.defaultPerspective.none
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
@org.eclipse.ui.examples.javaeditor=3.0.0
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
@org.eclipse.ant.ui=3.1.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRC=
@org.eclipse.help.ui=3.1.1
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.views_to _not_open=org.eclipse.debug.ui.DebugView,
/instance/org.eclipse.jdt.ui/fontPropagated=true
/instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=d\:/Programy/Java/eclipse
@org.eclipse.ui=3.1.1
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant=org.eclipse.team.cvs.ui.cvsworkspace- participant
@org.eclipse.team.cvs.core=3.1.1
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ code_templates= <?xml
*** Current Install Configuration:
Install configuration:
Last changed on 2006-02-22
file:/d:/Programy/Java/eclipse/configuration/org.eclipse.upd ate/platform.xml
Configured sites:
platform:/base/
Configured features:
ID: org.jboss.ide.eclipse.aop.standalone, Version: 1.0.1
ID: org.eclipse.jdt.source, Version: 3.1.1
ID: org.eclipse.emf.ecore.sdo.source, Version: 2.1.1
ID: org.eclipse.sdk, Version: 3.1.1
ID: org.eclipse.pde.source, Version: 3.1.1
ID: org.eclipse.rcp.source, Version: 3.1.1
ID: org.springframework, Version: 1.0.2
ID: org.eclipse.emf.ecore.sdo.doc, Version: 2.1.1
ID: org.eclipse.gef.examples.source, Version: 3.1.1
ID: org.springframework.ide.eclipse.beans, Version: 1.0.3
ID: org.eclipse.platform, Version: 3.1.1
ID: net.sourceforge.hiberclipse.feature, Version: 2.0.1
ID: org.eclipse.emf.source, Version: 2.1.1
ID: org.eclipse.gef.source, Version: 3.1.1
ID: org.springframework.ide.eclipse, Version: 1.2.3
ID: org.jboss.ide.eclipse.aop, Version: 1.0.1
ID: org.eclipse.jdt, Version: 3.1.0
ID: org.eclipse.jem, Version: 1.1.0.1
ID: org.eclipse.ve.source, Version: 1.1.0.1
ID: org.jboss.ide.eclipse, Version: 1.4.1.e31-jre15
ID: org.eclipse.gef, Version: 3.1.1
ID: org.eclipse.sdk.examples, Version: 3.0.1
ID: org.eclipse.emf, Version: 2.1.1
ID: org.eclipse.jem.source, Version: 1.1.0.1
ID: org.eclipse.platform.source, Version: 3.1.1
ID: org.eclipse.rcp, Version: 3.1.0
ID: org.eclipse.ve.sdk, Version: 1.1.0
ID: org.eclipse.ve, Version: 1.1.0
ID: org.eclipse.emf.sdk, Version: 2.1.1
ID: org.eclipse.xsd.doc, Version: 2.1.1
ID: org.eclipse.xsd.source, Version: 2.1.1
ID: org.eclipse.pde, Version: 3.1.0
ID: org.eclipse.emf.doc, Version: 2.1.1
ID: org.eclipse.xsd, Version: 2.1.1
ID: org.eclipse.emf.ecore.sdo, Version: 2.1.1
ID: org.eclipse.jem.sdk, Version: 1.1.0
ID: org.eclipse.emf.examples, Version: 2.1.0
ID: de.byteaction.velocity, Version: 2.0.2
Configured plug-ins:
file:/d:/Programy/Java/eclipse/plugins/com.ibm.etools.emf.ev ent_3.0.0.1/
file:/d:/Programy/Java/eclipse/plugins/de.byteaction.velocit y.ui_2.0.2/
file:/d:/Programy/Java/eclipse/plugins/net.sourceforge.hiber clipse_2.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.apache.ant_1.6.5/
file:/d:/Programy/Java/eclipse/plugins/org.apache.lucene_1.4 .3/
file:/d:/Programy/Java/eclipse/plugins/org.apache.xalan_1.5. 0.M2/
file:/d:/Programy/Java/eclipse/plugins/org.apache.xalan_2.6. 0/
file:/d:/Programy/Java/eclipse/plugins/org.apache.xerces_2.6 .2/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ant.core_ 3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ant.ui_3. 1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.compare.e xamples.xml_3.0.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.compare.e xamples_3.0.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.compare_3 .1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.core.boot _3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.core.comm ands_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.core.expr essions_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.core.file buffers_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.core.reso urces.compatibility_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.core.reso urces.win32_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.core.reso urces_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.core.runt ime.compatibility_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.core.runt ime_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.core.vari ables_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.debug.cor e_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.debug.ui_ 3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.draw2d.do c.isv_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.draw2d_3. 1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.draw2d_3. 1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.activ ities_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ant_2 .1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.codeg en.ecore.ui_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.codeg en.ecore_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.codeg en.ui_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.codeg en_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.commo n.ui_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.commo nj.sdo_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.commo n_2.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.commo n_2.1.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.commo n_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.doc_2 .1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore .change.edit_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore .change_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore .editor_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore .edit_2.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore .sdo.doc_2.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore .sdo.editor_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore .sdo.edit_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore .sdo.source_2.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore .sdo_2.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore .xmi_2.1.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore .xmi_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore _2.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore _2.1.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.ecore _2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.edit. ui_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.edit_ 2.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.examp les_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.impor ter.ecore_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.impor ter.java_2.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.impor ter.rose_2.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.impor ter_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.java. editor_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.java. edit_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.java_ 2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.mappi ng.ecore2ecore.editor_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.mappi ng.ecore2ecore_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.mappi ng.ecore2xml.ui_2.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.mappi ng.ecore2xml_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.mappi ng.ui_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.mappi ng.xsd2ecore.editor_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.mappi ng.xsd2ecore_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.mappi ng_2.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf.sourc e_2.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.emf_2.1.1 .jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.gef.doc.i sv_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.gef.examp les.flow_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.gef.examp les.logic_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.gef.examp les.shapes_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.gef.examp les.source_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.gef.examp les.text_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.gef.sourc e_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.gef_3.1.0 .jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.gef_3.1.1 .jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.help.apps erver_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.help.base _3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.help.exam ples.ex1_3.0.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.help.ui_3 .1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.help.weba pp_3.1.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.help_3.1. 0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jdt.core_ 3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jdt.debug .ui_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jdt.debug _3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jdt.doc.i sv_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jdt.doc.u ser_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jdt.junit .runtime_3.1.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jdt.junit _3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jdt.launc hing_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jdt.sourc e_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jdt.ui.ex amples.projects_3.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jdt.ui_3. 1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jdt_3.1.0 .jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jem.beani nfo_1.1.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jem.proxy _1.1.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jem.sdk_1 .1.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jem.sourc e_1.1.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jem.ui_1. 1.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jem.util_ 1.1.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jem.workb ench_1.1.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jem_1.1.0 .1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jface.tex t_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.jface_3.1 .1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ltk.core. refactoring_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ltk.ui.re factoring_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.osgi.serv ices_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.osgi.util _3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.osgi_3.1. 1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.pde.build _3.1.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.pde.core_ 3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.pde.doc.u ser_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.pde.junit .runtime_3.1.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.pde.runti me_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.pde.sourc e_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.pde.ui_3. 1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.pde_3.1.0 .jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.platform. doc.isv_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.platform. doc.user_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.platform. source.win32.win32.x86_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.platform. source_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.platform_ 3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.rcp.sourc e.win32.win32.x86_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.rcp.sourc e_3.1.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.rcp_3.1.0 .jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.sdk.examp les.source.win32.win32.x86_3.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.sdk.examp les.source_3.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.sdk.examp les_3.0.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.sdk_3.1.1 /
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.search_3. 1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.swt.examp les.browser_3.0.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.swt.examp les.controls_3.0.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.swt.examp les.launcher_3.0.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.swt.examp les.layouts_3.0.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.swt.examp les.ole.win32_3.0.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.swt.examp les.paint_3.0.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.swt.examp les_3.0.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.swt.win32 .win32.x86_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.swt_3.1.0 .jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.team.core _3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.team.cvs. core_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.team.cvs. ssh2_3.1.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.team.cvs. ssh_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.team.cvs. ui_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.team.exam ples.filesystem_3.0.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.team.ui_3 .1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.text_3.1. 1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.tomcat_4. 1.30.1/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ui.browse r_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ui.cheats heets_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ui.consol e_3.1.0.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ui.editor s_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ui.exampl es.javaeditor_3.0.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ui.exampl es.multipageeditor_2.1.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ui.exampl es.propertysheet_2.1.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ui.exampl es.readmetool_2.1.0/
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ui.extern altools_3.1.1.jar
file:/d:/Programy/Java/eclipse/plugins/org.eclipse.ui.forms_ 3.1.0.jar
Current Time: Sun May 19 14:27:26 EDT 2013
Powered by FUDForum. Page generated in 0.01589 seconds
