Home » Eclipse Projects » EPP » Strawman package proposal for Java Developer
Strawman package proposal for Java Developer [message #573175] Wed, 14 February 2007 14:19
Wayne Beaton is currently offline Wayne Beaton
Java Developer
* Platform
* JDT
* Visual Editor (Swing only)
* Mylar
* XML Editor
No source code is required with this configuration.
Minimal prerequisites need to be included. If a plug-in is not required
by any of the above-listed components, it doesn't need to be included.
The configuration should specify reasonable "-Xmx" and "-XX:MaxPermSize"
values.
I'm not sure if the XML editor inclusion makes sense, or how much of the
web tools needs to be included to make the XML editor work.
At the end of the day, I am becoming less and less convinced that a Java
Developer package is really needed if there is a "Java Enterprise
Developer" package available.
I'm content with the Visual Editor only including Swing support in this
package. To be honest, the main motivation is that last time I checked,
including SWT support required the PDE be included.
Wayne
Previous Topic:Strawpack package proposal for Java Enterprise Developer
Next Topic:Straw man package proposal for Eclipse SDK Developer
Current Time: Tue May 21 00:02:55 EDT 2013
Powered by FUDForum. Page generated in 6.45156 seconds
