| Headless facet installation [message #548693] |
Thu, 22 July 2010 12:44  |
Konstantin Komissarchik Messages: 769 Registered: July 2009 |
Received by e-mail. Moving thread to the forum...
Hello Konstantin,
I have noticed that you wrote most of the facet stuff in the mentioned package. I try to create a new facet headless via WTP to a new project.
I add the nature with WtpUtils.addNatures(project); I like to create a dynamic web project with only a base facet like IJ2EEFacetConstants.DYNAMIC_WEB_24, but even trying 2 days, I fail.
Do you have a hint, how to do this with only a few lines?
Thank You in advance!
Barry
| Re: Headless facet installation [message #548700 is a reply to message #548693] |
Thu, 22 July 2010 13:00   |
Hi Barry,
You haven't indicated what you have tried or what failures you are getting. Note that the Dynamic Web Module facet (id jst.web) requires Java facet (id jst.java).
Here is a standalone snippet...
IProjectFacet javaFacet = ProjectFacetsManager.getProjectFacet( "jst.java" );
IProjectFacet webFacet = ProjectFacetsManager.getProjectFacet( "jst.web" );
Set<IProjectFacet> fixedFacets = new HashSet<IProjectFacet>();
fixedFacets.add( javaFacet );
fixedFacets.add( webFacet );
IFacetedProject fproj = ProjectFacetsManager.create( "my-project", null, null );
fproj.addTargetedRuntime( ..., null );
fproj.installProjectFacet( javaFacet.getVersion( "1.4" ) );
fproj.installProjectFacet( webFacet.getVersion( "2.4" ) );
fproj.setFixedProjectFacets( fixedFacets );
There are various versions of ProjectFacetsManager.create() method that are appropriate for different cases. There is no need to call WtpUtils.addNatures(). That's encapsulated in installation of the web facet.
You can substitute constants for appropriate IProjectFacet and IProjectFacetVersion objects from IJ2EEFacetConstants class.
Hope that helps. Let us know here if you have further questions.
- Konstantin
[Updated on: Thu, 22 July 2010 13:02] Report message to a moderator
| Re: Headless facet installation [message #572738 is a reply to message #572723] |
Mon, 26 July 2010 11:43  |
> it finally works, but how do I use
> ... how do I create a Runtime for this api call?
You can retrieve an IRuntime instance using RuntimeManager.getRuntime( name ) API. Note that the runtime must already be defined by the time you make this call.
Faceted project framework does not deal with actually defining runtimes. That's up to technologies that use the framework. For Java EE servers, you should use API in org.eclipse.wst.server.core plugin to define a runtime.
- Konstantin
FUDForum. Page generated in 0.03984 seconds
