Home » Eclipse Projects » DSDP » Tool for emdedded uCore
Tool for emdedded uCore [message #572710] Wed, 22 July 2009 05:30
Sebastien Rukin is currently offline Sebastien Rukin
I would like to use Eclipse as a framework for embedded micro-controller
IDE.
I already have the tool chain (based on gcc), and I think to have
understood that there is a way to create a micro-controller specific IDE
based on Eclipse. The problem is that I can not find any HowTo or tutorial
to start it.
The IDE should have the view of the internal registers of the core and the
memory of the micro-controller, that can be RAM or registers. In the case
of registers it should show the name of the registers and its bit
description.
At the end I would like that Eclipse is compiling the code and downloading
on the target. The target could be the real device, or a simulator (the
connection between the simulator and GDB is almost finished).
So I would like to know if there is some information around to do all that
and to package Eclipse such a way that the IDE is frozen enough, so that
changes on the description of the micro-controller is difficult or
impossible for a standard user.
Thank you in advance.
Seb.
Previous Topic:Re: openSolaris ? What is the story ?
Next Topic:Tool for emdedded uCore
Current Time: Wed May 29 01:57:03 EDT 2013
Powered by FUDForum. Page generated in 0.01611 seconds
