Home » Archived » IAM (Eclipse Integration for Apache Maven) » Disable Dependecy Path Update
Disable Dependecy Path Update [message #572353] Fri, 19 February 2010 12:33
Don Park is currently offline Don Park
Is there a way to disable automatic Maven dependency path update like the way one can disable automatic build? If not, could you add this feature?
Ideally, this feature should work at workspace level as well as per-project level. A menu command to *manually* update dependecy path will also be needed.
ISSUES I AM RUNNING INTO:
1. Unnecessary path updates.
After exiting Eclipse with workspace in working condition and nothing is changed, reopening the workspace still triggers path update. My expectation is that if a project's pom.xml file hasn't been changed, dependency path should not be updated yet it's happening.
2. Unreasonably slow path updates.
If the workspace is reopened within a few hours, path updates is *usually* fast (not always though). If the workspace is reopened much later (during which backup might have happened), path update is really slow even though workspace is configured to run Maven *offline* and with source download *disabled*.
3. Sporratic WTP related errors.
Often times, just switching to Servers tab or synching a deployed webapp triggers Eclipse errors. Restarting Eclipse (and waiting for everything to build which could take as much as 20 minutes in dependency path update) usually fixes this. I do have IAM Webtools support plugin installed.
Previous Topic:is the project dead?
Next Topic:File org.eclipse.wst.common.component modified
Current Time: Sat May 18 21:24:57 EDT 2013
Powered by FUDForum. Page generated in 0.01580 seconds
