| Problem running ETL using Epsilon/ANT [message #571846] |
Thu, 30 July 2009 17:04 |
Ali Gondal Messages: 13 Registered: July 2009 |
Junior Member |
Hi;
I'm trying to run my ETL rule using launch.xml (see below). There seems to
be a problem at:
'<epsilon.loadModel name="Ecore" type="EMF">'.
I think I am not sure how to specifiy URI based model and none of the
given examples do so. My etl works fine when I go through "Run
Configuration...".
<?xml version="1.0"?>
<project default="main">
<target name="init">
<property name="models" location="${basedir}/models"/>
<property name="metamodels" location="${basedir}/metamodels"/>
</target>
<target name="loadModels">
<epsilon.loadModel name="EM" type="EMF">
<parameter name="modelFile" value="${models}/car.ecore"/>
<parameter name="metamodelUri"
value="http://www.eclipse.org/emf/2002/Ecore"/>
<parameter name="isMetamodelFileBased" value="false"/>
<parameter name="readOnLoad" value="true"/>
<parameter name="storeOnDisposal" value="false"/>
</epsilon.loadModel>
<epsilon.loadModel name="FM" type="EMF">
<parameter name="modelFile" value="${models}/car.fmm"/>
<parameter name="metamodelFile" value="${metamodels}/fmm.ecore"/>
<parameter name="isMetamodelFileBased" value="true"/>
<parameter name="readOnLoad" value="false"/>
</target>
<target name="main" depends="init,loadModels">
<epsilon.etl src="${basedir}/fmm2ecore.etl">
<model ref="FM"/>
<model ref="EM"/>
<model ref="Ecore"/>
</epsilon.etl>
</target>
</project>
Any help would be great:)
cheers
--Ali
FUDForum. Page generated in 0.01580 seconds
