Home » Eclipse Projects » Service Oriented Architecture Tools Platform (STP) » Round 1 - Build System Proposal
Round 1 - Build System Proposal [message #571423] Wed, 18 January 2006 10:29
Adrian Skehill is currently offline Adrian Skehill
Member
--------------070903040009030801030905
This is something that I've put together to get the ball rolling on the
build system. It's based primarily on the build system that we've been
using to build our eclipse based plugins within IONA for the last year
or so.
The highlights of our build system are as follows:
* Ant based
* Provides a complete automated mechanism to build eclipse based
plugins as part of our product build cycle
* Does this build across UNIX based OS's (Linux) and Windows
* Leverages existing ant based build systems to build components that
are required by our tools
* Provides automated testing infrastructure, uses Eclipse unit test
infrastructure and interacts with Segues SilkTest for system level testing.
* Integrates with JCoverage to provide coverage figures on a regular basis
* Provide hooks for CruiseControl to do automated builds following
each update of the source base.
One of the bigger limitations of this system right now is that there is
no integration with CVS. We've built this within our own development
environment of ClearCase so I suspect we may have to do some work here
to get it to fully support CVS builds. I've only just started looking at
CVS in recent weeks, but I'm guessing that it should not be too much
work to get it up and running in this environment. Famous last words!
So I've attached a very rough diagram outlining our build system
(buildsytem.jpg). As you can see from this, we have one root build.xml
file, which includes a bunch of ant include files stored in the ant-inc
directory a few levels deeper. We've also created a number of ant tasks
specifically for build eclipse code which offer us the ability to parse
the MANIFEST.MF file to determine the correct build order, correct jar
names and plugin names so that the build artefact's are identical to
what is produced if using the Eclipse IDE. I was unable to get
ant4eclipse up and running with Eclipse 3.1 based (OSGI) plugins so went
a quick simple solution in this respect.
Evey plugin has a corresponding .tests fragment which obviously tests
the plugin. The test suite takes each plugin / fragment pair and kicks
off Eclipse to invoke those tests only. Eclipse is shutdown and
re-started for each plugin. When all plugins have been tested, a JUNIT
style report is produced.
In terms of how we bring in functionality from third party (that means
non IONA for now!) and IONA components, we created two special plugins
that are merely facade plugins. These plugins are auto generated using
XSLT which describes which jars are needed and brings the jars directly
into the plugins lib directory. Finally, the ant build system itself
needs to be bootstrapped to identify where the eclipse installation is
that can be used to build and test the plugins. At the moment we have a
staged copy of eclipse living within our development environment which
we use build the plugins. This contains full plugins for running on
Windows / Linux together with CDT and EMF plugins (all of which our
tools use). It also contains the eclipse automated testing plugins.
As an aside site.xml and feature.xml are also generated when required so
that any updates we need to do can be easily done.
When initially designing this build system, there were a few things that
I was striving for:
* I didn't want to have to exclusively maintain this, it should be
straightforward enough that every contributor could easily update it
when required.
* It was completely automated and could run reliably each night and
produce reports without any intervention.
* Integrated well with Eclipse so changes to plugins within the IDE
required as little as possible updates to the ant build system
* Was simple... darn said that already!
So in terms of improving this for the STP project I'd have the following
suggestions to make.
* Keep it nice and simple and stay with ant (I personally don't think
we should move to Maven to keep complexity down, but then again I've
only ever had fleeting glances at Maven in operation). But it probably
makes sense to leave this open to discussion.
* Keep the directory structure intact like as follows only allow
multiple components under the root (e.g. framework, service_creation)
each which would define their own set of plugins
* I'm not sure if we would need to have a build.xml present in each
directory or not, comments? Might make sense though.
* Shared components, i.e. access to the test suite, coverage etc.
would all be defined in the ant-inc directory.
Let me know what you think.
I'll be online at the IRC meeting later on this afternoon if anybody
needs to ask more detailed questions.
Adrian Skehill.
Artix UI Team Lead,
IONA Technologies.
Content-Type: image/jpeg;
name="buildsystem.jpg"
Content-Disposition: inline;
filename="buildsystem.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAQxAugDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3+iiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
ooAKKKKAObvLzXrrxVd6Xpd5ptpBa2VvcM11ZPOztK8y4G2ZAABCOx6mpPsf jD/oO6H/AOCa
b/5Kos/+Sh6z/wBgqw/9G3ddBQBz/wBj8Yf9B3Q//BNN/wDJVH2Pxh/0HdD/ APBNN/8AJVdB
RQBz/wBj8Yf9B3Q//BNN/wDJVH2Pxh/0HdD/APBNN/8AJVdBRQBz/wBj8Yf9 B3Q//BNN/wDJ
VH2Pxh/0HdD/APBNN/8AJVdBRQBz/wBj8Yf9B3Q//BNN/wDJVH2Pxh/0HdD/ APBNN/8AJVdB
VH2Pxh/0HdD/APBNN/8AJVdBRQBz/wBj8Yf9B3Q//BNN/wDJVU9SufFWjRW1 3cano1zA17a2
8kUelyxMVlnjiJDG4YAgPnoeldZXP+Mv+QHbf9hXTf8A0thoA6CiiigAoooo AKKKKAOfs/8A
koes/wDYKsP/AEbd10Fc/Z/8lD1n/sFWH/o27roKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACuf8Zf8gO2/ 7Cum/wDpbDXQ
Vz/jL/kB23/YV03/ANLYaAOgooooAKKKKACiiigDn7P/AJKHrP8A2CrD/wBG 3ddBXP2f/JQ9
Z/7BVh/6Nu66CgAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigArn/GX/IDtv+wrpv8A6Ww10Fc/4y/5Adt/2FdN /wDS2GgDoKKK
KACiiigAooooA5+z/wCSh6z/ANgqw/8ARt3XQVz9n/yUPWf+wVYf+jbuugoA KKKKACiiigAo
oooAKKKKACiiigAorm/EniS+0fU9PsLDTbe8lu4Z5iZ7toFRY2iHaN8k+aPT pWb/AMJb4k/6
F7Sf/BvJ/wDI1aRpTkrxREqsIuzZ21FcT/wlviT/AKF7Sf8Awbyf/I1H/CW+ JP8AoXtJ/wDB
vJ/8jVXsKnYn29PudtRXE/8ACW+JP+he0n/wbyf/ACNR/wAJb4k/6F7Sf/Bv J/8AI1HsKnYP
b0+521FcT/wlviT/AKF7Sf8Awbyf/I1H/CW+JP8AoXtJ/wDBvJ/8jUewqdg9 vT7nbUVxP/CW
+JP+he0n/wAG8n/yNR/wlviT/oXtJ/8ABvJ/8jUewqdg9vT7nbUVn6Fqf9t+ HtM1byfJ+3Wk
Vz5W7ds3oG25wM4zjOBWhWJqFFFFABRRRQAUUUUAFFFFABXP+Mv+QHbf9hXT f/S2Gugrn/GX
/IDtv+wrpv8A6Ww0AdBRRRQAUUUUAFFFFAHP2f8AyUPWf+wVYf8Ao27roK5+ z/5KHrP/AGCr
D/0bd10FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAcT4t/wCRz0L/ALB99/6Mtahq bxb/AMjnoX/Y
Pvv/AEZa1DXq4T+Gebiv4gUUUV0nMFFFFABRRRQAUUUUAbngT/knnhr/ALBV r/6KWugrn/An
/JPPDX/YKtf/AEUtdBXgnthRRRQAUUUUAFFFFABRRRQAVz/jL/kB23/YV03/ ANLYa6Cuf8Zf
8gO2/wCwrpv/AKWw0AdBRRRQAUUUUAFFFFAHP2f/ACUPWf8AsFWH/o27roK5 +z/5KHrP/YKs
P/Rt3XQUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBxPi3/kc9C/7B99/6Mtahqbxb /wAjnoX/AGD7
7/0Za1DXq4T+Gebiv4gUUUV0nMFFFFABRRRQAUUUUAbngT/knnhr/sFWv/op a6Cuf8Cf8k88
Nf8AYKtf/RS10FeCe2FFFFABRRRQAUUUUAFFFFABXP8AjL/kB23/AGFdN/8A S2Gugrn/ABl/
yA7b/sK6b/6Ww0AdBRRRQAUUUUAFFFFAHP2f/JQ9Z/7BVh/6Nu66Cufs/wDk oes/9gqw/wDR
t3XQUAFFFV76+t9Os5Lq6k8uFMAkKWJJICqqjJZiSAFAJJIABJoAsVhz+KLb 7RLbaXaXes3E
LlJksAhWFgcMrSuyxhwcZj3b+QduOaj/ALKvNe/ea6fKsW+aPS4mK8HjFw6t ibI6xj938zA+
bhWrcgghtbeK3t4o4YIkCRxxqFVFAwAAOAAOMUAYf/FYXf8A0A9L2/8AXa/8 zP8A342Y/wCB
Zz/Djk/4R7VP+hz1z/vzZf8AyPXQUUAc/wD8Ibpf/P1rn/g9vf8A49R/whul /wDP1rn/AIPb
3/49XQUUAc//AMIbpf8Az9a5/wCD29/+PUf8Ibpf/P1rn/g9vf8A49XQUUAc /wD8Ibpf/P1r
n/g9vf8A49R/whul/wDP1rn/AIPb3/49XQUUAc//AMIbpf8Az9a5/wCD29/+ PUf8Ibpf/P1r
n/g9vf8A49XQUUAc/wD8Ibpf/P1rn/g9vf8A49R/whul/wDP1rn/AIPb3/49 XQUUAc//AMIb
pf8Az9a5/wCD29/+PUf8Ibpf/P1rn/g9vf8A49XQUUAc/wD8Ibpf/P1rn/g9 vf8A49R/whul
/wDP1rn/AIPb3/49XQUUAc//AMIbpf8Az9a5/wCD29/+PUf8Ibpf/P1rn/g9 vf8A49XQUUAc
/wD8Ibpf/P1rn/g9vf8A49R/whul/wDP1rn/AIPb3/49XQUUAc//AMIbpf8A z9a5/wCD29/+
PUf8Ibpf/P1rn/g9vf8A49XQUUAc/wD8Ibpf/P1rn/g9vf8A49R/whul/wDP 1rn/AIPb3/49
XQUUAc//AMInFB82nazrllMeDJ/aD3WV9Ntz5qDnHIUNxjOCQT+w9bg/eW3i 2+lmH3Uv7S2k
hPruWKOJzx0w684zkZB6CigDn/t3iXTvlvNIg1WMcCbTJVikYnnJhmYKijkZ EzEnBwATt0NM
1vTtY81bK43TQ4863kRopoc52+ZE4DpkAkbgMjkZFaFZ+p6Hpes+UdRsILiS HJgmZP3kBOMt
G4+aNuAdykEEAg5AoA0KK59Jrzw/eWtrd3P2vSrmUW9vNID51sxBKLLISRIr EbFY4bcY1PmM
5YdBQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFABRRRQBxPi3/kc9C/7B99/wCjLWoam8W/8jnoX/YPvv8A0Za1DXq4 T+Gebiv4gUUU
V0nMFFFFABRRRQAUUUUAbngT/knnhr/sFWv/AKKWugrn/An/ACTzw1/2CrX/ ANFLXQV4J7YU
UUUAFFFFABRRRQAUUUUAFc/4y/5Adt/2FdN/9LYa6Cuf8Zf8gO2/7Cum/wDp bDQB0FFFFABR
RRQAUUUUAc/Z/wDJQ9Z/7BVh/wCjbuugrn7P/koes/8AYKsP/Rt3XQUAFc/o n/E/8jxFc/NC
+59Mh/gjhOQs3vJIh3ZIBRX2AA+YXPGnz+Gntm5hvLu0sp1/vwzXEcUi57ZR 2GRyM5BBwa6C
gDyDw54YvfGOoeKLy68ZeKrP7Nr93aRQWWpMkaRqwKgKQcY3Y44wBW/4C1HU LHVvFfh7VtWk
1C20OWFob+6Yb/LkjLlXbvtxyT6muY8JeCm8R3/i+8HijxHpYXxJexeRpt95 MZwwO4rg/Nzj
PoBWDqMF34c8H/EjwvHcfaFsruyka9l4llS4ZS3msOW44J9CaAPX9D+IXhTx Hqj6ZpOtQXN4
oJ8oKy7gOu0sAG/DNcj4e8XWOtfFvXzJ4ivVtbCJY7Oyw8dsVEeZnkBUDKvn BJHHTIqPU9J8
VtfeFm1T/hDtNtrLU4PsrWks6yMOQYY8pj5lyMdOB6VjeOJJ44/ir5DBd8+l JISSAEaOMNkj
nGDg+xNAHpeh/ELwp4j1R9M0nWoLm8UE+UFZdwHXaWADfhmp08a+HZNXXSV1 NDfvdSWawbH3
GVFDMOnQBh83TnGc1w2p6T4ra+8LNqn/AAh2m21lqcH2VrSWdZGHIMMeUx8y 5GOnA9K1fAGm
2p1nxtqi2sT3/wDbs8KysoLBVRCAD25Y0AbV98R/CGm67/Yt3rttFf7wjRkM VVvRnA2qfYkV
d1rxj4f8O3DQavqUdpKtuboh0Y5jDBMggcncwG0c+1eQeF9P8Vaj8IpkWHwm NJvYriS7ub6W
YTbtzb5JCFIDKQcHttFdRounpc/Enwr/AGhJBe3Fn4UEq3CEsjyeYieYpIB5 DMQcDrQB32h+
JtG8R6UdU0nUIrmyUlWlGV2EDJDBgCvHPIHFZ2jfELwn4h1d9K0rWoLm9UE+ WqsN2Ou0kAN6
/KTXmviwvYWPxcjssxIZLAsIxjAkRPNOPcMxNei6vpvhq2j8OCTy7eS1uFXR xDxuk2HCDA+6
R17cDJoAdffEfwhpuu/2Ld67bRX+8I0ZDFVb0ZwNqn2JFTeIfHvhfwrdR2ut avFa3Ei7li2O
7bfUhQcD3OK8n8L6f4q1H4RTIsPhMaTexXEl3c30swm3bm3ySEKQGUg4PbaK 3NGsPEWmX1zq
OgT6H4jnm06xj1SzkmZJNywAKY5CMbXX5vmA69KAPWLO8ttQs4byznjntpkD xyxtlWU9CDWH
4g8e+F/C15Haazq0Vtcuu8RBHkYL6kIDtHucUz4fXOlXngXTJ9EsXsbBlfZa u5YxMJGDrkkk
jeG/D06VzlxLdv8AEfxBH4T0TT5NTWG3TVNQ1O5cRjcmURUUE/dAJxgHv60A dnc+J9FtNLst
Tm1CIWN7LHDb3C5ZHaQ4XkA4B9TgDviqOi+P/C3iKe7h0nWIbqW0QyTIqOCF HVhkDcPdc9R6
15ZYWsN/8E/BFjcqksFx4ijhkUfdZDdygge2K7vXreG3+LfgmSGNI2ktb+Ji gxlFRCq/QEnA
oAd8OvHcHjB9bi+1ieW21CbyALdo8Wu7ERJIAzjPHX1Fatpe2Nr4n8TzPrVz MbaC3kubKRXM
dkoRyGTsd4BJ2/3Rms34af6jxT/2Mt//AOhismQ48VfFM+ml2n/pPNQB0Vt8 S/B13qlnpsGu
27Xd4kbwR7XG7eAVBJGAxBHykg84xmr3iPxn4e8JJC2u6pFaGbPloVZ3bHUh VBOPfGK851jT
LOy/Zy0l7e3jR0g066VgvIleSIs+fU725966TQI4rr4yeMZrtVe4tbayhtC4 yUhaNmfb7F+t
AEmp6+uoeMvAM2k6k0umag96X8iUiOcLASNw74YdD0I9a6W28S6Rd+G5fEMF 3v0qKOWV5/Lc
YWMsHO0jdwUbtzjjNefR22hWnjzwbD4fl32i6pqvmKCdscvkHei5A+UH04qP QZo4f2btTaR1
UfYtTTk/xNLMAPxJH50Ad5q/jXw5oOkWmqanqkdtZ3iq1uzIxaQEAghAC3Qj txnmsLwh4hj1
Xxf4zuk1Q3GkxfYpbZ2mJiiRrcMxXJwoJyT0561j+HI45viL4XF0qssPg+KS 0DjhZS6hyv8A
tbcfhXLeJoo7Cx+K8WliOOFrzTxJtOFAfb5ucdBlmB+poA9X0P4heFPEeqPp mk61Bc3ignyg
rLuA67SwAb8M1J4619PDXgrVdSM5gmS2kW2cRl/3xU+XwAf4scnj1ridT0nx W194WbVP+EO0
22stTg+ytaSzrIw5BhjymPmXIx04HpXceO/+SeeJf+wVdf8AopqAOR+Gl9YX lxpskXi/V9Uv
ZNJaSazvTKVLGVd8gLAD5WOwdTg8Eir3gfxTbad8KrLWvEmrFUE1wr3N1Izs 2LiQKMnJY4AA
AzwPaqHhf/kofh3/ALEpP/RsVcVpC6pcaf8ADe102LTpZPP1WaKPUS4gaVZn wTtBO4AsV460
Ae1eH/Fug+KbKW80XUorqGE4lIBQx/7ysAR36jtVDS/iP4Q1rWRpGna5bz3p JCxhWAcjrtYg
K34E1yA0jVpPFWvzeJtQ8Paebzw7LFdJpkspcR7sC4cOo+6C4zn0FRWkl9o8 XhLTfFGjaXqO
jrd20Wk6tpkzJ5cpGIWaM4PPfB2+oNAHrM8EN1by29xFHNBKhSSORQyupGCC DwQRxisPT/8A
iS+IRoUf/IPuLRrqxjHP2fy3VZYx6R/vYii84+cfKoRR0Fc/4u/dWOm3qcXF tqtn5T/3fNmW
B+OhzHNIvPTdkYIBAB0FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUVhzzza7cS2NjLJDp8TmO7vImKtIwOGhhYcgg 5DyD7vKr8+5o
gDmfEOpQ3/jvTI7dZHjt7G+ja4wPLaQS2wdFOckqRhjjAJ25LKwWaneJoIbX xX4et7eKOGCL
TL1I441Cqih7UAADgADjFc74y+3/ANg/6DqcGmKZkFzdyybPLh/iKnH3ugH1 r1MK7UbnnYhX
q2Ogorz3wfq0J8ZXGk6br95rGmmwNx5l25kZJVkCkK5AyMNWVZ2uu3vgS68R N4l1KKezFzLb
RpL8jLG7k+YDkuTggZOAAOK09tpov6Rn7LXVnpNzq1taatY6bLv+0XokaHC8 fuwC2T26irF3
LJBZzzQwmaWONmSIHBcgZC59+lefapaf2t4w8HahLfX0Bu7SWZkgnKrHtjRs KOwbOG9QBW2f
Guia9o+rpompNLcwWUsuVikjKYU4ILAc5x0pqpq0/l9wnT2t/Wp0ljPLdafb XE9u1tNLEryQ
McmNiASpPfB4/CrFeaWp1fWtS8OWEes3ttDceHo57uSOU725TLAnIDkkDdgn BPrUqa7qPhfR
/FttLeTahJpDxC0nujuc+cq7Qx/iwWFJVe60/wCBcbpdj0aiuNsfDniDSdR0 69TXr3UTI+3U
YLqUGLaQctGuPlwccDrXZVpFt7qxnJJbO5ueBP8Aknnhr/sFWv8A6KWugrn/ AAJ/yTzw1/2C
rX/0UtdBXhnshRRRQAUUUUAFFFFABRRRQAVz/jL/AJAdt/2FdN/9LYa6Cuf8 Zf8AIDtv+wrp
v/pbDQB0FFFFABRRRQAUUUUAc/Z/8lD1n/sFWH/o27roK5+z/wCSh6z/ANgq w/8ARt3XQUAc
/wCMv+QHbf8AYV03/wBLYa6Cuf8AGX/IDtv+wrpv/pbDXQUAZGg+HbTw6NTF pJO/9o38uoS+
cwO2STG4LgDC8cZyfeqw8HaS2peIbydJLj+3o4o72CUgx7Y0KDaAARkHnk89 MVs/bbUXwsft
MP2wxecLfzB5hjzjft67ckDPTNT0AcZonwz0fRdVtr832r6g1mCLKLULwzR2 uRj92uBjjjnN
a3/CI6W97r9xcJJcLrqxreQykFMJH5YC4AI49zz0xW7RQBxmifDPR9F1W2vz favqDWYIsotQ
vDNHa5GP3a4GOOOc1vaLoFroT6m1rJM51G+e+m81gdsjhQQuAML8o65PvWrR QBwt58J9AvNQ
uJjdatDZXU3n3OlwXhS0mcnJLR47n0IrpF8O2SeJ4tfRpUuYrA6ekSkCIRlw /TGc5UDrjHat
aoLy9tdPtWur25htrdCA0s0gRFJIAyTxySB9TQBlJ4T0z7fr91MslwNcWNby GUgx7Uj8sBQA
CMr1yTz0xWRoXw00fQdWttRW91W+ezVksor+7MsdoCMERrgY445zXZ1BZ3tr qFqt1ZXMNzbu
SFlhkDoSCQcEccEEfUUAcZefCfQLzULiY3WrQ2V1N59zpcF4UtJnJyS0eO59 CKta58OdK1nU
zqMV/q2k3EkSwTnS7ryBPGowquMEEAcduK7CigClpGk2WhaTbaXp0IhtLZAk SA5wPr3J6k+9
c/rHw80nWdel1d7zVLWS5jWK8hs7sxRXarwBKAMnjjgjiutooA4+z+HGkWGl 2umQ3eofY7TV
E1S2iaVSIXVtwjX5eI8knHXk81t32gWt/wCIdJ1qWSYXOmLOsKqw2MJVVW3D GTwoxgj8a1ag
vL21060ku725htraMZeaeQIijOOWPA5oAx9D8J23h/V9Wv7S9vWTU52uZLSW QGGORjlmQYyC
T15NObwnYPf+ILwzXPma5bx29yAy4RURkBTjg4c9c84rdooA5698HaffeCYP Cks10LCGG3hW
RWXzSsJQrk7cZOwZ49elV/EngPTfEmoxakb3U9N1COIwm70y58iR4852McHI zXU0UAczZeBN
G02Tw+1ks8K6GZjbIrghzKhVzJkEknJPBHP5Vj3Pwh8PXMl+pvNXSxvTI7ae l3i2SRwQZFjI
xuBORnIBA44rvqKAOW1fwDper6bpVq11qFpPpUYjtL6zn8q4jXaFI3AY5AGe PypmjfDrQdFt
tYto1uLm31dEW7jupN4fahUnOActksSSeTkYrrKKAOM0T4Z6Pouq21+b7V9Q azBFlFqF4Zo7
XIx+7XAxxxzmun1bTYdZ0a+0u4aRYL23kt5GjIDBXUqSMgjOD6GrlFAGDYeE 7DTtZstUhluW
ntNLGlxq7KVMQZWycDO7KjnOPas5vhxoj+E7Tw80l75NnM9xa3SzBLiGRnZy yuoGDlyOnTH1
roYda0q5+y+RqdnL9rLrbeXOrecUzvCYPzbcHOOmDmr1AHM6D4F0nQob8GS8 1K41BPLu7rUp
/OlmTBGwtgfLgngCs7SPhdoukalZ3Yv9YvIbF99lZXl6Zbe1bGAUTHGAeMk4 rt6KACuf8Zf8
gO2/7Cum/wDpbDXQVz/jL/kB23/YV03/ANLYaAOgooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKw555tduJbGxlkh0+JzHd 3kTFWkYHDQws
OQQch5B93lV+fc0QATzza7cS2NjLJDp8TmO7vImKtIwOGhhYcgg5DyD7vKr8 +5otiCCG1t4r
e3ijhgiQJHHGoVUUDAAA4AA4xRBBDa28VvbxRwwRIEjjjUKqKBgAAcAAcYqS gDifFv8AyOeh
f9g++/8ARlrXKeNtJvdW0q0+wW8d1LaXsV0bWVgq3CrnKEnjnPfjiur8W/8A I56F/wBg++/9
GWtQ16eGjzUbM87EPlq3OI0608SP44tdavdIgt7SWxezMMVyrG1G4OGY8biS MYXpkVLpmh6l
b/C670aW226hJbXiLDvU5aRpCoznHO4d+9dlRW6ppdTF1GzirrS9XtbrwdeW +nfajp0D291E
JlUpvjRd2TwQCp6V0mrWPnaJqFvawJ501tJGgUBdxKkAZ+taNFUoJX8xObdj jfD+h6lY63ot
xcW2yG28PJZStvU7ZgyErgHnhTyOPeo77wpd6tc+MoJlEMGqfZjazFgQWjjH JAOQA6jr+Fdt
RU+yja39dh+0d7nG2J8Y6nqWnR6nZx6ZaWbeZczQ3Qc3jAEABRyqknJBrsqK KqMeXrcmUr9D
c8Cf8k88Nf8AYKtf/RS10Fc/4E/5J54a/wCwVa/+ilroK8M9kKKKKACiiigA ooooAKKKKACu
f8Zf8gO2/wCwrpv/AKWw10Fc/wCMv+QHbf8AYV03/wBLYaAOgooooAKKKKAC iiigDn7P/koe
s/8AYKsP/Rt3XQVz9n/yUPWf+wVYf+jbuugoA5/xl/yA7b/sK6b/AOlsNdBX P+Mv+QHbf9hX
Tf8A0throKAOFuZY4Pjck0rhI4/DErOzHAUC5Qkmqtn8UpZ5rO9ufDN7aeG7 6cW9tq8kyncW
OFZ4vvIhPRie4qv4qsp9S+JGpWFt/wAfFz4Mu4Yv95plA/U1z2q+JdJ134Ma V4Y065ifXLuO
009LBT++hljdA5ZOqhdhOSMdKAO+8ReNLvTtcGh6DoE+u6qsIuJ4kuEgSCMn ALO3G484Ws2b
4pwvo+kSadot1d6zqdxLax6W0ixtHLF/rQ7ngBeOcdCOnOK9rrGneF/i14r/ ALdvILCPVLaz
uLOa5cIjpGhR1DHjIbnHXmsvVfGp1ZPDxsbhfDOk6xf3gfVCqBmSMfKwLjCG U55PPHU0Addo
3jLUNXtdatv+Edkt/EGlbPN0yS6Qq+9SybZgNuCAeccYrlPh/wCMLjQ/g9Y6 hrGnzMFYW9iI
5hLLfu7sFAXqp3ZGDngZp/wwuNN/4T/xlDZa1caosiWRiuruYSSXAVZA7KcD coJC5Ax09q5W
Pybr4I+C7gX80NtpeqRvqE1lIPNtELyLv6HaV3qeR3oA9M0jx3dvqx0zxP4f m8P3D273Vu0l
yk8c0acv8yjhlByV9K4fxz48vfEPw/umk8MXllpF/NbjT9QkmVvOxOjfNGOY wVViCcg/iKbe
6Pomtauun6N4s17xLqf9mXrRO1/FPBa+ZA0Y3lUGCxcAAHOQM1D4j8Y6De/A 7S9Kgu4W1Ly7
K3ezU/vYHieMPvXqoG0jJxnI9aAPda8v034hWWj+F/DTad4ZkSDVri8hhsra beySI74Ayo3b
3HOcBdxPOK9QrxHwaAyfC5SAR9t1g8+3nUAeheFvGN1rWr32i6vocui6taRp Obd51mWSJiQG
V14PIwf/ANeJfF/jA+GZNMsrTTJdU1XVJWitLSOQR79oBYs54UAEfnWcn/Jd J/8AsWo//Sl6
h+Ims3Nlq/hvS01ddEs9RmnFzqZVN0QRAVRWf5VLk4z7UAX9I8by31jrwv8A RpdO1XRI/Mur
J51kBBQuhWRRghgp5xxWHbfFi6lstM1e48J3lv4fvDFG+pG4UiKR8A/u8Big Y7d/GcZA5Arn
fDNzpq6j8TYrLWrjVFfTYWiuruYSSXASGYOynA3KCQuQMdPatXxCoX9m/TAA B/oGln8fMgoA
urqmuf8AC+pbYaRm0/shIy/21cCHzmPn7cdd2V29eM5rpPiHf2WmeAtWvNR0 1NStIo1Mlo8m
wSjeoxuwcckHp2rIluIIfjo0U1wkL3HhtI4gzhS7faHOFz1OOcCuc8b+DJ/D Xw18TXEvifXd
WEtqiCLUroyon71DuA7HjFAHYeJPHNxonii28P2WhT6ne3dm1xbrDME3OHC7 WJGFXG5ixPbG
Oaq2vxNtl8O6rf6vpVzp+o6XcLa3GmhhLI0r48tUIwG3Z4PsT05qSUBvjlbZ AJXw5KR7f6Sg
rgvFebfxl4k1RkZrTS/EOjXt3tXO2FbfDNjvgsD+FAHoXh/xtqF94gTRNf8A Dc+h3k8DXFpv
uUnWdFI3DKj5WGQdv+TpeMfFcHhDRUvpLWW7mnuEtba2iIDTSvnauT06Hn2q na+NNE1rxfZa
VpH2bVXW2kuZb23kV1tF4AGRnlicYyDxzVf4ma1d6LoFg1pdpY/a9SgtJr94 w4tI3zulw3HG
MZPTNAFjw54wvdT16fQdb0CXRtUjthdpEblLhJYd20sHUAZDEAj3rDb4qXQt xrK+FLxvCpm8
v+1/tKZ279nmeT97ZnvnpWN4Tn0uH41mO28TXOtl9DkiN3dXCyBpfORjHGVA U4XnC5xz71iL
rlhoGhDV/BviW5srr7X5Z8JXsiTZcy7WiWP78fUnIz9aAPaPEmrS6D4a1HV4 rT7W1lA0/keZ
s3hRk/Ng44yelYGofEO1std8K6aloZU1+PzBMJceQpC7DjB3bi2Oo/Gutu7a K9s57SYbop42
jceqsMH+dfPulpdXvhPVtTmRjeeEYLOzi46Pa3DySf8AjgWgD1W++Idtpx19 prCWSLTLuGxt
/JffJeXDoG8tVwMEFgOp7mnaB41v73Xk0XxB4cn0K+uIWntA9yk6TquNwDL0 YZBK+led6tZN
cfDfRvEU1xd2ltdeJDq97cWpxJBDK7qsinBxtUx9jW5otr4en+ImiDT/ABZr viW8tYp7gO99
FcW9qpTYd5VBy27AAOcgZoAyfBn/ADS3/r71n/2tXrPibxBaeFvDl7rd8Ha3 tEDMqDLMSQqg
e5JA/GvJvBn/ADS3/r71n/2tXpHxE1m70DwDq2p2CI1zBGuwum8JudVLkd9o Jb8KAM/RPHep
Xeu6fpWveF59FfU4nksJDdJOJdi7mVtoBRtvODVbU/iPqFvdapJpPhK71TSd JleG+vkuo49r
IMyBIzy+38OlclDc6XB8U/Bbr40uPEE26586ea4QwQl4GCKoQBVZj/Dknge1 Gs6jo+mXfinV
NF8V3XhrWbO7mafS7mVHivJQMh1hbk+ZxyPXpQB7LYXsGpada39sxaC5iSaM kYJVgCP0NY/j
L/kB23/YV03/ANLYa0dEu7m/0DTry9h8i6uLWKWaLGNjsoLLz6EkVneMv+QH bf8AYV03/wBL
YaAOgooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAoor
Dnnm124lsbGWSHT4nMd3eRMVaRgcNDCw5BByHkH3eVX59zRABPPNrtxLY2Ms kOnxOY7u8iYq
0jA4aGFhyCDkPIPu8qvz7mi2IIIbW3it7eKOGCJAkccahVRQMAADgADjFEEE NrbxW9vFHDBE
gSOONQqooGAABwABxipKACiiigDifFv/ACOehf8AYPvv/RlrUNTeLf8Akc9C /wCwfff+jLWo
a9XCfwzzcV/ECiiiuk5gooooAKKKKACiiigDc8Cf8k88Nf8AYKtf/RS10Fc/ 4E/5J54a/wCw
Va/+ilroK8E9sKKKKACiiigAooooAKKKKACuf8Zf8gO2/wCwrpv/AKWw10Fc /wCMv+QHbf8A
YV03/wBLYaAOgooooAKKKKACiiigDn7P/koes/8AYKsP/Rt3XQVz9n/yUPWf +wVYf+jbuugo
A5/xl/yA7b/sK6b/AOlsNdBXP+Mv+QHbf9hXTf8A0throKAIPsVqb4X32aH7 YIvJFx5Y8wR5
zs3dduQDjpmoItF0qHUn1KLTLOO/kGHukgUSt9Xxk/nV6qk+qWVrqVnp01wq Xd4JDbxHOZAg
BbH0BH50AN1HR9M1iNI9T060vY0O5FuYFkCn1AYHFLd6RpuoWK2N7p9pc2iY 2wTQq8Yx0wpG
OKreHNftfE+hQavZRzR28zSKqzKA4KOyHIBI6qe/StWgCnDpOm292l3Dp9pH cpD5CTJCodY/
7gYDIX26U200XStPiuYrPTbS3jumLzpFCqiVj1LADnPvV6igClp2jaXo6Omm abZ2KyHLrbQL
EGPqdoGagk8N6FNNczS6Lpzy3WPPdrVCZcEMNxx82CAee4BrUooAKow6LpVt 9l8jTLOL7IXa
28uBV8kvneUwPl3ZOcdcnNXqqWGqWWqC4NlcLMLa4e2m25+SVDhlPuDQBJ9i tRfG++zQ/bDF
5JuPLHmGPOdm7rtyScdM0y/0yw1W2+zajZW15BkN5VxEsi5HQ4YEZqudZhHi VdD+z3PntZm8
8/YPK2hwm3dnO7JzjHTvWlQBQ/sPSfN83+y7LzDb/Zd/2dM+T/zzzj7n+z0q STS9Pm01dNls
LV7BFRFtWhUxBVwVATGMDAxxxgVbrK1DX7XTdd0fSJo5muNVaVYGRQUUxpvb cScjgcYB5oAs
3Gk6dd39tf3NhbTXltnyJ5IlZ4s9drEZH4VLeWVrqNpJaXttDc20gw8M8YdG Gc8qeDzU9FAE
H2K1N8L77ND9sERhFx5Y8wR5zs3dduQDjpmmrp9kk11MtnbrLd4Fy4iUNNgb RvOPmwOOe1U9
P1+11LXdY0iGOZbjSmhWdnUBGMib12kHJ4POQOa1aAKWnaNpejpImmabZ2Sy Hc4toFjDH1O0
DNT3dpbX9rJa3lvFcW8gw8UyB0Ye4PBpt9ewabp9zfXT+Xb20TTSvjO1FBJP 5A1z+keObPWF
0ZotL1aBdXeVbdri2CBVjTfvb5uFYfdIzn2oA2ItC0e3a0aHSrGNrPcLUpbo DBu67MD5c98Y
o/sHRxqn9pjSbH+0P+fr7Onm/wDfeM/rUXhzX7XxPoUGr2Uc0dvM0iqsygOC jshyASOqnv0r
VoAKpppOmxw3cKafarFeMz3SLCoWdmGGLjHzEjgk5zVyigCGOztYrJbKO2hS 0WMRLAqAIEAx
tC9MY4xUGnaNpejo6aZptnYrIcuttAsQY+p2gZq7WVrmv2ugJp7XUczi+vob GLylBxJIcKTk
j5fXGT7GgCeHRdKtvsvkaZZxfZC7W3lwKvkl87ymB8u7Jzjrk5q5JHHNE8Uq K8bgqyMMhgeo
I7inVm6DrMPiDRodTgt7m3jlZ1EdygSQbXZDkAnqVyOehFADY/DehQ28VvFo umpDDMJ4o1tU
CpIOjqMYDe45qS60HR72+jvrvSbG4vI8bLiW3R5Fx0wxGRUXiTX7Xwv4evNa vY5pLa1UM6wK
C5BYLwCQOp9a1aACuf8AGX/IDtv+wrpv/pbDXQVz/jL/AJAdt/2FdN/9LYaA OgooooAKKKKA
CiiigAooooAKKK5a+8bx2mr32nQ6Fqt61lIsUssBtwm5o0kwN8qk/K69qai5 OyQm0tWdTRXI
f8J3J/0Kmuf992n/AMfo/wCE7k/6FTXP++7T/wCP1fsqn8r+4n2sO6OvorkP +E7k/wChU1z/
AL7tP/j9H/Cdyf8AQqa5/wB92n/x+j2VT+V/cHtYd0dfRXIf8J3J/wBCprn/ AH3af/H6P+E7
k/6FTXP++7T/AOP0eyqfyv7g9rDujr6K5D/hO5P+hU1z/vu0/wDj9H/Cdyf9 Cprn/fdp/wDH
6PZVP5X9we1h3R19FcgPHyLPbJceHdZto57iK3E0htiqNI6xqTtmJxuYdAa6 +olFx0asUpKW
qYUUUUhhRRWPfX1xe3kmlaVJ5cyYF3eBQwtAQCFUHIaYgghTkKCHYEFEkAI9 Snm1S/XR7CWR
I0cf2ncRMUMUZQkRI45ErEoTjlYyWyjNGTsQQQ2tvFb28UcMESBI441CqigY AAHAAHGKjsbG
306zjtbWPy4UyQCxYkkkszMclmJJJYkkkkkkmrFABRRRQAUUUUAcT4t/5HPQ v+wfff8Aoy1q
GpvFv/I56F/2D77/ANGWtQ16uE/hnm4r+IFFFFdJzBRRRQAUUUUAFFFFAG54 E/5J54a/7BVr
/wCilroK5/wJ/wAk88Nf9gq1/wDRS10FeCe2FFFFABRRRQAUUUUAFFFFABXP +Mv+QHbf9hXT
f/S2Gugrn/GX/IDtv+wrpv8A6Ww0AdBRRRQAUUUUAFFFFAHP2f8AyUPWf+wV Yf8Ao27roK5+
z/5KHrP/AGCrD/0bd10FAHP+Mv8AkB23/YV03/0throK5/xl/wAgO2/7Cum/ +lsNdBQB5J/w
kfjjVdAvvHWl6jZxaNbPLJb6Q9qGNzbxMQzNL95WIViAOOlSeIF1HXPiT4C1 PTdde1tb60uJ
7ZPssb+Uvlxs4yeu9WA5+7jIqjF/wkvh/wAHX3w7tvDOo3Vy/n2tjqUaD7IY JWYh3kz8rKHP
y47CtzWdPn8NeIPh48NhfX1lpcE9hK9pAZChaKNEZgOi/KcntQByXhaTxtZ/ C2TXNK1ezstP
0n7XNHZPaCU3ipLI7l3Jyn8SgL/d6811ev8AjW/1DU9I0fSdZsPD5u9NTU7m /vAj+Wj8JGiu
QrMTnOewpNB0vUIfgFqGmy2F0l+9jqSratCwlLM8xUBMZycjHHORWVqPh9tM vvDviHUfCMni
CxOhw2F3ZrZrPPbSrhlcRv16lT6Y/MAkm8d61beB/GER1izvNY0IRNDqlmiF J45MFW28qGGG
BHTj8a9A8LxeIRZz3HiK6t3nuJPNit4I8LaoQMR7urEdya841PR7+/8Ahp4v nsvB0OjrfCJL
DTrWwVLp0Vly0qxjJJJJC9gD9a9koA8+8R3Hi+fxLeRwa9ZeGNCtYUMF5cQx S/bJCMsPnb5V
Xp2P1zxlz+PNfvPhb4b1/T/IGq32pw2rxqo8ub968ZXkHaH2dRyM8VHrtg8P xM1a81bwZeeI
47mC3XR3WBZYINqkOrljtjy/O4jp+tDRtM1hPh74W0mfRb+G90vxRCblTbNt 2faHkMinvGA4
+bpwaAOksbzxfonjax0PXNct9Tg1m1uHt5YrJYTayxgEgAE7lww+9yfbvB8I 7HVLY+J3vdZa
9jGt3cTRm2SPdMr/ADy5X+9/d6DtW34gsrqb4meDbuK2mktreK/E0yxkpEWj jC7m6DJBxnri
qnw9NzZap4r0u7069t3/ALZub2OeWEiGWOV8qUfoxwOR2oAdr/iHVLHxte6f b3Wy0i8M3F+k
flqcTrIFV8kZ4B6dPauWXxB4+sPB2j+N77WLSSxdbX7TpYs1BkikKp5vmDkO xYNgAKM+3O94
n02/n8ealcwWVzLA3hG6t1kSJmVpTKCIwQMFiOQvWq+vaXqE3wC0/TYrC6e/ Sx01WtVhYyhl
eEsCmM5GDnjjBoAvaxqXiXxD4zvvDvhrVYNHh0qCKS8vXtVuHaSQEpGqtxja Mk9ayI7vW7rx
h8P18RWyw6nBd6lBK6LtScLAwWRR6MMH86vajNqfgrx/rOtR6DqWsaZrcMBY 6bF5ssM0SlAC
uR8pXBzUFrB4n1DxL4G1TXLKVZhdahNLHHFlbKJ4WESOyjAOMDJ5JOOtAF3R fEur3fwTvvEM
93v1WKzv5Un8tBho3lCHaBt4CL25xzmq1zr3ibXbvw74e0XVItPvbnR01S/1 GS2WYhTtUBUO
FyzE59ulc3HP4l0n4c6x4Fi8J6rLfpHeol4sObaSF2dyyuOWchiAgGScVuPB qvhbUPDPiiLR
NQ1GAaFHpd/a2kW64hI2urCM4J+bcCO1AGVpniTUvClx8SdY1dIJ9TtJLKL5 Bsjmk8oRxtj+
ENlWI7ZPpV+y8U67omt6M2qeMdG1621O6Szns7SONGtHk+6yFTl1DYBLev5Z 3/CO6/4wsviE
brR5tPutRksriyiukwr+WgZUJPyk4VVbnAJIPSr+kxQ6vrmkw6Z8L4NDkt51 m1C9v9KijSNV
52wMBlmLYww6dcegB2HxKt7u4+HOvi0vTaMljNJIwiV/MjEbFo+em4cZHIzk Vzeg32t6Ofhz
pU2rm7g1KGcz5t40zGttvjTgfwnHIwT3rsvGkE114F8Q29vFJNPLplykccal mdjEwAAHJJPG
K5Yabf8A9sfDB/sVzssraZbpvKbEBNptAfj5fm45xzxQBy+geJ7zSPh34V0X TL6y0+91W5vv
9OvceXbRRzyFmwSAWOQADwa39F8Z6ppl5rmlahrFl4mls9LfVLS8s0RDKEyG idUJAbO3GOx/
LnLTwrfW/g/whq954Yk1QaVcX6Xukz2waV4ppnIdY3HJGFYDuD+NdP4Ztrq7 vNX1TQvBln4a
gWwaCw+16dHb3M1wedzheVjBCjaevX6AEHhbVPGepnSNat/Eul69ZXckf2/T beCKL7Cjjkq+
7cSh6q3J9K7jxbLqMHhDV59JnMGoQ2sksDhFbDKNwGGBBzjHI715bZWFxrHi Xw7PY+BtQ8P6
7aXccurah9nFvbPGoPmqpU4k3ngcZ569a9qZVdSrAFWGCD3FAHlmo/EDUzr/ AIGNlMq6df20
M+pLsU7hcFY4+SMrh93Qj3rL8Za1rGpfaLmBkuIrLxfZWmm2zqFXzIlG7LAZ IaQ45zjHFVNH
8Ia2ngvxhBPY3IvLDZa6XuibdMlrK80ZjGMsGLADHXFbY0PU18CeDvM0+5N/ L4ittSvoxExe
LzJmkcuMZUKGAJOMY5oA19MvvFegeOtM0bxBrVvq9trFvPJE0dmsBt5IgrFR g/MuG6nn+uTp
/jXxHqPg3wxaWlzC/iHXru7hW7miXbDFDJJufYoAJCKoA7966fxBZXU3xM8G 3cVtNJbW8V+J
pljJSItHGF3N0GSDjPXFcPpOia5pHhLwZr8Oj3c93od3f/adO8spO0E8sgJV WwSQNrAd80AP
8b/8JZYeAvFuk+IrpdVtltIZ7XVEtlg3EyqGjZV4BGARjt+m22peNfD+t6Bf a3qtpc2Gs3q2
cumxWoT7G8isybZPvPjbgk/lzxl+Kr3xR4y8GeKpU0PUrPTGtYYbDT7i1xdT yiQM8hQZYADA
A/Guu8e2V1eTeEza2004g8QW803lRlvLjCSAu2OijI5PHNAHYVz/AIy/5Adt /wBhXTf/AEth
roK5/wAZf8gO2/7Cum/+lsNAHQUUUUAFFFFABRRRQAUUUUAFedf8zX4p/wCw hF/6R29ei151
/wAzX4p/7CEX/pHb104T+Ic+K/hlmiiivVPMCiiigAooooAKKKKAM7WP9Vp/ /YV0/wD9K4q9
NrzLWP8AVaf/ANhXT/8A0rir02vMxv8AEXoejhPgfqFFFY99fXF7eSaVpUnl zJgXd4FDC0BA
IVQchpiCCFOQoIdgQUSTkOoL6+uL28k0rSpPLmTAu7wKGFoCAQqg5DTEEEKc hQQ7AgokmhY2
Nvp1nHa2sflwpkgFixJJJZmY5LMSSSxJJJJJJNFjY2+nWcdrax+XCmSAWLEk klmZjksxJJLE
kkkkkk1YoAKKKKACiiigAooooA4nxb/yOehf9g++/wDRlrUNTeLf+Rz0L/sH 33/oy1qGvVwn
8M83FfxAooorpOYKKKKACiiigAooooA3PAn/ACTzw1/2CrX/ANFLXQVz/gT/ AJJ54a/7BVr/
AOilroK8E9sKKKKACiiigAooooAKKKKACuf8Zf8AIDtv+wrpv/pbDXQVz/jL /kB23/YV03/0
thoA6CiiigAooooAKKKKAOfs/wDkoes/9gqw/wDRt3XQVz9n/wAlD1n/ALBV h/6Nu66CgDn/
ABl/yA7b/sK6b/6Ww10Fc/4y/wCQHbf9hXTf/S2GrniXUptG8K6vqlusbT2V lNcRrICVLIhY
A4IOMj1FAGpRVDRL2TUtA06/mVFlubWKZwgIUMygnGe3NX6ACis3WJNXjWy/ siG2lZryJbrz
yfltyf3jLgj5gOnX6Gs7wnr91rsviBbqOFBp2rzWMPlKRujRUILZJy3zHpge 1AHR0Vzmr6/d
WHjfw3osUcLW2qJdtMzqS6mJEZdpzgcsc5B/CujoAKKK4PxT4/m0nS/GDafZ x/bPD4t8NcZa
OUyhW6Ag8BsdaAO8ooooAKKKKACiiigAooooAKKr3zXS6fctYpG92ImMCyfd L4O0H2zim6Y1
6+lWb6lHFHftAhuUh+4su0bwvJ4znHJoAtUUUUAFFc5q+v3Vh438N6LFHC1t qiXbTM6kupiR
GXac4HLHOQfwro6ACiiigAoorL8S6lNo3hXV9Ut1jaeyspriNZASpZELAHBB xkeooA1KKoaH
eyanoGm38yostzaxTOEBChmQE4z25rL8ea/deF/BOp61ZRwyXNqisizqShJd V5AIPQ+tAHR0
UUUAFc/4y/5Adt/2FdN/9LYa6Cuf8Zf8gO2/7Cum/wDpbDQB0FFFFABRRRQA UUUUAFFFFABX
nX/M1+Kf+whF/wCkdvXotedf8zX4p/7CEX/pHb104T+Ic+K/hlmiiivVPMCi iigAooooAKKK
KAM7WP8AVaf/ANhXT/8A0rir02vMtY/1Wn/9hXT/AP0rirtb6+uL28k0rSpP LmTAu7wKGFoC
AQqg5DTEEEKchQQ7AgoknmY3+IvQ9HCfA/UL6+uL28k0rSpPLmTAu7wKGFoC AQqg5DTEEEKc
hQQ7AgokmhY2Nvp1nHa2sflwpkgFixJJJZmY5LMSSSxJJJJJJNFjY2+nWcdr ax+XCmSAWLEk
klmZjksxJJLEkkkkkk1YrkOoKKKKACiiigAooooAKKKKAM/U9C0fW/K/tbSr G/8AJz5f2u3S
XZnGcbgcZwOnoKz/APhBPB//AEKmh/8Aguh/+JroKKAOf/4QTwf/ANCpof8A 4Lof/iaP+EE8
H/8AQqaH/wCC6H/4mugooA5//hBPB/8A0Kmh/wDguh/+Jo/4QTwf/wBCpof/ AILof/ia6Cig
Dn/+EE8H/wDQqaH/AOC6H/4mj/hBPB//AEKmh/8Aguh/+JroKKAOf/4QTwf/ ANCpof8A4Lof
/iaP+EE8H/8AQqaH/wCC6H/4mugooAjgghtbeK3t4o4YIkCRxxqFVFAwAAOA AOMVJRRQAUUU
UAFFFFABRRRQAUUUUAFc/wCMv+QHbf8AYV03/wBLYa6Cuf8AGX/IDtv+wrpv /pbDQB0FFFFA
BRRRQAUUUUAc/Z/8lD1n/sFWH/o27roK5+z/AOSh6z/2CrD/ANG3ddBQBz/j L/kB23/YV03/
ANLYaPHf/JPPEv8A2Crr/wBFNR4y/wCQHbf9hXTf/S2GrniXTZtZ8K6vpdu0 az3tlNbxtISF
DOhUE4BOMn0NAHkmo+FLbwn8ONN8cWdzdnxFZQ2lxLctcOROjFFaErnbs2tg AAdBXceG/wDk
q/jr/rjpv/ouSsa38CeMLzT9M8Oa5rGmTeG7JoWfyY3+03Cx4KxOT8u0EAbh yQB3rV1fwz4r
tfGN7rvhXUNKjXU4IobyLUY3bYY8hXTZ1OCeDgf0AOL/AOXD/upX/teluZ7k 6Xr2lW9xLbLr
Pjs6dNNE211idEL4PYkLj8a6DT/hxq9lolrYSX9tcSweKE1hpndsyQq4Jz8v +sIHTpnvVyX4
e3t1o3iC2e9ht72611tY064iy3kOAmzcCBzlSCBng9aAMhfCOn+Efi14Pt9I M0WnzQXzLavM
0ixyCNdzKWJI3ArkZx8tdf8AEjWbvQfh7q+oWD+XdpGscUg6o0jrGGHuN2fw rF0/wp4xu/HO
i+JPEWoaS/2GO4ha2sRIqKroArLuGSxOd2SAAFxmuw8R6FbeJfDt/o12SsN3 EYyy9UPUMPcE
A/hQB53eeFbP4cat4X1PRZ7vzr3UotN1LzZ3cXglBHmMCSNwYZGMVyXirwzo 1gPipc21ksc1
qLMQsHY7BKqPJ1Pduefwr0PT/CPi3UdY0iXxbqum3Nho0nnWyWUbh7mYKVWS XdwCAScLxk1R
8U+AvEerX/i+PT59LFh4ggtzuuHkWSKWIKoHCkbSFJz16UAV9U8J2vgvXfCe s2Fxdtq19q0V
lqNzLcO/2tZEcsWUnHVcgAAD8BXN3E2leK9e8QXniLQ/FmqTQahNaWEmmW0r w2ccZ2goUIG/
OWOc9q9Z8WaBda7L4fa1khQadq8N9N5rEbo0VwQuAct8w64HvWBceFfGOjat qreENT0mLTtV
uGupY9QicvbTMAHePbw2cZw3Gf1AOUlt9X8TWfw2sdZk1Cwv5pL6C5eRDFcG NImUk7hkF4x1
/wBrNew6Vplto2lWum2SsttaxiKJWYsQo6cnrXLQ+Cruz1DwY8V99ph0P7Sb qa5djLO0sRXc
OD/ExOCeB612tAHz/p1nJoHwlu/GVvd3bas7T2VltYlbWOS7KNsUfxZ3Nnrk j0q5pdtaaL4i
0K78K+GvGdreNeRw6nNf2c3l3MD/ACu8hJIBBIbIAAwa7vTfALt8K38H6tcR iWTziZrYlgjN
O0qMMgEkEqe3IP1qPT/D3jm/1TTT4n1rTf7P06UTKumrIkl46ghTKTgAc5Kr wf5AGJpnhiDx
1rPijXdRubpdSsNUmsNLkjnZBZCEAKyqDgkscnIIP41leDP+Pb4Q/TUf/RL1 1l94Q8VWWs6s
fDGrada6XrUvnXa3UbtLbSFQrvDt4JIAPzd653wr4c1XWPhh4I1XQbu1t9X0 kyywC8VjDIrl
0dW28jI7j/69AGp4o/5KH4i/7Et//Rstc/p/h2LxTrPg7S7q5nism8GQvcpA +wzIGi+QnqBu
2k4/u47101r4H8Tza3rer6xqOnz3WqaI9hsg3rHDKWOFUEE+WBg5JJyW4rT8 OeD9Q0jXtDvr
ia1aKw8Nx6TKI2YsZlZCWXKj5PkPJwenFAHD+IptM1v4gaxpuv6L4i1fS9Ij gt7O00uCWSNG
aMM0khQg7uQBnsKEvtaf4fWmgT/2xYQ3viSPSIJr6Nobr7C/zg5bnOAUz7Yr tdY8M+JrLxTe
a/4QvdMSTUYo47611NHMbNGMJIpTkNt4x04/Js3gG9u/BLabda1JLrv20amm oMpKx3Qbcu1T
0QY249OcdqAMFfCOn+Efi14Pt9IM0WnzQXzLavM0ixyCNdzKWJI3ArkZx8tb fxZglutD0O2g
uHt5ptdso45k+9GxcgMPcHmodP8ACnjG78c6L4k8RahpL/YY7iFraxEioqug Csu4ZLE53ZIA
AXGa6LxdoN1r8WjLaSQobLV7a+l81iMxxtlgMA/N6ZwPcUAefH4faRF8Tv8A hGYJL6PQrvSf
7QvbL7XIRdSpLsBds7v48nBGSBVOK4vbDwfd+FbK/uYYJPF/9gwTiQmSC1YK 5Csec43AfWvT
G0C6PxIj8R+ZD9jXSGsSm4+Z5hmV84xjbgHvnPasGT4eXd1o3iC1lvYre7u9 dbWNOuYct5Dg
JsLAgc5UggZ4PWgCnZaFZ/D/AOI+gafoRni0zXIbmO4tHmaRRLEgkEo3EkMR kHtXKR+GIPEn
wo1jx5dXN3/wkF5a3lx9oE7AJCC6mAJnbsKKRgjv7CvQdC8M+I7nxTB4h8X3 umzXNlA8Fjb6
cjiJN+N8hL87iABjpWFffD7xfFo2reF9H1jTIvDl357wCZH+0Q78t5OQCvll jgnk4J4oAl8L
f8lC8Of9iVH/AOjYq5/xr/x6/F7/ALh3/oqOusvfB3iWyuPD+reHb3TE1XT9 LXTLmK+Ehglj
+U5BUbuGXPbPHToc2b4a+IbjQfGlrc6nZXN9r5tnjmYsiq6AFwwCnaoOQuM8 AZoAyPE91p/i
H4i63Y+ItG8RaxpulrDDaWmlwSvEjsm95H2EfNkgD2FOjTxHe/DJ7H+zvEL2 VnrQje3ljaG+
uNMHzbRnBY/MF4PIUiux1jwz4msvFN5r/hC90xJNRijjvrXU0cxs0YwkilOQ 23jHTj8myeCt
dXwlDbweInbxBHqA1NruTd5Mk2TmMqDxFg42j0zjtQBmfDa38MRa/fnwte3t lALZVutAvEkV
4Zd3Ev7xiRx8pAyORz2rrvGX/IDtv+wrpv8A6Ww1meGvDfiBfFVx4m8UXWmv qDWYsYYNNRxE
kW/eSS/zFiQPpWn4y/5Adt/2FdN/9LYaAOgooooAKKKKACiiigAooooAK86/ 5mvxT/2EIv8A
0jt69Frzr/ma/FP/AGEIv/SO3rpwn8Q58V/DLNFFFeqeYFFFFABRRRQAUUUU AZXiCNprG0iS
aSB31OwVZYwpZCbqL5huBGR15BHqDXpNjY2+nWcdrax+XCmSAWLEkklmZjks xJJLEkkkkkk1
51rH+q0//sK6f/6VxV6bXmY3+IvQ9HCfA/UKKKK5DqCiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK5/xl/yA7b/ALCu m/8ApbDXQVz/
AIy/5Adt/wBhXTf/AEthoA6CiiigAooooAKKKKAOfs/+Sh6z/wBgqw/9G3dd BXP2f/JQ9Z/7
BVh/6Nu66CgDn/GX/IDtv+wrpv8A6Ww10Fc/4y/5Adt/2FdN/wDS2GugoAKK Kp6rqlnoml3G
pahKYbS3TfLIEZ9q+uFBJ/AUAXKKyrnxLo9nqOlWE96qXOqhjZJsY+btAJ5A wOCOuM9q5Tx3
4ogin0y0sNTkgns/EGnw6hsZ4wschLbWbgMpXkjJHrQB6BRXPeH/AB14Z8U3 k9pourw3dxAN
zxqrKcZxkbgNwzjkZHIqnoOu6Lo3gGHVLrxHJe6bG8udSvd4dz5rjbhvmODl QPRRigDraK81
8Y+OtM1z4U+INT8K60zS2qIDLbs8MsRLr6gMuRnnvzXTad4+8Latr8mhWOs2 8+pIWBhUN8xX
qFYjaxGD0J6GgDpKK4/4qXt1p3wz1u7srma2uY4kKTQSFHU+Yo4YcjipNX1n StD8XSX2o67d
Qrb6Q0suniOR4hF5ygz4UEbgSF9cE9qAOsorN1DX9L0vTre/vLoJbXMkcULq jP5jSHCABQSc
59Ky9e+IPhTwzqKafrGsw2124B8razlQehbaDt/HFAHTUUyGaK4gjmhkWSKR Q6OhyrKRkEHu
K57XfH3hbw1qMWn6vrMFrdyAERkMxUHoW2ghR7tigDpKp6VpVjoemQabptuL ezgBWOIEkKCS
epJPUmo59b023v8ATbKS6X7Rqe/7GqqWEuxN7YYDA+XnkjPaq+o+KdG0m7ub S9uzHPa2f26Z
BC7bYNxXd8oOfmBGBz7UAbFFeb+DvinpF18PbbWvEWrww3KMYbpjCy/vCSQq qB83y4Py5rT1
fxV4d8SfD7U9RsPE8tnYIAsuo2ayCW3O5f4QA4JyB06GgDtaKxvEXivQ/Cdp Hc65qMdnFK2y
PcrMznvhVBJx9OK5bw14rtLjxP421KbWQ+h2/wBilglkmJhiRrcE7QeFyeoH U+9AHoVFc/4c
8ceG/Fsk8eh6rFdyQDMkexkYD1wwBI9xxR448QJ4Y8GapqnneVNFbuLZjGXH nFT5YIAPG7HX
j1oA6CivItL+JFhJ4o07V9Q1xotKPhoyXIcOkZuROisRHjlskgEA8dOK6rWP E2geIvh3qOqW
PiWWy04AJJqVmsgltyGX+EDeDyBjHRvSgDs6K5zxD498L+FbqO11rV4rW4kX csWx3bb6kKDg
e5xW5Z3ltqFnDeWc8c9tMgeOWNsqynoQaAJ6KwPEPjbw34Unt4Nb1WG0luOY 0ZWYkdMkKDge
5wK4vRNVW/sLua/8SXtvGPGkkNpJHI8gnUSfu7fIziNumPu4oA9TorATxr4d k1ddJXU0N+91
JZrBsfcZUUMw6dAGHzdOcZzW/QAVz/jL/kB23/YV03/0throK5/xl/yA7b/s K6b/AOlsNAHQ
UUUUAFFFFABRRRQAUUVXvr+z0yzkvL+7gtLWPG+aeQRouSAMseBkkD8aALFe bQzw3PijxU8E
scqDU1QsjBgGW1t1YcdwwII7EEV1P2a88SfNer9m0R+li8RWa6XsZiT8sbd4 du4gAOQGeKuW
gghtfEfiS3t4o4YIr6FI441CqiiztgAAOAAOMV04T+Ic+K/hl2iiivVPMCiu W8Ya9c6dNpul
2N3a2V1qDv8A6XdY2QRoAWbB4J5AANZ+i6tqtzqV/wCHZfENrfXJtPtNrqlt DGSg3bWDICVy
CQR7Gs3USlymiptq52Fhf2up2MV7ZTLNbSjKSL0YZx/SrNeUeFr/AFmw8F+H tM0++je81eSR
bYywjbaRJkyHj757jPrXaaB/wkVnql3p2tXC6hAI1lt9QSARbskhkZRxkcH6 UoVeZLQc6fLf
U6OiiitTIztY/wBVp/8A2FdP/wDSuKvTa8y1j/Vaf/2FdP8A/SuKvTa8zG/x F6Ho4T4H6hRR
RXIdQUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABXP8AjL/kB23/AGFdN/8AS2Gugrn/ABl/yA7b/sK6b/6Ww0AdBRRR QAUUUUAFFFFA
HP2f/JQ9Z/7BVh/6Nu66Cufs/wDkoes/9gqw/wDRt3XQUAY/iixuL/QZUs4/ NuoJYbuGHcF8
54ZUmWPceF3mMLuPTdnBxitCwvrfU9Otr+zk8y1uokmhfaRuRgCpweRkEdas Vz5/4paWaU86
HNK88rnrZSOxd3Y94WZmYk8xkkn92f3QB0FUda01NY0LUNMkxsu7aSA57blI /rV6igD54hvZ
NX0/SfEb53+ErHTklB6+Z9oKTf8AjkfNa+pWMOs+GbW+ukEsGu+No2Ib+KDz DCoPttT9a9Ft
fh7olnpPiLTYjceRr0sst0Sy5QyDBCfLwBkkZzg+tTnwTpf9gaFoyyXK22jX EFzblWXc7wnK
7ztwQTycAe2KAMjX4Irf4s+CGhjSMvbahE2wYyipGVX6Ak4FcJ4YSO6tPhfZ Xiq9g9/qszI4
yrTI8hiz75LEV7DfaBa3/iHSdalkmFzpizrCqsNjCVVVtwxk8KMYI/GsZvhz oj+ELbw473jW
9pM1xbXIlC3EMjOz7ldQMEFyBx09aAOW+K9roUWieLJ7eXbrkulwfaYkzhoh OArsMY3ZyOuc
Vq+NtNtNL/4QOGygjhS1162t4tigbYzHICo9jgZ9cVcT4X6KPD+r6VNeapcy atsF5f3NwJLl
whBUbyuMDHp3roda0C1119Ma6kmQ6dfR30PlMBukQMAGyDlfmPTB96AOd+MH /JKNf/64p/6M
Wqmr6fDq3xdm064GYbvwnPA/+61woP8AOut8SaBa+KPD15ot7JNHbXShXaBg HADBuCQR1HpQ
dAtT4rXxH5k32xbE2ITcPL8suHzjGd2QO+MdqAPLvDN1N4kn8CeHrnmXQxPc 6gh/he2YwRZ9
9xz+FHhe38XXl74vl0yz8MzpPrN1BdHVGm80hSAEIVSNgXGB7mvRtG8G6VoX iPWdctPON3qz
K0wdgVTGSdgABGScnJPNZmt/DTSNa1a51Fb/AFfTpLwBb2PT7swx3QAx+8XB zxxxigCb4Z2k
lj8PdKtZb60vfKEipPZyM8TJ5jbQrMASAML07Vj+B7Sxv5/HsmqRRSzTa1c2 90ZgMm3VVEan
P8O3OPxrvNP0+10rTrewsYVgtbeMRxRr0VR0Fcvr/wANdG1/VZ9Qe71Syku0 WO9jsLoxR3ig
YAlXHzccduKAOD8HzSyQ/CN7hmJB1JEL9SgjkWP/AMdC12UM0cnx3u0RgzRe HI0cD+E/aGOD
+BB/GtfXfA+j67o9hprC4sU05laymsZfKltiowNjc444qHw94B0rw3rUmr2t zfz3str9mnlu
p/Nab59+9yRkv0Gc4wAMUAedeGNNu7vwR8PLzSL7TY9bs0u3tLPUA3l3KkkS Y28hlGCCPWjx
PfxXngb4hJd6Cuk+IY0tP7SEU/mxzAkeU6noMjOeM9M5rsovhNo0Ojxaamp6 yq21w1xYTpdb
ZbHd1WJgOFOeQc1bX4aaKvhfVNDe51GUaqyteX004kuZSpBBLsCOMY6etAFS 5jjm+O1mLpVZ
YfD7yWgccLKZ8OV/2tuPwrzTxHa+V4w17T9Iisjb3HifTVeK4yLd3aF32ybe dpk6jHUV7P4n
8Haf4q+yS3Fxe2V5ZszW97YT+TPFuGGAbB4Pfisu0+Fnhu107V7Ardz2+qmJ pxNNuYSRjAkV
sBg5OWJJOST24oAx4tO8Tt8SPDd/rsvhe0ljjuYlisJpvOuYzHyuGTBCna3U Y5rrfHf/ACTz
xL/2Crr/ANFNVXw74C03w7qb6n9u1TVNQMXkpc6ndGd4o852pwAB+tdDqNhB qul3enXQLW91
C8EoBwSrKVP6GgDzHQLG2vPiP4TkuIkka18IRzQ7hna+9FyPfDH86xfGMaQ6 f8XYYlCR77CT
aowNzRxlj9SeTXo3hzwHZeHL+1vk1LUr24trBtPja7lV8Qlw4HCg5G0Ac4x2 pdU8A6Vq8fiN
Li4vFGv+R9q8t1GzylCrsypxwoznP4UAYF/Z65YeOvEOqeGF0jWWuI7dNR0y 5kMc8RWPCKr8
qAy84b1ro/h9c6VeeBdMn0SxexsGV9lq7ljEwkYOuSSSN4b8PTpVfX/h5pmv avJqi6jq+mXc
0axXL6ZdmH7Qg6CQYOcDiuh0jSbLQtJttL06EQ2lsgSJAc4H17k9SfegDjvD 8MVx8XfGr3SI
88dvZRW+8ZIhaMlgPYvnP4VwmmQW1t4ctLeyCi1i+IiJDt6bBKAuPbGK9Q8S eA9M8SalDqT3
mpaffRxeQ1xp1yYXlizny3ODlc5qCz+G2h6fpkGnWsl3Ha2+rrq8SB1+WVSC E+7/AKvgDHX3
oAzvh5plk2veNNTa2ja9OvzQiYqCwRUQgA9uWNeg1laLoFroT6m1rJM51G+e +m81gdsjhQQu
AML8o65PvWrQAVz/AIk/0660nRI/9dcXcd67f884baWOVmx3y4ijxnI83dgh SK1NS1KHTLdZ
JFklkkcRwW8QBknkIJCICQM4BJJIAALMQoJFPTLG4m1GXWtRj8q6liEMFqWD fZYgSxBIyPMc
kF9p2/IijdsDsAbFFFFABRRRQAUUVj32rXD3kmm6RbfaLtcLNcPjyLMkAjzP mDM207hGmTyu
4xq6vQBY1PWLfS/KjdJ7i6nz5FrbRGSSQjGeBwq5KguxVFLLuYZFV7HSbh7y PUtXuftF2uWh
t0x5FmSCD5fyhmbadpkfJ5baI1dkqxpmj2+l+bIjz3F1Pjz7q5lMkkhGccnh VyWIRQqKWbao
ya0KACvOv+Zr8U/9hCL/ANI7evRa86/5mvxT/wBhCL/0jt66cJ/EOfFfwyzR RRXqnmHG+NtJ
ee/0jWRpK6vBYtIlxZeWsjPG4A3KrcEqQDil8KQC41m51C28Lw6Jp6wiKIS2 aQ3Mrk5YnbyF
wAMd+tdjRWfs1zcxpzvl5TyjRrXVbPQvDt9Ho98934emnhubVotrSxyZDNHn 7+OPrXaeH9U1
fWdTu7y4sLnT9KWNY7a3u4gkzvklnI6gdABmujopRp8vUcqnN0CiiitTIztY /wBVp/8A2FdP
/wDSuKvTa8y1j/Vaf/2FdP8A/SuKvTa8zG/xF6Ho4T4H6hRRRXIdQUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXP8A jL/kB23/AGFd
N/8AS2Gugrn/ABl/yA7b/sK6b/6Ww0AdBRRRQAUUUUAFFFFAHP2f/JQ9Z/7B Vh/6Nu66Cufs
/wDkoes/9gqw/wDRt3XQUAFFFFAHP/2fqOg/Now+2aeOP7LlkWP7Oo5xbtt+ oEbnbyoVolXB
sWPibTry8jsZDPZX75C2l9C0LuwBLiMsNsu3HJjLqODnBBOxVe+sLPU7OSzv 7SC7tZMb4Z4x
IjYIIyp4OCAfwoAsUVz/APwiVvbc6Vqeq6W3QC3ujLGqf3EhmEkSKOMbUGAM AgZBPsPiyP5I
tf0p414VrjSHaRh2LlLhVLepVVGegA4oA6Ciuf8AtPjCP5P7K0O428ed/ac0 Pmf7Xl+Q+zPX
bubHTcetH2zxh/0AtD/8HM3/AMi0AdBRXP8A2zxh/wBALQ//AAczf/ItH2zx h/0AtD/8HM3/
AMi0AdBRXP8A2zxh/wBALQ//AAczf/ItH2zxh/0AtD/8HM3/AMi0AdBRXP8A 2zxh/wBALQ//
AAczf/ItH2zxh/0AtD/8HM3/AMi0AdBRXP8A2zxh/wBALQ//AAczf/ItH2zx h/0AtD/8HM3/
AAczf/ItH2zxh/0AtD/8HM3/AMi0AdBRWHB4lhjuIrPWbeTSbyRxHGJyDBO5 OAIph8rFjnah
2yEDJQCtygAooooAKKKKACiiigAorl9Y1jW7fXE06JLHTrSbZ9n1O5iluklc /L5TIuxYm3EA
FpPmyoUMxISx/ZfiW5+S88SwQRjkNpmmrFIT6EzPMu3rwFBzjkDIIBuTzw2t vLcXEscMESF5
JJGCqigZJJPAAHOaw/8AhJX1D5PD+mz6gx5FzOGtrQDqGErKTIrAHa0SyA8Z Khg1SQeE9Mju
Irm6N3qNxG4lV7+6knVZQc+asTHy43znBRV25IXAOK3KAMex0a4F5Hf6vqH2 +7jyYVSERQW5
IKlo0yzbivBZ3cjLBSqsynYoooAKKKKACo554bW3luLiWOGCJC8kkjBVRQMk kngADnNV9S1S
00m3Wa7eQB3CRpFE8skjYJwiICzHAJIAOApPQE1nwabd6pcRX+sNJHGjiSDS wUMcRU5R5CAS
8oPOAxjU7cBmQSEAj+03niT5bJvs2iP1vklKzXS9xCAPljbtNu3EAlAAyS1s WNhZ6ZZx2dha
QWlrHnZDBGI0XJJOFHAyST+NWKKACiiigArzr/ma/FP/AGEIv/SO3r0WvOv+ Zr8U/wDYQi/9
I7eunCfxDnxX8Ms0UUV6p5gUUUUAFFFFABRRRQBnax/qtP8A+wrp/wD6VxV6 bXl3iATNY2i2
8kcc51OwEbyIXVW+1RYJUEEjPbIz6iux/wCEjuLDjXtInsI1+/ewOLm0B68u MSIoGSzyRoi4
OWxgnzMb/EXoejhPgfqdBRVexv7PU7OO8sLuC7tZM7JoJBIjYJBww4OCCPwq xXIdQUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUVzt7420S0uJbWKWe+uYiUaOxt3nAkBI8t pFHlo+eCHZcZ
BOAc00m9EJtLc6KiuMl8aapNj7B4ZePH3/7TvY4c+mzyRNnvnO3HGM84rPr3 i2dzJHLolkp6
QNay3JT/ALaeZHuz1+4MZxzjJ1WHqvZGbr011O8oriovF2vW5X7ZoVrcxIMP JY3uJZO25YpE
VVyeSplOBnliObUXj2xXP9oaVrNh/c3Wn2nf6/8AHuZNuOPvYznjODiZUakd 0NVYPZnV0VXs
b+z1OzjvLC7gu7WTOyaCQSI2CQcMODggj8KsVmaBRRRQAUUUUAFFFFABRRRQ AVz/AIy/5Adt
/wBhXTf/AEthroK5/wAZf8gO2/7Cum/+lsNAHQUUUUAFFFFABRRRQBz9n/yU PWf+wVYf+jbu
ugrn7P8A5KHrP/YKsP8A0bd10FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQBHPBDdW8tvcRRzQSoUkjkUMrqRggg8EEcYrD/sG80n5/D175UI5/ s27JktiP7sZ+
/BwFUbS0aDOIia6CigDDg8Swx3EVnrNvJpN5I4jjE5BgncnAEUw+VixztQ7Z CBkoBW5Uc8EN
1by29xFHNBKhSSORQyupGCCDwQRxisP+wbzSfn8PXvlQjn+zbsmS2I/uxn78 HAVRtLRoM4iJ
oA6CisODxLDHcRWes28mk3kjiOMTkGCdycARTD5WLHO1DtkIGSgFblABRRRQ BHPBDdW8tvcR
RzQSoUkjkUMrqRggg8EEcYrD3XnhrmaW+1PSTwG8sz3NqeijCLvmjIwMkNID yxcMWj6CigCO
CeG6t4ri3ljmglQPHJGwZXUjIII4II5zUlYc+lzaVcS6joySOXcvc6eZT5c+ TljGGO2KXJLZ
G1XLNv5YSJoabqUOp27SRrJFJG5jnt5QBJBIACUcAkZwQQQSCCGUlSCQC5RR RQAVl6lq7Wtw
tjY2cl/qDoH8lHVFiQkgSSufuIWBHAZjhiqttbFP+1rjX/3fh6aA2B+WXV1k DqD3FuuCsrDo
WJCKxH+sKug1NN0qx0i3aCwto4EdzJIV5aVyAC7seXc4GWYknuTQBX03RVs7 hr+6nkvNTkQr
JcOW2qCQSsUZJEScLwvJ2KWLsN1alFFABRRRQAUUUUAFedf8zX4p/wCwhF/6 R29ei151/wAz
X4p/7CEX/pHb104T+Ic+K/hlmiiivVPMCiiigAooooAKKKKAM7WP9Vp//YV0 /wD9K4q9NrzL
WP8AVaf/ANhXT/8A0rir02vMxv8AEXoejhPgfqY994Z068vJL6MT2V++C13Y zNC7sAAhkCnb
LtxwJA6jkYwSDX3+JdK5kSDXbUcAQKttdqBwCQzeVKxyCxzCBgkA5CjoKK5D qMvTfEOmarcN
a288iXaoZDa3UElvPsyBvEciq5TJxuxjORnINalU9S0nTdZt1t9U0+0voFcO sd1CsqhsEZAY
EZwSM+5rL/sXVNN+fR9ZnljX7tjqbefGR1IExHnKxP8AGzSBQThCAoAB0FFc /wD8JK+n/J4g
02fT2HJuYA1zaEdSxlVQY1UEbmlWMDnBYKWrcgnhureK4t5Y5oJUDxyRsGV1 IyCCOCCOc0AS
UUUUAFFFFABRRRQAVz2s+Ko7C5k0/Trf7fqaYLxFmjhiBGf3koVgpwQQgBY7 lO0KSwi1/X5V
nfSdJkAvAB9pusBhaAjIAB4aUgghTkKCGYEFVfEtraK0gWGFSEBJ5YszEnJZ ieWYkkkkkkkk
kk11UMM6nvS2OaviOTSO5Xu7S61rJ8QXn9oIf+XNY/KtB/2yyd/RT+8Z8MMr t6Vahhit4Y4Y
Y0jijUIiIoCqoGAAB0Ap9FelCEYK0UcEpyk7yYUUUVRAUUUUAUJdItGvWv7d Ws9RbGb20Plz
HGMBmH31GF+R9ynaMg4rZsPFc2lsYfEEoe1JxDqCQkBR0xcBchTj5jKAsf3s iPC7qtFY1aEK
m+5tTryh6HcQTw3VvFcW8sc0EqB45I2DK6kZBBHBBHOakrz+z1RvDFwZ850i aUG6iJwLZnbB
nUnhVyd0gOBjc4wQwk9Ary6tN05crPRp1FUjdBRRRWZoFFFFABRRRQAVz/jL /kB23/YV03/0
throK5/xl/yA7b/sK6b/AOlsNAHQUUUUAFFFFABRRRQBz9n/AMlD1n/sFWH/ AKNu66Cufs/+
Sh6z/wBgqw/9G3ddBQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQBHPBDdW8tvcRRzQSoUkjkUMrqRggg8EEcYrD/sG80n5/D175UI 5/s27JktiP7s
Z+/BwFUbS0aDOIia6CigDDg8Swx3EVnrNvJpN5I4jjE5BgncnAEUw+VixztQ 7ZCBkoBW5Uc8
EN1by29xFHNBKhSSORQyupGCCDwQRxisP+wbzSfn8PXvlQjn+zbsmS2I/uxn 78HAVRtLRoM4
iJoA6CisODxLDHcRWes28mk3kjiOMTkGCdycARTD5WLHO1DtkIGSgFblABWX qWireXC39rPJ
Z6nGgWO4QttYAkhZYwQJU5bhuRvYqUY7q1KKAMOPxLDAkyaxbyabdwpvMLkS icbgm6ArkyAu
yqFwJMsmUUuoMf2a88SfNer9m0R+li8RWa6XsZiT8sbd4du4gAOQGeKtTUtL tNWt1hu0kIRw
8bxSvFJG2CMo6EMpwSCQRkMR0JFZ8GpXel3EVhrCySRu4jg1QBBHKWOESQAg pKTxkKI2O3BV
nEYANyiiigAooooAKKKKACiiigArzr/ma/FP/YQi/wDSO3r0WvOv+Zr8U/8A YQi/9I7eunCf
xDnxX8Ms0UUV6p5gUUUUAFFFFABRRRQBnax/qtP/AOwrp/8A6VxV6bXmWsf6 rT/+wrp//pXF
XpteZjf4i9D0cJ8D9QooorkOoKKKKACsOfwpppuJbzThJpF/K5eS607bG0rE 8mRSCkp5bBkV
sbiRgnNblFAHP+d4l0r5ZLWDW7VOksEi292R0AMbYiduhZ98YOThBgBrmm+I dM1W4a1t55Eu
1QyG1uoJLefZkDeI5FVymTjdjGcjOQa1Kp6lpVjq9usF/bRzojiSMtw0TgEB 0Yco4ycMpBHY
igC5RXP/ANj6xpn/ACBtW823HP2PVd9x052pPu8xdxzln83GRtUAbSf8JSlj x4gsZ9HUcG6n
ZXtGI6kTKSEXOAplEZbcABnIAB0FYniTXH0mG3t7RI5NQvHZIFflYwBlpXAO Si8DjGWZFyu7
cNeCeG6t4ri3ljmglQPHJGwZXUjIII4II5zXndtenXbuXXpGLxXBIsAekdrx tK9MeZtEpyA3
zKrZ8sY2oUvaTt0Mq1T2cb9SSxs0sLKK1R5JAg+aSQ5eRjyzue7MSWJ7kk96 sUUV7CVtEeU3
cKKKKBBRRRQAUUUUAFFFFABU2h6l/YNxa6bI+dMuZRBbBuPsbkEqmenlMRtU HlWZEXcrARw1
Be2qX1lLbO7x+YuFkjwHjb+F0JBw6nDK3UEAjkVlWpKpG3U1pVHTlc9DorI8 MatLrfh62vbh
ES5y8NwIwQnnRu0cmzJJ2b0bbnnGM4Na9eNsesFFFFABRRRQAVz/AIy/5Adt /wBhXTf/AEth
roK5/wAZf8gO2/7Cum/+lsNAHQUUUUAFFFFABRRRQBz9n/yUPWf+wVYf+jbu ugrn7P8A5KHr
P/YKsP8A0bd10FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUARzwQ3VvLb3EUc0EqFJI5FDK6kYIIPBBHGKw/7BvNJ+ fw9e+VCOf7Nu
yZLYj+7GfvwcBVG0tGgziImtyeeG1t5bi4ljhgiQvJJIwVUUDJJJ4AA5zWH5 154k5srn7Loj
fKbhARNeL3MLgjy4+wkwWcElNgCSMAFn4ss2vDp+qJ/Zt+sq25SVw0MkpAKp HKPlLNuBWNts
pXDFADXQVTh0nTbbSzpcGn2kWnlGQ2iQqsRVs7hsAxg5ORjnJrL/ALHv9F58 OvA1r/Fpt7LJ
5YPQeTINxgUD+AIyYVQqplmIB0FRzwQ3VvLb3EUc0EqFJI5FDK6kYIIPBBHG Ky7HxJZ3V5HY
XUc+m6lJnZZ3yhHkwCT5bAlJcLyfLZtuRuweK2KAOf8AJvPDfFlbfatEX5jb oSZrNe4hQA+Z
H3EeQyAEJvBSNdyCeG6t4ri3ljmglQPHJGwZXUjIII4II5zUlYc+jzabcS3/ AIegtI55nL3V
nIxhgumJyZCyqxSUE53hTuHysD8jIAblFU9N1KHU7dpI1kikjcxz28oAkgkA BKOASM4IIIJB
BDKSpBNygAooooAKKKKACuevvBOh6hqNzfzR3yXFyyvMYNSuIVdgqoDtSQLn aqjp2roaKabW
wmk9zmP+Ff6B/wBRb/wdXn/x2j/hX+gf9Rb/AMHV5/8AHa6einzy7i5Y9jmP +Ff6B/1Fv/B1
ef8Ax2j/AIV/oH/UW/8AB1ef/Ha6eijnl3Dlj2OY/wCFf6B/1Fv/AAdXn/x2 j/hX+gf9Rb/w
dXn/AMdrp6KOeXcOWPY5j/hX+gf9Rb/wdXn/AMdo/wCFf6B/1Fv/AAdXn/x2 unoo55dw5Y9j
mo/APh+O4gm8vUJGglSZBNqt1IodGDKSrSEHDAHkHpXS0UUm29xpJbBRRRSG FFFFABRRRQAU
UUUAFFFcddeJZNP+Jtxp99qMNto0Whpdt55REWUzsm4ueegAxnFADvFen2ei eHtZv9MSSxv7
+I2qvaytEn2i4cRrMyKQu/e6kyYL4HU4ArPhhit4Y4YY0jijUIiIoCqoGAAB 0ApfGes6dcXf
h1xfWosUNxqQvRMpiIjQQbd2cYJus7s/wYxzkMnure2MQuJ4ojLIIo/McLvc 9FGep4PHtXo4
ONouRwYuV5KJLRXGanq2p2CwmPV4LnzvEUVqRCqHyYGIBhbjhhzk9eRzXUza lY213FaT3ttF
czf6uF5VV3+ik5Ndammcri0WqK5/wRqV3rHg3Tb+/m866mRjI+0LkhiOgAHQ CtO51jTLMyi6
1G0gMO0SiWdV2bs7d2TxnBxnrihSTSYOLTsXaKge9tY4oZZLmFI5mVInaQAS M33Qp7k9gOtR
Nq+mpZG8fULRbUMVM5mUIGBwRuzjOaq6FZlyiqzahZJYfbmvLdbPbu+0GVRH j13Zxikh1Kxu
buW0gvbaW5h/1kKSqzp9VByKLoLMtUVTu9V07T5Y4r3ULW2kk+4k0yoW+gJ5 qWe8tbZ40nuY
Yml3GNZJApfaMtjPXAGT6Ci6CzJ6K5qDxhY3PjIaLDe2MkD2SzxypOrF5SxG wYOD8uGx1wc9
KvaNdtF4ejudS1e0vCpkMl7GyrERvbHIwBgYU+4NSpp7DcWtze8Iym38VazZ 7gkVxb294iHr
JL88crLnk4VLcEDgZXoW57WvNtH1Ozl8YaHfWVzBeQ3K3OnboZQyqWQT7sjO cfZtuP8Abznj
B7m217R72/ksLXVrGe8jzvt4rhGkXHXKg5FeViFao7Hp0HemjQooorA2Ciii gArn/GX/ACA7
b/sK6b/6Ww10Fc/4y/5Adt/2FdN/9LYaAOgooooAKKKKACiiigDn7P8A5KHr P/YKsP8A0bd1
0Fc/Z/8AJQ9Z/wCwVYf+jbuugoAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKACqepapaaTbrNdvIA7hI0iieWSRsE4REBZjgE kAHAUnoCar6l
qs0FwthpttHeakyCTypJTFHFHkjfI4VioJBCgKSxBwMK7Kaboq2dw1/dTyXm pyIVkuHLbVBI
JWKMkiJOF4Xk7FLF2G6gCvBpt3qlxFf6w0kcaOJINLBQxxFTlHkIBLyg84DG NTtwGZBIdyii
gAooooAr31hZ6nZyWd/aQXdrJjfDPGJEbBBGVPBwQD+FY/8AZWsaRzo1/wDb Lcf8uOqzO+P9
y4w0i8ksd4lzgKuwV0FFAGPY+JLO6vI7C6jn03UpM7LO+UI8mASfLYEpLheT 5bNtyN2DxWxV
e+sLPU7OSzv7SC7tZMb4Z4xIjYIIyp4OCAfwrH/srWNI50a/+2W4/wCXHVZn fH+5cYaReSWO
8S5wFXYKALmpaJDeXC6hbeXa6vEgSG+WMM20Eny36F4iScoSOuQVYKwjsdcz eR6bq8cGn6rJ
kxQCfzEuFAJJhcqpfAB3DaGXHI2lWYsfElndXkdhdRz6bqUmdlnfKEeTAJPl sCUlwvJ8tm25
G7B4rQvrG31GzktbqPzIXwSAxUgggqysMFWBAIYEEEAggigCxRXP/wBqXHh7 5fEN7A9geItU
ZBCqHoEuOdqseokG1GYldqHYH6CgAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACvNdU8P6Zr/xzVdVtoruG38PJKtvMoZGb7RIASp4bAJ6+ telVxPiPwJe6
v4uTxLpfiObSNQisVs4mjtllAAdmbcGOGU7vu44Kg57UAeKeOrWHR/EvjHQr BBFpdrZNPBAv
3Ynla0Z1UdhkA47ZruvGxHn+GBnk65Acf8BepNe+H1tp72lrqF7cXz6vHew3 moyAB5bmTyZE
AUfdAS3kIHQbMZ5ANFPA2oTXemXOp+JZ76TTrlJYQ1sqKEUHKkA8sfl+Y5PH Tmu/DpuGiOKu
0p6s59/+W/8A2PMf/slauiaFp3iG48U3up28c12dTmtUmcZaBIwAmw/wkdcj 2rWbwZu8z/T/
AL+uLrH+p6Y2/u/vf7P3vfpSX/g2efVru50/W7jT7TUCDfWscSsJTjBKseUJ HBIrZU5LVq5i
5row+Gv/ACTzR/8Arm//AKG1Z9vomnav8S/ET6jbRXSwW9qEimUMmWVsttPG RjGe2TWrp/ha
70zw/oulWusyRf2fcLLLIkWPtMYZiYyN3AOeuT06VhPo9/qfxE8RzabrMul3 MEVonmLCsquj
I2QVbjPyjB7c02moxTX9WEmnKTT/AKuYr2qy+GP7FEki2lv4sFlAVY7ki3jA B9ix/Kt+TQdK
k8fWGhNYw/2VY6Y93DaFcxmVpdhYg/ewPX1rXHgyCHRtL063u3X7Ffx30k0i 72ndWLNnkYLE
9ece9Wdf8OSatdWt/YajJpup2oZY7lIxICjdVZTww/lQqbS1XYbqJvfucJrM MemaH8QNHtF2
WFsbeaGIfdjMoBZR6DIBx71s63oWneHbjwteaXbxw3Y1OG1eZBh50kBD7z/E T1yc03xPoCaD
8M9fD3Ul5eXWJrm6lADSuXUdB0AHQdq1tO8Gz2+qWlzqOuXOo22n5+w20kSq IjjALMOXIHAJ
qeR3tb/gasfOrXv/AMHRHJWUFxrGo+ILq48GrrjSX81v9oluokMSIdqooflc DuMdalXSbi+t
/Auk66jBxJdRyoJg+5ERtqllJBBUAHB9a6e+8HXp1K8udG8Q3GlQ3zb7qBIF kDPjBZCeUJHU
irkPhK2tLjw8bOYxQaMJQsRXcZd6FSS2Rg5JPQ59qapPr+nf+twdRdP17GTa aRptp8U/Kt7C
2jSLRY3jCxAbW85lyPfAAz6Vx1q09zong7TV0w6nbyTX872XnLGszJK23Jbj A3E4716XdaBc
SeMLbXrbUPIC232W4gMIbzUDFhg5+U5NZq+BRH4d06wi1OWG/wBOmkmtr+KM AoXdmIKkkEYb
BGecfhRKnLov6uhRqLq/61ObstI1U+O7NLfR4vDVtfQXMYC3UTIs4tLkJKFQ /LgMcnGOPWuk
0XT9J0m88L6fr/g+XQNRt7qFLTWNPMbxXkoGAryqN2JOflPPPUUaV4LM/i7T 11bUJdYvrpbj
7VK6LCEsxbyxMFUcAb7iMEDk7s44JrqtM+G9/b3elJqviy71PSdIlSaxsHtU j2MgxGXkHL7e
2cVwV1adjuou8D0GiiisTUKKKKACuf8AGX/IDtv+wrpv/pbDXQVz/jL/AJAd t/2FdN/9LYaA
OgooooAKKKKACiiigDn7P/koes/9gqw/9G3ddBXP2f8AyUPWf+wVYf8Ao27r oKACiiigAooo
oAKKKKACq99f2emWcl5f3cFpax43zTyCNFyQBljwMkgfjViuY+IH/Iqf9xCw /wDSyGmld2E3
ZXJ/+E78H/8AQ16H/wCDGH/4qj/hO/B//Q16H/4MYf8A4qsOiu76j/e/A4/r n938Tc/4Tvwf
/wBDXof/AIMYf/iqP+E78H/9DXof/gxh/wDiqw6KPqP978A+uf3fxNz/AITv wf8A9DXof/gx
h/8AiqP+E78H/wDQ16H/AODGH/4qsOij6j/e/APrn938Tc/4Tvwf/wBDXof/ AIMYf/iqP+E7
8H/9DXof/gxh/wDiqw6KPqP978A+uf3fxNz/AITvwf8A9DXof/gxh/8AiqP+ E78H/wDQ16H/
AODGH/4qsOij6j/e/APrn938Tc/4Tvwf/wBDXof/AIMYf/iqP+E78H/9DXof /gxh/wDiqw6K
PqP978A+uf3fxNz/AITvwf8A9DXof/gxh/8AiqP+E78H/wDQ16H/AODGH/4q sOij6j/e/APr
n938TuIJ4bq3iuLeWOaCVA8ckbBldSMggjggjnNSVz/gT/knnhr/ALBVr/6K Wti+vrfTrOS6
upPLhTAJCliSSAqqoyWYkgBQCSSAASa4DtLFc/8A2pceIfl8PXsCWA4l1RUE yuehS352sw6m
Q7kVgF2ud4Q+x3HiT97fGe20huE09kCtdp/euARuVTxiIFflyJM7zGnQUAU9 N0qx0i3aCwto
4EdzJIV5aVyAC7seXc4GWYknuTVyiigAooooAKKKKACiiigAooooAr31hZ6n ZyWd/aQXdrJj
fDPGJEbBBGVPBwQD+FY/9laxpHOjX/2y3H/Ljqszvj/cuMNIvJLHeJc4CrsF dBRQBj2PiSzu
ryOwuo59N1KTOyzvlCPJgEny2BKS4Xk+Wzbcjdg8VX+zXnhv5rJftOiJ1sUi LTWq9zCQfmjX
tDt3AEhCQqRVsX1hZ6nZyWd/aQXdrJjfDPGJEbBBGVPBwQD+FY/9laxpHOjX /wBstx/y46rM
74/3LjDSLySx3iXOAq7BQBsWN/Z6nZx3lhdwXdrJnZNBIJEbBIOGHBwQR+FW K4/+0PM1jdp5
/sfW7jmbS9Vj2pfbVzlGRipkCKoMkRk2qQHViqBeg0zWLfVPNjRJ7e6gx59r cxGOSMnOODwy
5DAOpZGKttY4NAGhRRRQAUVHPPDa28txcSxwwRIXkkkYKqKBkkk8AAc5rl7n xzBMCmhWM2pS
Z/10ga3tgOx81lO9WGdrRLIDxkgEGqjFydkhSkoq7OsqOeeG1t5bi4ljhgiQ vJJIwVUUDJJJ
4AA5zXBzal4ovsiXVrbT4yd6rp9qDIn+wZJi6uBnqI0JIB+UZU0B4f0s3Edz Pa/bLqIgx3N9
I1zNHg5AWSUsygHkAHAJJ6k10QwlR76HPLFQW2p1/wDwnfg//oa9D/8ABjD/ APFUf8J34P8A
+hr0P/wYw/8AxVYdFa/Uf734Gf1z+7+J1mma7o+t+b/ZOq2N/wCTjzPslwku zOcZ2k4zg9fQ
1oV5vf6RpuqeX/aGn2l55edn2iFZNucZxkHGcD8qS3s7zTMHR9WvbJVxi3Z/ PtyB91PLkzsQ
dNsRj44yMLiJYKS+F3Kji4vdWPSaK4qDxbrdmNuo6PFqCgY87TJRG7HqMwys AqgZGfNYkgHH
J29HpOv6XriSHT7tZHix50Lq0csWc7d8bAOmcEjcBkcjIrmnTlD4kdEZxn8L NKiiioLCiiig
AooooAKKKKACiiigDmvHlup8KXOpjifSA2own1MaNvX0+eMyJkg7d+4DIFZF d5Xmel2p0gS6
BJkPpZWCInrJb4/cv2zlPlYgAb0kA4Fd2CnZuJx4uGikaFFFFegcAVGlvDHP JMkMayy4EjhQ
GfHTJ74qSigAooooAjnt4bqBobiGOaJ+GSRQyn6g1JRRQAUUUUAFFFQ3d1DY 2U95cvsggjaW
R8E7VUZJwOTwKBlrwxD9r8Z3t0QxTT7JLeN1+6XmffIrH+8qwwEDggSZOdy4 7isLwjpc+l+H
4lvIwl/cu91dLkFleRi3llgTv2KVjDdxGMYGAN2vFqz55uR69OPJBRCiiisy wooooAK5/wAZ
f8gO2/7Cum/+lsNdBXP+Mv8AkB23/YV03/0thoA6CiiigAooooAKKKKAOfs/ +Sh6z/2CrD/0
bd10Fc/Z/wDJQ9Z/7BVh/wCjbuugoAKKKKACiiigAooooAK5j4gf8ip/3ELD /wBLIa6euY+I
H/Iqf9xCw/8ASyGqh8SJl8LMqiiivcPGCiiigAooooAKKKKACiiigAooooAK KKKALnhfVk03
4eeFIktp7y8m0q2MNpbbfMkCxJub5mVVVcjLMQMlRncyg7Fjo7veR6pqz+fq IyY40lYwWoII
2xqcAsAWBlK723N91SEXL+HGlWNh4F0O5traNLi70y1e4n6ySnygRuc8kLkh QThRwMAAV1le
Ce2FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBXvrCz1Ozks7+0g u7WTG+GeMSI2
CCMqeDggH8K5fU/CmqReVNoesT+ZBkQpeTbpIg2NypcMsjbW+8yyrMCVTaIy qsvYUUAcvoPi
77XeRaNrlnPpWutv2QXEW1LpUCkvC4Zkb5WBKB2ZPmByF3G9rfiS20iQWkcb 3WpSJvitUBxg
nAaRwCI04bluTtYKGYbag8TaxFbqmm28EF3qMm2ZI5k3x24VsrNIPZlyoBBZ l4ICs6c9bWwt
1cmSSaaV/MmnlILzOQAWYgAdAAAAAAAAAAAOmhh3U1exz1q6p6LchmtbnU7m O61y6S/liYPD
CIQlvA46PHGSx3/7TMxHO0qCRVyiivTjCMVaJ50pOTuwoooqiQooooAKKKKA Cq11Yw3UsNxz
FeW5Jt7qMASwMcZKMQcZwAQchhwwIJFWaKTSasxptO6LOn+K59L/AHPiKZZL c4EWoxwFQvbE
4XIXj5jKNsf3siPC7uzrg6dpGr/8Izttrlv+JH0Rz/y4ex/6Yf8Aov8A65/6 rz6+F5fegd1D
Ec3uzO6oooriOwKKKKACiiigAooooAK5fxlpcskEGt2UDzXumrIWhiUtJcQM MvEo/vZVHXjJ
KBcgOTXUUVUZOLuhSipKzOAhmiuIY5oZEkikUOjowKspGQQR1Bp9XNc0OXTp pdU0uF5LeRjJ
eWUSksGJy00Sjqx6sg+9yy/PkSUIZoriGOaGRJIpFDo6MCrKRkEEdQa9ejWV RXR5VWk6bsx9
FFFamQUUUUAFFFFABRRRQAU3TdOfxDqduwH/ABK7C5Es0h6TzRnKxpjn5JAr MwOMoE+bLhIl
s7jX55tKspJIYwNl5exnBtwwztQ/89iCCP7gIdv4Vfv4IIbW3it7eKOGCJAk ccahVRQMAADg
ADjFcOKr29yPzO3DUb+/IkooorzzuCiiigAooooAK5/xl/yA7b/sK6b/AOls NdBXP+Mv+QHb
f9hXTf8A0thoA6CiiigAooooAKKKKAOfs/8Akoes/wDYKsP/AEbd10Fc/Z/8 lD1n/sFWH/o2
7roKACiiigAooooAKKKKACuY+IH/ACKn/cQsP/SyGunrmPiB/wAip/3ELD/0 shqofEiZfCzK
ooor3DxgooooAKKKKACiiigAooooAKKKKACiiigDc8Cf8k88Nf8AYKtf/RS1 0Fc/4E/5J54a
/wCwVa/+ilroK8E9sKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA qhrOqwaJpU1/
OruqFUSNB80kjsERB2BZmVcnAGckgZNX64TxDcjVvFiWykm20YZbnhrqROPQ /JE/uD5/YpWl
KHPNRIqT5IuRT063nhtmkvWR7+5cz3boSVMrckKTzsXhFzyEVR2q3RRXspJK yPIbbd2FFFFM
QUUUUAFFFFABRRRQAUUUUAFFFFAFzwbeixlk8OTE/IJLjT+4Ntldye3lvIFC 4ACGMDJDY7Cv
NtRS4RIL6xj8y+sJRc26ZA8xgCGjyeBvRnj3HO3fu6gV6DYX1vqenW1/ZyeZ a3USTQvtI3Iw
BU4PIyCOteTiaXJPTZnqYepzw13RYooornNwooooAKKKKACiiigArk9X8Jyp dS6joLRx3ErF
p7O4ldbeYk5LDAbynySxKqQ5J3Akhl6yiqjOUHeJMoqSszzWPU0F2llfW9xp 185IS2vFCNJg
ZPlsCUkwME7GbGRnB4q9XaX1hZ6nZyWd/aQXdrJjfDPGJEbBBGVPBwQD+Fc1 c+BkhJfQ9Tn0
4dVtZEE9qDnn5Dh1AHARHRVwML1B7YY3pNHHPCfysoUVFJYeKbVd8+h2typO AmnagJJAfUiZ
Il2/RickcdSI/wDif/8AQo6t/wB/7P8A+P10rEUn1MHQqLoWaKgjg8RXDeVH 4ZureQj5ZL26
t1hH+8Y5JHHGcYRucZwMkXoPCWt3g3ajrEWnqRnydMiEjqegzNKpDKRk48pS CQM8HdMsVSXW
444ao+hQvL61sI0e6mWMO4jjXq0jnoiKOWY44UAk9hVuw0DUdcAmvWm0zTWA ZIom23M6ntJl
cwqRnhT5nzDmNlKno9K8M6LosxnsNPiS6ZCj3b5kuHUkHDSuS7DgcEnGAOgF a1clXFynpHQ6
6eGjHWWpWsLC10uxis7OIRQRg7VySSSckknlmJJJYkkkkkkmrNFFch0hRRRQ AUUUUAFFFFAB
XP8AjL/kB23/AGFdN/8AS2Gugrn/ABl/yA7b/sK6b/6Ww0AdBRRRQAUUUUAF FFFAHP2f/JQ9
Z/7BVh/6Nu66Cufs/wDkoes/9gqw/wDRt3XQUAFFFFABRRRQAUUUUAFcx8QP +RU/7iFh/wCl
kNdPXMfED/kVP+4hYf8ApZDVQ+JEy+FmVRRRXuHjBRRRQAUUUUAFFFFABRRR QAUUUUAFFFFA
G54E/wCSeeGv+wVa/wDopa6Cuf8AAn/JPPDX/YKtf/RS10FeCe2FFFFABRRR QAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAV5d4dme90O21SY7rrUkF9cN1y8gDYBPO1QQigk kKqjJxXY+O/+
SeeJf+wVdf8Aopqw67sEtWzjxj0SCiiivQOA5vVfH3hnRNSl0/UdT8m6ixvj 8iRsZAI5VSOh
FaGieI9I8RQPNpN7HcpGcOACrL6ZUgEflXFp4n0Xw58RvFf9sXfkeeLPyv3L vu2xHP3QcfeH
Wm6TrFnqXijxF4l0ER/Y7XS/Lbcu3zpgS4crw2MDGTjNc6qu9rrd6dTd0lbZ 9PQ9KrKu/Emk
2H9o/abvZ/Zyxvdfu3Plh/udBzn2zWVqPiW8tPh1beIY4oDdy29rKyMp8vMj IGwM5x85xz6d
awfG2pPc6X42sGggRLSCzKyImHfecncc84xx+NXOpZaf1o/8iYU7vX+tv8z0 iqlvqVpdX95Y
wzbrmzKCdNpGwuu5eSMHI9M1ieINc1WHWbTQ9AtrSXUZoWuJHu2YRRRA7cnb ySTxxWd4Jubq
78VeK5b23W3uvNtkljVtyhli2kg+hxkexFN1PeUV/WglD3XJnb0VzWteJJvD /iKzj1AQJol3
Gyi5wQ0UyjOGOcYIBxxnNZMvjLWYPClprrafAftuoJHbWwVg5t2bC5O7G8gZ B6cjim6kVdAq
cmd3VS+1K000W5u5fLFxOlvF8pO6RzhRwOM+p4rjv+Ej8Yx602gyaZpR1KeE XNvKkr+RFHkh
vM/iJBwOMdaqX+t3Ot6RpBvreOC+s/E1vaXKRElN6P1XPOCCKl1VbQapO+p6 PRRRWpkFaPgO
Zxp+p6dnMGm37W9vnqsbRRzBfQBTKUUAABVUdsnOqbwl/wAjnrv/AGD7H/0Z dVyYyN6dzqwj
tOx21FFFeYeiFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAFc/4y/5Adt/2FdN/9LYa6Cuf8Zf8gO2/7Cum/wDpbDQB0FFFFABRRRQA UUUUAc/Z/wDJ
Q9Z/7BVh/wCjbuugrn7P/koes/8AYKsP/Rt3XQUAFFFFABRRRQAUUUUAFcx8 QP8AkVP+4hYf
+lkNdPXMfED/AJFT/uIWH/pZDVQ+JEy+FmVRRRXuHjBRRXNa540tdD1lNKOl 6rfXTW4udtjb
iXCFiuT8wPUencUpSUVdlKLk7I6WisLw/wCK7DxFLcQQw3dpd22DLa3kXlyq D0OMnit2hSUl
dCaadmFFFUdO1OPUmvBHDPH9kuWtm81QN7KAdy88rz1+tO4WL1FFFAgoqt9v tTqR07zl+1iE
TmLvsJ27vzBFWaBhRRRQI3PAn/JPPDX/AGCrX/0UtdBXP+BP+SeeGv8AsFWv /opa6CvBPbCi
iigAooooAKKKKACiiigAoorHvvFWhafeSWU2pwPfpjNjATNcnIB4hTMh4O7h eBz05oA2KK5/
/hINRvONJ8OX0qv/AKu5v2WzhOOu5WzOvQgZh5OP4Tuo+yeKb7/j51Sx0uF/ vRWFuZ5o8dNs
8vyHJGTmDgEgcgPQB0FY994q0LT7ySym1OB79MZsYCZrk5APEKZkPB3cLwOe nNV/+EP064+b
Vp77V2b/AFi39yzQy+m63XbBxxjEY5Ab73NbFjYWemWcdnYWkFpax52QwRiN FySThRwMkk/j
QBj/APCQajecaT4cvpVf/V3N+y2cJx13K2Z16EDMPJx/Cd1H2TxTff8AHzql jpcL/eisLczz
R46bZ5fkOSMnMHAJA5AeugooA4Pxp4WtF8C+Ibq9vNS1G5TTLl993dv5bMsT FSYE2w5XAIIQ
YKhvvfNRXcTwQ3VvLb3EUc0EqFJI5FDK6kYIIPBBHGK808PmYaHbQXMrS3Vp us7iVmLeZLCx
ikYE8kFkYgnkgjIB4ruwT1aOPGLRM06KKK9A4DzdfFejeGPiP4r/ALXuzb/a BZ+ViJ33bYjn
7oOPvCksNvijxB4h1jRraRdPn0lrNZWjMYuZzk7gD1wMDNek0Vl7N9Xoa+0X Ranj2p+KrO8+
GdrodtFcNfW0drDextCy/Z9joMsSMcsAABzzVzxb/wA1E/69tP8A616rRUui 3u/6s/8AMr2q
Wy/rT/I4rX72Lw145tdfvxIumT6e1jJOkZcQuJN6lgATg5IrL0TxVZ2eo+Mv EN3DcRWfm2hC
+X85UoFRtp9QQfoa9JoqnTd7pkqatZo4PxzDJ4q1C38H2bqjMhvLuYrnyVUE IPqzEe+PrVCX
WW1bwz4dS4jEV/Z69aWl3CBjZIj4PHoeD+PtXpdFDpXbd9wVSyStscq3/JWY v+wG/wD6PWuU
f/lv/wBjzH/7JXqtFEqd+oKpboFFFFamQVN4S/5HPXf+wfY/+jLqoav+BIfM g1bVCFP2u/eO
Jj99Y4QISh9B5qTMADj95ngsRXLjHanY6sIrzudbRRRXlnohRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXP8AjL/kB23/AGFdN/8A S2Gugrn/ABl/
t3XQUAFFFFABRRRQAUUUUAFcx8QP+RU/7iFh/wClkNdPXMfED/kVP+4hYf8A pZDVQ+JEy+Fm
VRRRXuHjBXnuua0ND+Ky3J07UL7fogj8uxg81x+/Y5IyOOOvuK9CrlhaXP8A wtY3n2eX7L/Y
gi8/Ydm/zydu7pnHOKzqJtK3c0ptK9+xjWc+o6jr2teLBpt3pcEGkta263kY SSRwTJvKnPTG
P8mpdP1/X9P8Ez+KNanhmjayie2tUjAO8gAMzAD75IOBwM8V12uRvL4f1KOJ GeR7WVVVRksS
hwAO5rnptCutW+FFro4Vobw6bbhUkG0rIiowVgenzLg+lQ4yWz6P7y1JPddv uK8V74o8P6lp
L67qNvfWmpzi2kjjtxGbWVgSgUj7wyCMmq1x4w1Gz03V8zwNdHXW02ye4AWO FdqkFsYyFG45
PNPa61bxfqWi2s2hX2mxWF0l5eTXSBULxg7VjOfnBY9fSsqTR5tV0/XJrezj vpLDxRJdG0kA
InQIgZOeOQf0qG5fZuUkvtGzouuahZ+J7PSr/wAQ2OuQ6hHIY5bdER4ZEG7a QhIKkZwTzkVX
i1Lxfr2nXPiLRr63is0kf7Jpptg5ukRiMs55BODgCrGgRRX/AIitrnT/AAbH otlbI5mnu9Pj
hmdyMBY8cgDJye/SqGn3fiDwvocnhez0K9nvYpJI7G+SMNblGYlXduikbuhH ai7tq3b5+X/B
Cyvolf5Fm2t9Tm+LIuG1J4kbSY52t2t0ysZkI8kn2bJ3de3SvQK45heWHxIs 57i1uriO50lb
Q3UMOUEqyMxLEcKMH9a7Gtqatf1Mqjvb0CiiitDM3PAn/JPPDX/YKtf/AEUt dBXP+BP+SeeG
v+wVa/8Aopa6CvBPbCiise+8VaFp95JZTanA9+mM2MBM1ycgHiFMyHg7uF4H PTmgDYorn/8A
hINRvONJ8OX0qv8A6u5v2WzhOOu5WzOvQgZh5OP4Tuo+yeKb7/j51Sx0uF/v RWFuZ5o8dNs8
vyHJGTmDgEgcgPQB0FY994q0LT7ySym1OB79MZsYCZrk5APEKZkPB3cLwOen NV/+EP064+bV
p77V2b/WLf3LNDL6brddsHHGMRjkBvvc1sWNhZ6ZZx2dhaQWlrHnZDBGI0XJ JOFHAyST+NAG
P/wkGo3nGk+HL6VX/wBXc37LZwnHXcrZnXoQMw8nH8J3UfZPFN9/x86pY6XC /wB6KwtzPNHj
ptnl+Q5IycwcAkDkB66CigDn/wDhD9OuPm1ae+1dm/1i39yzQy+m63XbBxxj EY5Ab73NbFjY
WemWcdnYWkFpax52QwRiNFySThRwMkk/jViigAooooAKKKKACiiigArgtZtT pXi6dzn7NrAE
6Of4biNFRkzwOY0jZRyTsmPQCu9rL1/Rk1zTfs3m+RPHIs1vOE3GKRTkHHBw RlWAIJVmXIzm
tKVTkmpGdWHPFxOXoqtY3T3Vv/pEBtryM7Lq2ZstBLgEoT36gg9GBDDIINWa 9lNNXR5LTTsw
ooopiCiiigAooooAKKKKACiiigAooooAqajcTw2yx2So9/cuILRHBKmVuAWA 52Ly7Y5CKx7V
3ek6bDo2jWOl27SNBZW8dvG0hBYqihQTgAZwPQVy/hWwOqagNfmU/ZYA0enA jKyhlXdcDP8A
wJEIA+UuQWWQY7SvKxVXnnZbI9PDU+SN3uwooormOgKKKKACiiigDlPFWt6x Yazpmn6TJYxf
abe4nkku7Z5v9W0KgALImM+aeTnoKzP7Z8Yf9BLQ/wDwVTf/ACTVjxb/AMjn oX/YPvv/AEZa
1DXoYehTnC8kcNetOE7RY3+2fGH/AEEtD/8ABVN/8k0f2z4w/wCglof/AIKp v/kmnUVv9Vpd
vzMfrNXuN/tnxh/0EtD/APBVN/8AJNH9s+MP+glof/gqm/8AkmnUUfVaXb8w +s1e43+2fGH/
AEEtD/8ABVN/8k0f2z4w/wCglof/AIKpv/kmnUUfVaXb8w+s1e43+2fGH/QS 0P8A8FU3/wAk
0f2z4w/6CWh/+Cqb/wCSadRR9VpdvzD6zV7nUeGtSm1nwrpGqXCxrPe2UNxI sYIUM6BiBkk4
yfU1qVz/AIE/5J54a/7BVr/6KWugryD1AooooAKKKKACiiigAooooAK5/wAZ f8gO2/7Cum/+
lsNdBXP+Mv8AkB23/YV03/0thoA6CiiigAooooAKKKKAOfs/+Sh6z/2CrD/0 bd10Fc/Z/wDJ
Q9Z/7BVh/wCjbuugoAKKKKACiiigAooooAK5j4gf8ip/3ELD/wBLIa6euY+I H/Iqf9xCw/8A
SyGqh8SJl8LMqiiivcPGCiiigAorm/GWtanotlpv9kx2j3d7qEdmv2oMUG8N ydpB6gevfise
+8QeMvDcKajr1nos2mLIiTtYNKJIwxA3fPweSOKiVRJ2Zoqba0O6kVmjdUfY 5BCtjOD64rI8
NaC+gWNxFNete3NzcvdXFw0YTe7YBIUcAYA4rZoqrK9yLu1goorM0XWU1lL5 khaL7Jey2hyc
7jGcbvxour2C3U06KKKYgooooAPBetanJ4F8PW+m+HbubbplsiXV3NHb27FY lDZ5aUDggERE
McEfKd1bn2TxTff8fOqWOlwv96KwtzPNHjptnl+Q5IycwcAkDkB6PAn/ACTz w1/2CrX/ANFL
XQV4J7Zz/wDwh+nXHzatPfauzf6xb+5ZoZfTdbrtg44xiMcgN97mtixsLPTL OOzsLSC0tY87
IYIxGi5JJwo4GSSfxqxRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFAHN+JdDnu
biLV9OQPewRNFJb5C/aoiQdu44+dSCU3Hb87g7d5dcK2uYruBZoWJQkjlSrK QcFWB5VgQQQQ
CCCCARXoNc9rPhODUbmS/sbqXTtSfG6aP545cDAEkRO1uAoLDa+FADgDFdWH xHs/dlsc1ehz
6rcxKKqfa5La9TT9Vt/sF/JnyonkVluAPvNCwPzgYJwQGAwWVdwzbr04yUle J58ouLswooop
khRRRQAUUUUAFFFRXNzFaQNNMxCAgcKWZiTgKoHLMSQAACSSAASaNh7ktR2e lt4nuDBjGkQy
gXUpGRcsjZMCg8MuRtkJyMbkGSWMduw8MXesL5+sm80+2zhdPhnVJH/2pZYy SvOCqxuOB8xb
cUXsYIIbW3it7eKOGCJAkccahVRQMAADgADjFefXx
Previous Topic:RE: [stp-newsgroup] from IRD today
Next Topic:RE: [stp-newsgroup] Reminder of weekly IRC
Current Time: Tue Jun 18 02:52:04 EDT 2013
Powered by FUDForum. Page generated in 0.01718 seconds
