Home » Archived » IAM (Eclipse Integration for Apache Maven) » java version used by IAM?
java version used by IAM? [message #571053] Thu, 29 October 2009 17:24 Go to next message
Ashish Joshi is currently offline Ashish Joshi
Maven uses the JAVA_HOME for all execution activities.
What is the corresponding Java Runtime environment that IAM uses during execution?
I am using IAM 0.9 within RAD 7.5.
The "Installed JRE" in preferences is pointing to 1.5. version.
The Java_Home is pointing to 1.5 JDK version
The compiler plugin within POM is configured to use 1.5 version
However when enforcer:display-info goal is executed, it shows up the jdk as 1.6 version. The output line is
JDK Version: 1.6.0 normalized as: 1.6.0
RAD itself runs with a JRE of 1.6. So is that the one that is being picked up?
Is there a way to configure IAM to use a specific JRE?
Ashish
Re: java version used by IAM? [message #571074 is a reply to message #571053] Fri, 30 October 2009 14:01 Go to previous message
Carlos Sanchez is currently offline Carlos Sanchez
IAM uses the same Java that Eclipse is running, because it runs Maven
in-process, without forking the JVM
You can configure some plugins to fork and use different Java version,
like the Compiler or Surefire plugins if you need to.
http://maven.apache.org/plugins/maven-compiler-plugin/exampl es/compile-using-different-jdk.html
http://maven.apache.org/plugins/maven-surefire-plugin/test-m ojo.html#jvm
Some previous info about it
http://groups.google.com/group/q4e-users/msg/75884e3cf07d8f5 b
On 10/29/09 2:24 PM, Ashish Joshi wrote:
> execution?
> picked up?
> Ashish
Previous Topic:java version used by IAM?
Next Topic:Picking up wrong version of dependency if dependent project open
Current Time: Sun May 19 23:15:32 EDT 2013
Powered by FUDForum. Page generated in 0.02078 seconds
