Home » Eclipse Projects » Eclipse Examples » SWT Examples Source missing
SWT Examples Source missing [message #570063] Tue, 13 April 2010 12:49 Go to next message
Khurshid  is currently offline Khurshid
Hi Everyone,
I have downloaded eclipse-examples-3.5.2-win32.zip and it has no source file in it.
I can install examples and I confirmed that by going to Window -> Show View -> Other -> SWT Examples. I can even run them. But the problem here is how to run them as a project. I cannot view any java files.
Can anyone help me please?
Khurshid
Re: SWT Examples Source missing [message #570084 is a reply to message #570063] Tue, 13 April 2010 16:09 Go to previous message
Wayne Beaton is currently offline Wayne Beaton
If I understand correctly, you've installed the contents of this ZIP
into your Eclipse configuration. If this is true, then you should be
able to open the "Plug-ins" view, right-click on
org.eclipse.swt.examples and select "Import As > Source Project". This
should create a new project for you containing the source.
HTH,
Wayne
Khurshid wrote:
> Hi Everyone,
> file in it.
> Khurshid
Previous Topic:SWT Examples Source missing
Next Topic:how to create a interface using Eclipse
Current Time: Fri May 24 19:34:10 EDT 2013
Powered by FUDForum. Page generated in 0.01610 seconds
