| Re: Galileo SR2 Source for development [message #568575 is a reply to message #568522] |
Sat, 22 May 2010 14:43  |
David Williams Messages: 176 Registered: July 2009 |
> I am trying to locate the entire source package for the Galileo SR2. ...
The EPP packages are meant to me ready-to-go packages that consist
of contributions from many Eclipse projects and often don't
contain source (the reason being, is that it
would double the size in many cases).
The one you named is for C++ development. Is that what you wanted?
If you wanted the source for CPP related code, you could search for
the Eclipse CPP project, and get its source directly.
(BTW, its generally recognized we don't have a very good solution
to satisfy both audiences, those wanting minimum to get their work
done, and those wanting source).
FUDForum. Page generated in 0.06774 seconds
