| Help with Rational Requirements Composer [message #568272] |
Sun, 09 May 2010 03:12  |
No real name Messages: 6 Registered: May 2010 |
Junior Member |
Hello, I'd like to install RRC 2.0.0.1 Cliente on my laptop on Linux Ubuntu 32 bit, but I met a problem.
I followed the guide on the official site, but it doesn't work.
The guide is on "jazz.net":
1. Download the Rational Requirements Composer Client and Server .zip files (Part 1 and 2 for the server, Master and Main for the client) from the All Downloads tab.
2. Extract the contents of the downloaded .zip files into a temporary location, so that you have the following directories: RRCS and RRCS_SETUP for the server, and RRCC and RRCC_SETUP for the client.
3. Go to the RRCS_SETUP directory and execute launchpad.exe (on Windows, or launchpad.sh on Linux) to launch IBM Installation Manager v1.3.2., which will install Rational Requirements Composer Server.
4. Go to the RRCC_SETUP directory and execute launchpad.exe to install Rational Requirements Composer Client.
I only need to install the client, because the server one is on my university's server.
I extracted the zip files of the client in the same directory; later, using the terminal, i compiled the .sh file by the instruction "chmod +x launchpad.sh", but when I try to execute the sh file it returns me some errors, and they are:
> ./launchpad.sh
> cp: impossibile fare stat di `/callback.sh': No file or directory
> cp: impossibile fare stat di `/changeDirectory.sh': No file or directory
> .: 86: Can't open /tmp/IBM_LaunchPad_2263/launchpadExports
I tryed even by making it by administrator using "sudo", but id always returned me the same error.
I use Ubuntu LL 10.04 32 bit.
Can somebody help me?
Thanks a lot, Bye.
FUDForum. Page generated in 0.02208 seconds
