| Eclipse Galileo on Kubuntu 9.10 [message #568225] |
Thu, 07 January 2010 10:48  |
Juan Damián Bernabé Messages: 2 Registered: January 2010 |
Junior Member |
Hi everybody,
I'm Trying to run eclipse ganymede on Kubuntu 9.10. I've downloaded it already and uncompressed on my home folder. when I execute eclipse the eclipse splash appear, but, eclipse doesnt start, instead, a non-text windows appear. I can't close that window even if I click on the x windo button. To close that I had to use ctrl+c on the console.
On the console appears the following when I execute the command "./eclipse"
(eclipse:5093): GLib-WARNING **: g_set_prgname() called multiple times
What can be happening?
by the way, compiz effects are active.
Thnx!
JCrx,
| Re: Eclipse Galileo on Kubuntu 9.10 [message #568315 is a reply to message #568265] |
Wed, 27 January 2010 13:38  |
Eric Rizzo Messages: 2011 Registered: July 2009 |
gia wrote on Sat, 16 January 2010 11:58
> I have the similar problem with the similar warning message since I've upgraded my kubuntu to 9.10. In general, Galileo still works (it was perfect with kubuntu 9.04) but I can't do some essential operations anymore like creating new projects, refactoring some variable names, exporting preferences and many others. For example, if I want to create a new bzr project and I select let's say "Branch as a new project" and then push the "next" button it doesn't respond at all. Is there any solution for this problem? Thanks.
> Cheers, Gia
See http://www.eclipse.org/forums/index.php?t=msg&th=161210& amp;start=0&
FUDForum. Page generated in 0.01696 seconds
