Home » Eclipse Projects » P2 » After migrating to Eclipse Helios, updating my RCP fails
After migrating to Eclipse Helios, updating my RCP fails [message #568084] Wed, 28 July 2010 16:48 Go to next message
Tobias Hoppenthaler is currently offline Tobias HoppenthalerFriend
After migrating my RCP app to eclipse helios I seem to be unable to update. When I click Help>Check for Updates I get the message
Cannot complete the request. This installation has not been configured properly for Software Updates. See the error log for details.
The error log contains the following:
!ENTRY org.eclipse.equinox.p2.ui.sdk.scheduler 4 0 2010-07-27 10:14:11.773
!MESSAGE The update checker service is not initialized
I also noticed that when I click Help>About and then in the about dialog I click Installation Details, I get an NPE and the log says:
!ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2010-07-27 10:17:18.920
!MESSAGE Could not locate the running profile instance. The eclipse.p2.data.area and eclipse.p2.profile properties may not be set correctly in this application's config.ini file.
!ENTRY org.eclipse.ui 4 0 2010-07-27 10:18:10.873
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.equinox.internal.p2.ui.ProvUIActivator.addProvis ioningListener(ProvUIActivator.java:106)
at org.eclipse.equinox.internal.p2.ui.dialogs.InstalledIUGroup. createViewer(InstalledIUGroup.java:75)
at org.eclipse.equinox.internal.p2.ui.dialogs.StructuredIUGroup .createGroupComposite(StructuredIUGroup.java:80)
at org.eclipse.equinox.internal.p2.ui.dialogs.InstalledIUGroup. <init>(InstalledIUGroup.java:51)
at org.eclipse.equinox.p2.ui.InstalledSoftwarePage.createContro l(InstalledSoftwarePage.java:95)
at org.eclipse.ui.internal.about.InstallationDialog.tabSelected (InstallationDialog.java:274)
at org.eclipse.ui.internal.about.InstallationDialog.createConte nts(InstallationDialog.java:245)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at org.eclipse.ui.internal.dialogs.AboutDialog$1.run(AboutDialo g.java:126)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.dialogs.AboutDialog.buttonPressed(Ab outDialog.java:121)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:234)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.about.AboutHandler.execute(AboutHand ler.java:32)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:820)
at org.eclipse.ui.menus.CommandContributionItem.access$19(Comma ndContributionItem.java:806)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(C ommandContributionItem.java:796)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at com.company.Application.start(DiflowApplication.java:41)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
!ENTRY org.eclipse.core.jobs 4 2 2010-07-27 10:18:10.874
!MESSAGE An internal error occurred during: "Fetching children of _SELF_".
!STACK 0
at org.eclipse.equinox.internal.p2.ui.model.ProfileElement.getQ ueryable(ProfileElement.java:55)
at org.eclipse.equinox.internal.p2.ui.QueryProvider.getQueryDes criptor(QueryProvider.java:54)
at org.eclipse.equinox.internal.p2.ui.model.QueriedElement.fetc hChildren(QueriedElement.java:102)
at org.eclipse.equinox.internal.p2.ui.model.RemoteQueriedElemen t.fetchDeferredChildren(RemoteQueriedElement.java:34)
at org.eclipse.ui.progress.DeferredTreeContentManager$1.run(Def erredTreeContentManager.java:235)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
I found this:
http://www.eclipse.org/forums/index.php?t=tree&th=171233 &
and did as suggested, but the problem remained like before
PLEASE HELP!
-- Tobias
-- Tobias
Re: After migrating to Eclipse Helios, updating my RCP fails [message #658123 is a reply to message #568084] Sun, 06 March 2011 18:31 Go to previous message
Antonel Ernest Pazargic is currently offline Antonel Ernest PazargicFriend
Member
The p2 helios requires a proper configuration of the product in terms of
declarative service.
So add
<plugin id="org.eclipse.equinox.ds" autoStart="true" startLevel="2" />
in configurations element (*.product or p2.inf file)
For more details see also
http://wiki.eclipse.org/Equinox/p2/Helios_Migration_Guide#De fault_Agent_and_Declarative_Services
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/p2_overview.htm
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. pde.doc.user/tasks/pde_p2_configuringproducts.htm
jtonic
On Wed, 28 Jul 2010 19:48:35 +0300, Tobias Hoppenthaler
> 10:14:11.773
> !STACK 0
> java.lang.NullPointerException
> g.java:126)
> .java:70)
> outDialog.java:121)
> ner.java:234)
> ler.java:32)
> rProxy.java:293)
> java:476)
> (Realm.java:332)
> bench.java:663)
> tarter.java:369)
> tarter.java:179)
> _SELF_".
> !STACK 0
> I found this:
> PLEASE HELP!
Respect
jtonic
Previous Topic:Problems during first steps with p2.gathering=true
Next Topic:config.xml generated by DirectorApplication
Current Time: Sat Jul 22 09:02:54 GMT 2017
Powered by FUDForum. Page generated in 0.03374 seconds
