Have you used the e4 Wizard to create an e4 application project? If you use
it, you will not run into this problem.
The problem is the menu is created in children. It should be mainMenu.
<mainMenu>
<children xsi:type="application:MenuItem" label="File">
</children>
</mainMenu>
I suppose you have created using EMF Reflective Editor.
Yves
"Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
news:hj5g0d$bst$1@build.eclipse.org...
> I want to add a menu to my minimal e4 application but the menu is not
> displayed.
> I compared with the contact demo (which I also reduced for this purpose)
> but I cannot see any difference.
> The Application.xmi is like the following.
> <?xml version="1.0" encoding="ASCII"?>
> <application:Application xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:application="http://www.eclipse.org/ui/2008/UIModel"
> id="Application">
> <children xsi:type="application:Window" label="My first e4 application"
> iconURI="" tooltip="" id="Window" onTop="true" width="200" height="200">
> <children xsi:type="application:Part" id="View1" style="" URI="
> platform:/plugin/de.vogella.e4.rcp.first/de.vogella.e4.rcp.f
> irst.parts.View1 " containerData="" label="Hallo" tooltip=""/>
> <children xsi:type="application:Menu" id="">
> <children xsi:type="application:MenuItem" id="" label="File">
> <children xsi:type="application:DirectMenuItem" URI="
> irst.handlers.ExitHandler " label="Exit"/>
> </children>
> </children>
> </children>
> </application:Application>
> Advice would be welcome.
> Best regards, Lars
news:hj7rg0$6qm$1@build.eclipse.org...
> Hi Yves,
> thanks for the answer; it works now with your help. Sorry, I oversaw the
> obvious difference.
> I'll update soon my e4 tutorial so that other do not have to make the same
> error. Once I updated it I'll post to this thread.
> http://www.vogella.de/articles/EclipseE4/article.html
I'll update the wizard today to have an example with Perspectives, ToolBar
and Menu together.
On 20.01.2010 13:25, Yves YANG wrote:
> "Lars Vogel"<Lars.Vogel@gmail.com> wrote in message
>> Hi Yves,
>> obvious difference.
> and Menu together.
> yves
> Hi Yves,
> obvious difference.
and Menu together.
>> Hi Yves,
>> obvious difference.
> and Menu together.
> yves
