| packaging problem [message #567927] |
Thu, 13 November 2008 07:49 |
Andrei Ivanov Messages: 4 Registered: July 2009 |
Junior Member |
I'm using Q4E 0.8.0 with Eclipse 3.4.1 and I'm having a packaging
problem...
I have 2 modules, 'api' and 'model' using JDK 1.5 and retrotranslator
activated.
These seem to be fine, the JDK 1.4 artifacts are being created and
installed in the local repository (using 'Locally install artifact').
Another module, 'portal' depends on these 2 modules and specifies the 'j4'
classifier for them.
AFAIS, when running 'Package artifact' from Eclipse, the JDK 1.5 modules
are being used and the 'j4' classifier is being added to them(which
confused me and made me think at first the retrotranslator wasn't working).
When using Maven from the command line, the proper jars are used.
I suppose the problem comes from the fact that Q4E detects that the
projects of the first 2 modules are present in the workspace and uses
them...
Is there anything I can do?
FUDForum. Page generated in 0.02058 seconds
