Home » Eclipse Projects » DSDP - Mobile Tools for Java (MTJ) » How to add a jar file to the Midlet in MTJ?
How to add a jar file to the Midlet in MTJ? [message #567831] Fri, 14 November 2008 08:39
Francisco is currently offline Francisco
I am using MTJ and WTK 2.5.2. I have problems adding a jar file to my
midlet suite. I add the jar file to the res folder and I add it to the
build path. However, when I run the midlet it throws a
NoClassDefFoundError.
I have tried also exporting the jar file in the Build Path by checking the
jar file in the order and export option. But then, Eclipse shows errors on
my jar file and in the Problems window I get the following message:
Error preverifying class net.jxta.impl.endpoint.tcp.TcpConnection
jxta-cldc.jar FirstJXTAMidlet/res
Do you know how can I solve this problem?
Thanks in advance,
Fran
Previous Topic:Invoking a Web Service from an EclipseMe Cient
Next Topic:Help: WTK2.5.2 + MTJ 0.9 + Eclipse 3.4.1 + JRE6_10
Current Time: Tue May 21 08:48:18 EDT 2013
Powered by FUDForum. Page generated in 0.01757 seconds
