| Re: How to export metrics from the Metrics plug-in [message #567408 is a reply to message #567319] |
Tue, 12 January 2010 08:58  |
Stephan Herrmann Messages: 779 Registered: July 2009 |
Arlindo wrote:
> Is it possible to export the metrics calculated with the Metrics Plug-in
> (to Excel or XML)?
> Thanks.
Some time ago we started implementing an extra plugin for exporting metrics
for BIRT reporting.
Unfortunately this plugin no longer works with the current metrics plugin.
You might want to have a look at the sources at
http://trac.objectteams.org/ot/browser/tags/releases/OTDT_1. 0.0/org.objectteams.otdt.metrics.export/export
Here you will see a simple XML export (MetricsResultAccessor) plus an
action to invoke the export (ExportAction). One incompatibility I see
right away: the source reference classes ObjectFactory and OTMetricsResult
which I can't seem to find in the repository. So this is not in a good
shape.
In case you'd like to give it a try and re-vive the export function,
I'd be happy to integrate this into the metrics plugin for the next
milestone. I'll also try to get help from the original authors...
best regards,
Stephan
FUDForum. Page generated in 0.06877 seconds
