Home » Language IDEs » Objectteams » ClassCastException when instanceof is true
ClassCastException when instanceof is true [message #567144] Sat, 09 January 2010 13:04 Go to next message
Eugene Hutorny is currently offline Eugene Hutorny
The following code fails with ClassCastException on casting to Actor
Object[] roles = getAllRoles();
for(Object role : roles) {
if( role instanceof Actor) {
Actor server = (Actor) role;
The role class does not implement Actor interface but inherits its implementation from the super class
The problem disappears after adding clause 'implements Actor' to the concrete role class.
Complete sources to reproduce the problem are available on this http://hutorny.in.ua/wp-content/uploads/2010/01/exer8.zip
Re: ClassCastException when instanceof is true [message #567202 is a reply to message #567144] Sun, 10 January 2010 11:19 Go to previous message
Stephan Herrmann is currently offline Stephan Herrmann
Thanks for the report.
I've filed https://trac.objectteams.org/ot/ticket/333
Explanation for the curious: the two statements internally
use different versions of role Actor:
The instanceof check uses Service.Actor, this check passes.
The cast is internally translated as a call to a dynamically bound
synthetic method which then attempts a cast to Shaving.Actor,
which wrongly fails (due to a missing "implements" link in the
generated byte code).
Of course, this difference concerning Service.Actor and
Shaving.Actor shouldn't surface here.
best,
Stephan
Previous Topic:Suggestion on callin bindings
Next Topic:ClassCastException when instanceof is true
Current Time: Sat May 18 18:28:37 EDT 2013
Powered by FUDForum. Page generated in 0.02382 seconds
