Home » Eclipse Projects » Eclipse 4 » Product launch results in error
Product launch results in error [message #564725] Tue, 17 November 2009 16:58 Go to next message
Tom is currently offline Tom
I updated a small example (like the contacts demo) but when I launch the application now, i get an error. Any idea what I'm missing?
Tnx in advance for the answer !
This is the stacktrace:
java.lang.RuntimeException: Application "org.eclipse.e4.workbench.ui.internal.E4Workbench.init" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.e4.ui.workbench.swt.application, org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.equinox.app.error.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:367)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 611)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:566)
at org.eclipse.equinox.launcher.Main.run(Main.java:1363)
at org.eclipse.equinox.launcher.Main.main(Main.java:1339)
Re: Product launch results in error [message #564746 is a reply to message #564725] Wed, 18 November 2009 10:38 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
It seems to me you should be using one of org.eclipse.e4.ui.workbench.swt.application, org.eclipse.e4.ui.workbench.swt.E4Application to launch an e4 RCP app (based on an Application.xmi, for example).
PW
Paul Webster
Re: Product launch results in error [message #566914 is a reply to message #564746] Tue, 29 December 2009 14:25 Go to previous message
Ankur Sharma is currently offline Ankur Sharma
Member
> PW
I am facing the same issue. I am indeed using org.eclipse.e4.ui.workbench.swt.E4Application to
launch the rcp app.
In fact,I created a new project, copied everything from contacts demo project. updated manifest
accordingly and created a new product same as contacts.product. But it still throws the NPE. Badly
missing a silver bullet.
Ankur..
Eclipse PDE UI Committer | IBM India Software Lab, Bangalore
+91-99456-94011 | @ankur_sharma | http://blog.ankursharma.org
Previous Topic:XWT + DataBinding +DataContext +Replace
Next Topic:XWT + DataBinding + TableViewer +Image
Current Time: Wed May 22 10:26:16 EDT 2013
Powered by FUDForum. Page generated in 0.02232 seconds
