| Translation of <?> in .NET [message #566497] |
Thu, 18 September 2008 05:35 |
Alex FAU Messages: 15 Registered: May 2010 |
Junior Member |
(I re-post here a message from a list in Sourceforge)
In the current version of the translator I only support ot when it's a
parameter of a method :
public void method(List<?> list) --> public void Method<T>(List<T> list)
where T : class
public void method(List<? extends Object> list) --> public void
Method<T>(List<T> list) where T : class
public void method(List<? extends OtherType> list) --> public void
Method<T>(List<T> list) where T : OtherType
As you see I translate it into a generic method with constraint.
If you use <?> in a body I don'y modify it and the resulting buffer does
not compile in Visual Studio.
1/ List<?> myList = ...;
My point on this usage is :
If ? stand for "java.lang.Object" -> use the non generic version of list
instead (at least if you want to make your code translatable). BTW, it's
very frequent to see "Hashtable<String, ?>".
Otherwise ... do you really need to create a collection of you don't know
what ???
I mean the code I see frequently is :
List<?> myList = getList();
for(Object item : myList) {
SomeType myTypedItem = (SomeType) item;
And here the generics are useless ...
2/ List<? extends SomeType> myList = ...;
Ok that one is more "legitim" and I have no way to translate it in C#.
So, is it possible to introduce a generic parameter to the method/the
class that contains the statement in order to put the constraint on that
parameter and rewrite the list List<MyParameter> ?
Any ideas ? Comments ?
FUDForum. Page generated in 0.01508 seconds
