Home » Modeling » Epsilon » Problems View not Showing Markers from EVL
Problems View not Showing Markers from EVL [message #566443] Mon, 06 April 2009 17:12
Ken Sayers is currently offline Ken Sayers
Member
I have a validation written in EVL. I've followed the tutorial the best I
could, but my situation has a few complications.
We are using two models simultaneously. One is a common model. It
contains some base classes and some reusable classes. It is not intended
to be diagrammed, but instead provide reusable objects pointed to by
multiple other models. Let's call them reusing models. The reusing
models have a different meta-model which has references to the common
model.
At the end of the day, we have an emf editor for the common model and a
gmf editor for the reusing model. If I open the diagram file on the
reusing model (only one file is used to hold the model and the diagram),
in the emf editor, the validation uses the problems view correctly. If I
open the diagram file in the diagram view, the red x's show up in the
diagram, but no markers show up in the problems view.
Any pointers as to where to look are greatly appreciated.
Ken
Previous Topic:ant build
Next Topic:Problems View not Showing Markers from EVL
Current Time: Sat May 18 09:36:18 EDT 2013
Powered by FUDForum. Page generated in 0.01475 seconds
