Home » Archived » Hibachi » Project References without effect?
Project References without effect? [message #565937] Tue, 05 January 2010 14:54
Oliver Kellogg is currently offline Oliver Kellogg
Hello Hibachi team,
I'm finally getting around to doing my first steps with Hibachi.
I am using a GNAT toolchain.
I am trying to tell Hibachi about project dependencies, i.e.
I would like to set up the Ada sourcecode search path.
I tried adding the required projects in
"Project" -> "Properties" -> "Project References"
but that did not seem to have any effect (the added projects
do not appear in the switches passed to gnatmake/gcc.)
I'm not sure: Is Hibachi expecting me to specify these directories
in the GPR file?
As a workaround, I'm setting the ADA_INCLUDE_PATH environment
variable. But that is outside of Eclipse, and I'm hoping to find a
mechanism within Eclipse for this.
Many thanks,
Oliver
Previous Topic:Project References without effect?
Next Topic:Is anything happening?
Current Time: Sat May 25 04:32:30 EDT 2013
Powered by FUDForum. Page generated in 0.01472 seconds
