Home » Eclipse Projects » SeMantic Information Logistics Architecture (SMILA) » Deployment of own plugins to SMILA
Deployment of own plugins to SMILA [message #565257] Tue, 14 September 2010 01:57 Go to next message
SMILANewBee is currently offline SMILANewBee
Member
we have several plugins that we want to deploy with SMILA. All works fine except for generating the config.ini file in the configuration folder. In the config file there is specify in which start level the plugins to be start. This is necessary for our plugins.
We adapt the SMILA product plugin to add our plugins to the config file while deployment. But this doesn't work :(.
How can we add our plugins to the config file automatically?
Re: Deployment of own plugins to SMILA [message #565285 is a reply to message #565257] Tue, 14 September 2010 03:49 Go to previous message
Eclipse User
Originally posted by: juergen.schumacher.attensity.com
Am 14.09.2010, 07:57 Uhr, schrieb SMILANewBee <nils.thieme@unister.de>:
> Hello,
Sorry, I don't know this myself. The config.ini in the SMILA distribution
is currently not generated by the product, but copied from
SMILA.application/configuration, where it is maintained manually.
Maybe this also overwrites your generated config.ini?
However, I agree that it makes sense that this file is generated by the
build.
If you find a soluton and can provide instructions how to set up the
product build
to generate the correct config.ini immediately, I can probably apply the
changes to
the SMILA trunk. But I don't have much time currently for experimenting
with the build. (;
Thanks and Regards,
Juergen.
Previous Topic:Integrate now plugins into SMILA deployment
Next Topic:Deployment of own plugins to SMILA
Current Time: Wed May 22 00:21:37 EDT 2013
Powered by FUDForum. Page generated in 0.01672 seconds
