Home » Modeling » Epsilon » Odd bug in generated graphical editor
Odd bug in generated graphical editor [message #565192] Thu, 12 February 2009 05:15
Michael Moser is currently offline Michael Moser
------=_NextPart_000_0011_01C98D03.323719E0
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=original
I generated a simple editor from the attached .emf file. Oddly, when
running the generated graphical editor, one can nicely draw nodes and
connections. But whenever one creates a new node, then suddenly all
connections drawn so far are removed again from the diagram.
Can others reproduce this? Any idea why? Can one fix this somehow? And
is this now an Epsilon/Eugenia bug or a genuine GMF bug? I presume the
latter, but just wanted to double check. Before reporting transferring
this to the GMF NG.
Michael
Content-Type: application/octet-stream;
name="leonardo2.emf"
Content-Disposition: attachment;
filename="leonardo2.emf"
@namespace(uri=3D"leonardo2", prefix=3D"leonardo2")=0A=
=0A=
@gmf (foo=3D"bar")=0A=
package leonardo2;=0A=
=0A=
@gmf.diagram (foo=3D"bar")=0A=
class Leonardo2 {=0A=
attr String title =3D "Diagram";=0A=
attr String description;=0A=
val Artifact[*] artifacts;=0A=
val Process[*] processes;=0A=
val ArtifactRelation[*] artifactRelations;=0A=
val ProcessRelation[*] processRelations;=0A=
}=0A=
=0A=
@gmf.node(label =3D "name", label.icon=3D"true", figure=3D"rectangle", =
color=3D"255,255,200")=0A=
class Artifact {=0A=
id attr String name;=0A=
attr String location;=0A=
}=0A=
=0A=
@gmf.node(label =3D "name", label.icon=3D"true")=0A=
class ArtifactContainer extends Artifact {=0A=
val Artifact[*] contents;=0A=
}=0A=
=0A=
@gmf.node(label =3D "name", label.icon=3D"true", color=3D"200,255,200")=0A=
class Process {=0A=
val ArtifactRelation[*]#process1 artifactRelations;=0A=
val ProcessRelation[*]#process2 processRelations;=0A=
}=0A=
=0A=
@gmf.link(target=3D"artifact", source=3D"process1", label=3D"name", =
target.decoration=3D"arrow", style=3D"dash", width=3D"2", =
incoming=3D"true")=0A=
class ArtifactRelation {=0A=
attr ArtifactRelationType relationType =3D "0";=0A=
ref Artifact artifact;=0A=
ref Process#artifactRelations process1;=0A=
}=0A=
=0A=
enum ArtifactRelationType {=0A=
CREATES =3D 0;=0A=
READS =3D 1;=0A=
UPDATES =3D 2;=0A=
DELETES =3D 3;=0A=
IS_INSTANTIATED_FROM =3D 4;=0A=
}=0A=
=0A=
@gmf.link(target=3D"target", source=3D"process2", label=3D"name", =
target.decoration=3D"arrow", style=3D"dot", width=3D"2", =
class ProcessRelation {=0A=
attr ProcessRelationType relationType =3D "0";=0A=
ref Process target;=0A=
ref Process#processRelations process2;=0A=
}=0A=
=0A=
enum ProcessRelationType {=0A=
INSTANTIATES =3D 0;=0A=
CALLS =3D 1;=0A=
SENDS_DATA =3D 2;=0A=
RECEIVES_DATA =3D 3;=0A=
TERMINATES =3D 4;=0A=
}=0A=
=0A=
------=_NextPart_000_0011_01C98D03.323719E0--
Previous Topic:up-to-date list of supported annotations?
Next Topic:up-to-date list of supported annotations?
Current Time: Mon May 20 01:27:08 EDT 2013
Powered by FUDForum. Page generated in 0.11470 seconds
