| up-to-date list of supported annotations? [message #565158] |
Thu, 12 February 2009 05:10 |
Michael Moser Messages: 914 Registered: July 2009 |
Hi, I tried a few more of the @gmf annotations listed at
http://epsilonlabs.wiki.sourceforge.net/EuGENia,
among them things like ... figure="...", color="..."
When defining explicitly figure="roundedrectangle" (just to make this
explicit, even though that's the default) then - when generating the
diagram code - this leads to:
roundedrectangle cannot be resolved to a type ProcessEditPart.java
test.diagram/src/test/diagram/edit/parts line 217 Java Problem
The method add(WrappingLabel) is undefined for the type
ProcessEditPart.ProcessFigure ProcessEditPart.java
test.diagram/src/test/diagram/edit/parts line 242 Java Problem
The method setBackgroundColor(Color) is undefined for the type
test.diagram/src/test/diagram/edit/parts line 230 Java Problem
Type mismatch: cannot convert from ProcessEditPart.ProcessFigure to
IFigure ProcessEditPart.java test.diagram/src/test/diagram/edit/parts
line 97 Java Problem
I guess only the first is the real problem, the others seem to be
consequential bugs. Shall I open a Bugzilla?
Michael
FUDForum. Page generated in 0.08516 seconds
