| UML/EMX [message #564813] |
Fri, 22 January 2010 06:48 |
Hi All;
I am trying to create Class Diagram in RSM programatically by APIs suggested in topic "Generating UML models programmatically by using IBM Rational Software Architect"
http://www.ibm.com/developerworks/rational/library/08/0826_m akady/
Every thing is working fine except UML Association between Classes. The code snippets are as....
IUMLDiagramHelper diagramHelper = UMLModeler.getUMLDiagramHelper();
Diagram diagram = diagramHelper.createDiagram(model, UMLDiagramKind.CLASS_LITERAL);
Class mainClass, subClass;
Node mainNode, subNode;
Association association = mainClass.createAssociation( end1IsNavigable, end1Aggregation, end1Name,
end1LowerBound, end1UpperBound, type2, end2IsNavigable,
end2Aggregation, end2Name, end2LowerBound, end2UpperBound);
diagramHelper.createEdge(mainNode, subNode, association);
When end1Name & end2Name arguments have empty value, then opening diagram displays error message "IRJA0244E <Property> ......... must be named.", All changes is reverted, & not saved automatically..
But same Association object is fine with Eclispe 3.4 UML Class diagram..
please help me out, If you have any idea.
Thanks in Advance
Kishore
FUDForum. Page generated in 0.02367 seconds
