Home » Eclipse Projects » DSDP - Target Management » Remote Project
Remote Project [message #564756] Tue, 10 October 2006 11:16
Edward Mann is currently offline Edward Mann
First of all thanks for the great plugin to Eclipse. This is awesome. I
have been waiting for something like this. I use Linux and was using
FuseSSH to do my remote work.
My Question.
When i try and create a new project for RSE i am having problems.
Here are my steps.
My RSE connection is setup using sftp and if i am in the Remote System
Perspective i can view files on the remote system and work with them.
1. Create new project. I select PHP Project click next.
2. add my prject name and de-select the "Use default location" button and
pick RSE
3. click the browse button. When i do this even if my connection is the
remote box i don't get the remote tree view. I select a different
connection and then back to the connection that i want. I will then get
the remote system tree view.
4. Select the directory that i want to base my project off of. Click ok
5. Then i will see rse://my.server.tld/my/remote/path click finish...
nothing happens. I don't get an error, or any prompt and the new project
is not created. Is there something that i am doing wrong? Do i need a
dstore for this? I am not the admin of the remote system and do not have
root access. So i can not put the dstore software on that machine.
My setup.
Fedora Core 5
Linux 2.6.17-1.2187_FC5smp
Eclipse Version: 3.2.1
Build id: M20060921-0945
Java from Sun
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-b05)
Java HotSpot(TM) Client VM (build 1.5.0_06-b05, mixed mode, sharing)
RSE Core 1.0.0.v20060928------AXrVWXfeYa
RSE Dstore Connector Service 1.0.0.v20061006
RSE Dstore Core 1.0.0.v20061006
RSE Dstore Files 1.0.0.v20061006
RSE Dstore Platform Support 1.0.0.v20061006
RSE Dstore Services 1.0.0.v20061006
RSE Dstore Shells 1.0.0.v20061006
RSE Dstore SSL Support 1.0.0.v20061006
RSE EFS Support 1.0.0.v20061006
RSE Files Core 1.0.0.v20061006
RSE Files UI 1.0.0.v20061006
RSE FTP Files 1.0.0.v20061008
RSE FTP Services 1.0.0.v20061007
RSE SSH Connector Service 1.0.0.v20060921
I have many more than these, if you need an full list, or if i need to
have a specific plugin install please let me know.
Again thanks for the great plugin. It is something that has helped me get
eclipse on more desktops here at the shop.
Previous Topic:RSE 1.0 RC1 posted
Next Topic:Remote Project
Current Time: Mon May 20 02:24:06 EDT 2013
Powered by FUDForum. Page generated in 0.01484 seconds
