Home » Eclipse Projects » Orbit » org.aopalliance bundle do not specify version on exported packages
org.aopalliance bundle do not specify version on exported packages [message #564375] Wed, 10 September 2008 06:03
Frederic Conrotte is currently offline Frederic Conrotte
Following discussions about Xalan, Xerces libraries and Riena's problems
with package versioning, I have the same kind of problem in Eclipse OFMP
regarding the org.aopalliance bundle provided by Eclipse.
One of OFMP external dependencies requires
Import-Package: org.aopalliance.aop; version="1.0.0",
org.aopalliance.intercept; version="1.0.0"
But the org.aopalliance provided by Eclipse does not specify versions of
exported packages:
org.aopalliance/MANIFEST/MANIFEST.MF
Export-Package: org.aopalliance.aop, org.aopalliance.intercept
Bundle-Version: 1.0.0
instead of
Export-Package: org.aopalliance.aop; version="1.0.0",
As reminder OSGi R4 specs specify that no version on exported or imported
packages defaults to 0.0.0 version instead of the "Bundle-Version" meta-tag
version
All these issues come from projects slowly moving to the OSGI best practice
of using "Import-Package" meta-tag instead of "Require-Bundle", which is a
good thing.
I agree with Jeff's point that it should be an Orbit-wide effort/policy to
specify imported/exported packages versions.
Should I file a bug for this to the Eclipse runtime project or should we
move org.aopalliance bundle to Orbit and fix it there ?
Frederic
Previous Topic:Usage of the commons logging bundle.
Next Topic:org.aopalliance bundle do not specify version on exported packages
Current Time: Wed May 22 19:59:22 EDT 2013
Powered by FUDForum. Page generated in 0.05073 seconds
