Home » Modeling » Graphiti » Use dependency injection instead of singletons for services
Use dependency injection instead of singletons for services [message #563473] Wed, 18 August 2010 10:56 Go to next message
Ken Wenzel is currently offline Ken Wenzel
Member
instead of using singletons for Graphiti's services which are accessed by Graphiti.getGaService() and others, dependency injection would open the possibility of replacing the standard services by user-defined ones.
Does the Graphiti team plan to use Guice or other frameworks for dependency injection?
Ken
Re: Use dependency injection instead of singletons for services [message #563497 is a reply to message #563473] Thu, 19 August 2010 04:24 Go to previous message
Michael Wenz is currently offline Michael Wenz
Hello Ken,
thanks for this suggestion. As always it is a good approach to seperate API
from implementation, e.g. by using dependency injection.
Nevertheless, currently we see our services more or less as a static
offering towards the tools. So, at least currently we don't have plans in
this respect. Do you have a concrete usecase in which you would need this?
Michael
"Ken Wenzel" <kenwenzel@gmx.net> wrote in message
news:i4gsb3$7nd$1@build.eclipse.org...
> Hello,
> Best regards,
> Ken
Previous Topic:How do I get started?
Next Topic:Alternative implementations of diagram meta model?
Current Time: Fri May 24 15:25:27 EDT 2013
Powered by FUDForum. Page generated in 0.05477 seconds
