Home » Eclipse Projects » ATF » Javascript Validation
Javascript Validation [message #563219] Thu, 15 July 2010 11:54 Go to next message
Tobias Willig is currently offline Tobias Willig
I got a problem with the javascript validation, it does not work in HTML files. I'm using the eclipse HTML editor. Auto-completion and syntax highlighting are fully functional. The javascript validation works fine in the javascript editor. My eclipse version is Helios.
Is there a way to enable javascript validation for the HTML editor?
Re: Javascript Validation [message #563270 is a reply to message #563219] Mon, 19 July 2010 02:25 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
On 7/15/2010 11:54 AM, Twilli wrote:
> Hello,
Is your project enabled for JavaScript and the web page in the
JavaScript Include Path? If the project's not enabled for JavaScript at
all, a quick trip to its Configure context menu should do the trick.
Otherwise, check the JavaScript Include Path property page on the
project and make sure you've defined a Source folder.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Mirror of mozilla xpcom update site
Next Topic:Javascript Validation
Current Time: Tue May 28 21:44:27 EDT 2013
Powered by FUDForum. Page generated in 0.01708 seconds
