Home » Eclipse Projects » ATF » Browser proxy configuration
Browser proxy configuration [message #562642] Mon, 01 February 2010 06:45 Go to next message
froq  is currently offline froq
After installing ATF, opening URL fails. Since I'm behind a firewall I guess I need to configure the proxy. How?
Re: Browser proxy configuration [message #562664 is a reply to message #562642] Mon, 01 February 2010 10:40 Go to previous messageGo to next message
Jacek Pospychala is currently offline Jacek Pospychala
hi Froq,
unfortunately ATF doesn't provide any UI for proxy configuration at the
moment, however you're not totally lost.
Since we're based on XULRunner, ATF creates a separate profile in your
home directory: <home>/.mozilla/eclipse
There you'll find prefs.js file with all preferences. For example proxy
preferences can look like this:
user_pref("network.proxy.http", "150.254.6.139");
user_pref("network.proxy.http_port", 8080);
user_pref("network.proxy.type", 1);
If you're on Windows, then it should be <home>\Application
Data\.mozilla\eclipse, however I didn't tested that.
I have also created following bug, to fix this:
301424: Integrated browser should use proxy settings as configured in
Eclipse
https://bugs.eclipse.org/bugs/show_bug.cgi?id=301424
thanks
Jacek
Re: Browser proxy configuration [message #562687 is a reply to message #562642] Mon, 01 February 2010 13:41 Go to previous message
Hi Jacek,
Great, it works fine for windows!
Thx. :)
Previous Topic:Blog on dev.eclipse for ATF
Next Topic:Browser proxy configuration
Current Time: Sat May 25 01:59:36 EDT 2013
Powered by FUDForum. Page generated in 0.01738 seconds
