actually i cannot make the example "de.vogella.e4.todo" work after step by step to setup the project, launch the eclipse application ends up with error
ava.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
i'm using the 4.1.0 I20110620 build. have you any idea why this happens?
I also tried the example after download the de.vogella.e4.css, after small change with import and plugin.xml, add extension point org.eclipse.e4.workbench.parts and schema schema/org.eclipse.e4.workbench.parts.exsd, i can get rid of all red crosses in Eclipse, in product definition, i also set it as org.eclipse.e4.ui.workbench.swt.E4Application
but lauch the application ends up with error:
java.lang.IllegalStateException: Core services not available. Please make sure that a declarative service implementation (such as the bundle 'org.eclipse.equinox.ds') is available!
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:194)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:130)
i have a complete Eclipse installation and installed all updates, anything i can do to make this work?
actually still error in Application.e4xmi (i rename the file from Application.xmi to Application.e4xmi).
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http:__www.eclipse.org__ui__2008__Application' not found. (platform:__resource__de.vogella.e4.css__Application.e4xmi, 2, 197)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
after i recreate a new Application.e4xmi from workbench model editor with only empty window, i still get the error if i launch the application.
Please use the e4 project wizard which creates a .product with all
plugins needed to launch an eclipse 4 application.
You are missing equinox.ds in your launch config.
Tom
Am 23.09.11 12:03, schrieb peter pan:
> at
> at
> it cannot show me a single empty window :(
