| XWT and i18n [message #562047] |
Sat, 08 August 2009 06:15 |
Werner Keil Messages: 1067 Registered: July 2009 |
I noticed, XWT from the same vendor who already works with Eclipse and
Silverlight seems to become a commonly used technology for E4.
All demos and samples so far put UI messages mostly into the XML directly.
So how does i18n work there?
If Eclipse shall use that at least from E4 as a standard, then I guess all
the translation efforts, primarily undertaken by the Babel Project shall
also apply to UI elements created with XWT just as they do with normal SWT
components?
Werner
FUDForum. Page generated in 0.01429 seconds
