Home » Eclipse Projects » Tigerstripe » Errors using TS 2.2.4
Errors using TS 2.2.4 [message #562045] Thu, 06 March 2008 09:57
Marc FLAUW is currently offline Marc FLAUW
I was using Tigerstripe 2.2.1 and I had several projects working under
this version.
I have now upgrated to 2.2.4 and Eclipse Europa. For each one of my
project, I have the following 2 errors:
Project 'fm_model' is missing required library:
'C:\eclipse\plugins\com.tigerstripesoftware.workbench.base_2 .2.1.v20070730-0941\src\compatibility\1.1.x\distrib.core.mod el-1.0.6.jar' fm_model Build
path 1204801538209 6735
'C:\eclipse\tigerstripe\phantom\lib\phantom.zip' fm_model Build
path 1204801538209 6734
Can you help?
Marc
Previous Topic:Loading SID UML Model into Tigerstripe
Next Topic:Errors using TS 2.2.4
Current Time: Sat May 25 16:51:41 EDT 2013
Powered by FUDForum. Page generated in 0.16033 seconds
