| [ANN] oXygen XML Editor major version 7 [message #561524] |
Tue, 24 January 2006 11:19 |
Originally posted by: george.oxygenxml.com
Syncro Soft Announces New Release of <oXygen/> XML Editor, Schema Editor
and XSLT Debugger.
Release date: January 16, 2006
Syncro Soft Ltd, the producer of <oXygen/> XML Editor, has announced the
immediate availability of version 7.0 of its XML Editor, Schema Editor
and XSLT Debugger.
Version 7.0 of the <oXygen/> XML Editor adds more than 50 important new
features like continuous validation and on screen marking of the errors,
XQuery debugging, XPath content completion and XSLT refactoring actions.
For the complete list of new features please visit
http://www.oxygenxml.com/index.html#new-version
New in version 7.0:
Document validation has been improved by adding continuous validation
support (validate as you type), error markers and overview ruler,
multiple external validation engines and support for CSS validation.
Parsed schemas are being cached to improve the validation speed.
XPath support benefits now of an XPath aware content assistant showing
functions and axes (all documented with sections from the W3C
specification), variables and parameters as well as name tests for
elements and attributes in context. For XPath 2.0 queries the XPath
default namespace can be configured/automatically detected and used when
writing XPath queries.
XSLT editing features now an XSLT input document view presenting the
tree structure of the XML document set for the current stylesheet in the
associated transformation scenario. You can create templates or other
XSL snippets by dragging the nodes from the tree into the stylesheet;
the generated XPath expressions are context aware. Refactory actions
like renaming XSL occurences, creating an XSL template from selection or
creating an XSL stylesheet from selection as well as search XSL
references/declarations or occurrences are available. You can also apply
a transformation scenario for multiple files in one action.
XQuery debugging perspective has been added. The debugging support is
based on Saxon XQuery processor from Saxonica and the layout and
features provided are similar with the ones available on the XSLT
perspective (including XQuery profiler).
The content completion support was improved to show the recent content
items, handle namespace prefixes, learn words and present #ID URI
fragments for anyURI attribute values and a better CSS content assistant
is provided.
User interface improvements includes configurable GUI fonts, result
views allowing both table and tree layouts, folding support for
JavaScript and CSS and non-modal Find dialog. Now, not only the views
can be moved around the interface but also the editors can be arranged
as you need inside the editing area. Additionally, each editor can be
split horizontally or vertically. Splitting an editor allows you to copy
or move text and markup between two sections of the same document.
Other new features includes new views like information, properties or
images preview, different element colors depending on the XML prefix,
contextual spell-checking correction on a mis-spelled word, extract XML
Schema from a database structure and floating license support over Internet.
Pricing and Availability
<oXygen/> XML Editor and XSLT Debugger is available immediately in two
editions:
Multi-platform Academic/Non-profit license costs USD 48.00
Multi-platform Professional license costs USD 180.00
<oXygen/> XML Editor and XSLT Debugger can be run as a standalone
application on Windows, Mac OS X, Linux, Solaris and as an Eclipse plugin.
Version 7.0 is available for free trial download from
http://www.oxygenxml.com/download.html
To purchase please visit the XML Editor store at
http://www.oxygenxml.com/buy.html
<oXygen/> is a registered trademark of Syncro Soft in the U.S and other
countries. Any other trademarks or service marks contained herein are
the property of their respective owners.
SOURCE: Syncro Soft Ltd.
support at oxygenxml dot com
FUDForum. Page generated in 0.02156 seconds
