| cannot find packages for p2 [message #561448] |
Wed, 30 June 2010 07:45 |
Luca Ferrari Messages: 159 Registered: November 2009 |
Hi all,
I've got an RCP stand-alone application and I'd like to use P2 to provide auto-update mechanism. Having a look at http://wiki.eclipse.org/Equinox/p2/Adding_Self-Update_to_an_ RCP_Application it seems that the Headless Updating on Startup section gives me what I want. However, trying the following code (directly from the web page above):
public class P2Util {
// XXX Check for updates to this application and return a status.
static IStatus checkForUpdates(IProvisioningAgent agent, IProgressMonitor monitor) throws OperationCanceledException {
ProvisioningSession session = new ProvisioningSession(agent);
// the default update operation looks for updates to the currently
// running profile, using the default profile root marker. To change
// which installable units are being updated, use the more detailed
// constructors.
UpdateOperation operation = new UpdateOperation(session);
SubMonitor sub = SubMonitor.convert(monitor,
"Checking for application updates...", 200);
IStatus status = operation.resolveModal(sub.newChild(100));
if (status.getCode() == UpdateOperation.STATUS_NOTHING_TO_UPDATE) {
return status;
if (status.getSeverity() == IStatus.CANCEL)
throw new OperationCanceledException();
if (status.getSeverity() != IStatus.ERROR) {
// More complex status handling might include showing the user what updates
// are available if there are multiples, differentiating patches vs. updates, etc.
// In this example, we simply update as suggested by the operation.
ProvisioningJob job = operation.getProvisioningJob(null);
status = job.runModal(sub.newChild(100));
return status;
I got compilation errors even from IProvisioningAgent: I cannot find the package where the class is, even if I've added the p2.ui, p2.core, p2.ui.sdk and p2.ui.sched bundles to the java build path and runtime dependencies. The only doubt is that I got such bundles directly from the plugins directory of the Eclipse IDE installation.
Am I doing something wrong?
FUDForum. Page generated in 0.01694 seconds
