| Re: Copying models in ETL [message #561440] |
Tue, 11 November 2008 10:29 |
Steffen Zschaler Messages: 221 Registered: July 2009 |
Hi again,
I have a core ecore metamodel and want to generate an extension
metamodel for this. This essentially means that I need to add a few
subclasses for some abstract classes in the core metamodel. As discussed
in earlier mails, I have a few tools that have problems with ecore
metamodels referencing each other. Hence, I cannot use linking between
the metamodels. Instead, I am planning to hack around this by including
a copy of all classes and relationships from the core metamodel in my
generated metamodel.
What is the most efficient way of creating such a copy?
Many thanks,
Steffen
Dimitrios Kolovos wrote:
> Hi Steffen,
> There are more than one ways to do this in ETL, EOL. Could you please
> give me a bit more details as to what you are trying to do so that I
> can suggest the best solution?
> I'd be grateful if we could take the discussion over to the
> eclipse.epsilon newsgroup as it sounds as something potentially
> interesting to others too (and also the more activity in the
> newsgroup, the better for the project ;)
> Cheers,
> Dimitrios
> Steffen Zschaler wrote:
>> Is there a possibility in ETL to create a copy of a source model to
>> be further expanded in the transformation?
>> Many thanks,
>> Steffen
FUDForum. Page generated in 0.01576 seconds
